Question about Sharp Microwave Ovens
We have an old Sharp Carousel R-1440 that works great, except for the door latch broke (i.e. doesn't work at all now). Can we replace just the door?
  • Anonymous Feb 02, 2009
    14 year old Carousel 1440--the door latch sinks in and does not engage.
  • Sharp Master
  • 9,098 Answers
Actually, the door latch head (hooklike device) is pretty easy to replace or repair if that's the issue.
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Sep 27, 2008
My sharp carousel microwave only works when I depress the door knob halfway down. What could be wrong ?
All microwaves have a safety lever or switch that prevents the unit from working if door is not closed all the way. Most of them you have to take the unit apart as access to it is from inside--what happens is when door is closed the latch or door moves the lever--seen a number where lever is loose or even the holder for it cracked.
Most shops are familiar with this and it should if the problem not be a real expensive repair.
Jun 16, 2012 | Sharp Carousel R530EST Microwave Oven
My microwave wont turn on. the power works, clock, timer and all electrical is working, it just wont turn on.
Most likely you have an interlock microswitch problem or a latch problem. as you just open or just close the door VERY slowly listen for 3 distinct clicks one for each of the 3 interlocks. Two you will hear as you press the door open button and the last one you will hear as the door just opens or closes. If you do NOT have 3 clicks you have a bad micro-switch.
The micro-switches you can purchase on line here:
http://www.repairclinic.com/Sharp-Microwave-Switch-Parts
Owners manual: (Provided only for telphone contacts in first 2 pages.)
http://files.sharpusa.com/Downloads/ForHome/HomeAppliances/MicrowaveOvens/Manuals/mic_man_R530ES.pdf
I think you just have a simple micro-switch problem. However... if the latch assembly that holds the switch is cracked or broken it will have to be replaced. I have seen the plastic latch assembly fail causing the switch not to work properly.
Thanks for choosing FixYa,
Kelly
Jun 28, 2011 | Sharp Carousel R530EST Microwave Oven
I have the Sharp R-1440 carousel microwave oven and it won't shut off when I close the door. Do you know how old this oven might be? Model R-1440; Serial 123662
Check and change door interlock switches or check for condensation problem on control panel, (internal).
Hope that helps.
Feb 02, 2011 | Sharp R-1480 Microwave Oven
Sharp Carousel Model R-1440 won't shut off
Take it immediately to a local Microwave repair shop...looks like one of the circuits may have gone...otherwise switch off from mains
Sep 28, 2009 | Sharp R-1480 Microwave Oven
How to install latch and spring in microwave door
You need to know where the 'catches' are inside the choke cover on the door to remove it carefully without breaking anything or marring the cover. You might get inside and find that the post for mounting the return spring has broken and that is part of the outer door panel.
Sep 11, 2009 | Sharp R-1610 Microwave Oven
Sharp Carousel Model No. R-315F(S)C
this can the be door latch overriding the start
Apr 25, 2008 | Sharp R-1874 Convection/Microwave Oven
Microwave Ovens Logo
168 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
