Question about Husqvarna Zero Turn Mower Z5426
John deere lt120 , 2004
Ignition problem,have to jump soleniod to start, would it be solenoid, ignition switch, or a safety switch?
My zero turn z5426 keeps moving on the left side even when its engaged in neutral
Posted on Nov 05, 2008
    Scholar:
  • 62 Answers
My bet would be a saftey switch. On most riding mowers there are several switches that must be actuated before it will start. First, make sure that blades are disengaged. If there is a handle that engages and disengages them, you might try holding it in the dis-engage position in case the switch is out of adjustment. There is probably one under the seat also. This switch kills everything if you are not sitting in the seat for safety reasons. Also, make sure the parking brake is set, and the gear is in neutral, and not forward or reverse.
Hope some of this helps.
C
Posted on Oct 08, 2008
LX176 John Deere lawn tractor doesn’t get power to the starter, I have replaced the ignition switch and still nothing. Can anyone help?
Oftentimes there are switches at the blade engagement lever and under the seat...for safety reasons. I can't start my mower if the blade drive is engaged and /or I'm not in the seat. That's a clue to check , however I'd check the starter solenoid first.
Oct 17, 2017 | John Deere Garden
I have an old john deer I think 1982 put new ignition on and solenoid and batt. turn key I get nothing it will start if you jump across. but turn key nothing.can you show me wiring
It will start if you jump across WHAT? The electrical terminals on the key switch? The solenoid actuating terminal to ground? Need more info!
Apr 18, 2017 | Garden
When I turn my john deere sabre off at the key the engine shuts down, however ten seconds later the fuse blows. Also brand new safety switches are killing engine when released. Suggestions?
Somewhere, probably in the ignition switch circuit there is a short circuit - otherwise the fuse would not blow. You'll need to take a test meter to each circuit in turn to isolate the circuit and then find the short. Be logical and patient!
Apr 29, 2015 | John Deere Garden
John Deere 855 Compact tractor has no power to solenoid
Power from the battery direct to a big terminal on the solonoid. The other big terminal leaves the solonoid for the starter. Then there are either one (1) or two (2) smaller terminals on the solonoid. If there is one then the body of the solonoid is the ground. With two of course the extra is the ground. Make sure the solonoid has a good ground.
Remove the smaller terminal from the solonoid ( usually yellow) and connect the positive end of a multimeter or a DC volts tester to it. ground the other end of the tester and turn the ignition key to start. If you get 12 volts to the wire end then the solonoid is bad and should be replaced. If no voltage is registered then the ignition switch is bad or an inline safety switch such as: nuetral, clutch/brake, PTO, seat ( Operator Presence Switch). Or you have a bad wire, bad ground, bad connection somewhere in the starting system.
Oct 31, 2012 | John Deere Garden
John Deer L130 lawn tractor: Start with jumper on solenoid.
i would check the safety switches you can jump them and find the bad one
Mar 28, 2012 | John Deere Garden
John Deere 2010 utility tractor, lights come on dash board, but it wont start. Its in neutral, PTO is okay, seat switch okay
1) Battery condition and clean cable connections
2) Check the voltage & connections at the solenoid
*Is full battery voltage found at the solenoid?
3) Does the small wire that activates the solenoid from the ignition switch/safety switches have voltage when the key is in the start position
a) voltage yes, but it does not start; suspect solenoid
b) voltage no, inspect and check all safety switches for voltage to and from each switch
c) safety switches do NOT have voltage to them: inspect connections on ignition switch and check for voltage coming into the switch from the battery.
Nov 09, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Husqvarna Zero Turn Mower Z5426 Logo
606 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
