Question about Maytag Dryers
Maytag gas dryer. I have long drying times unless I put a jumper wire across the high limit switch. With the jumper wire on the dryer cycles normally and appears normally. I just replaced the switch with a new one and I have the same problem. I doubt that the new switch is bad. Any ideas?
  • 706 Answers
Hi DonaldGuppy,
If multiple high limit switches sense an 'above the upper limit temp' then in all probability it is working correctly but your exhaust system may not be ( meaning your exhaust vent is restricting air flow or your blower is damaged or has an obstruction in it) Check the entire vent system all the way out and including the end cap for restrictions. The back pressure from the blower not being able to move air adequately may be contributing to excess drying times and high temp condition..In fact.. you just might have a problem with the blower itself.. so check for a fairly brisk flow of air coming out.. You can unhook the vent line for a second or two indoors to get a feel for what is coming out of the dryer at the point of exit, then use that for comparison to what you get at the end of your duct system..Obviously you do not want to run the dryer that way and have those gases fill up a room but it's OK to do a short test drive like that. You may have some losses in the vent but it should not be dramatic. Also... make certain your lint trap is free of lint. These tips should help you zero in on the real problem.. Hope this helps...
Posted on Sep 27, 2008
I have a maytag dryer mdg 6460aww. timer is not working I I exchanged-timer. , temp switch, cycling th'st, high limit th.st My question is why does not operate on a timer
It's none of the above. The part your dryer requires is the dryness control board part #33002905. Unfortunately they are NLA. If you are really good, you can study the wiring diagram, unplug the board from the system and send power directly to the timer from the motor to run the timer when the unit is running. This will only work properly for the timed dry selection as the dryness sensing is eliminated.
Beats replacing the dryer and the part MAY be remanufactured by Whirlpool. So it might be available in the near future.
May 01, 2014 | Maytag Atlantis MDG8400AW Gas Dryer
Maytag gas dryer model SDG4606AWW timer wont rotate on any cycle, dryer just keeps running until knob is rotated manualy to off, replaced timer and new one is doing the same, took dryer compltley apart,...
I don't have a Maytag schematic handy but there should be one on or in the dryer. Trace the clock wiring back until until you get voltage. I am betting one leg of the time motor goes to the drum motor (Gray wire maybe) and the other leg to the dryness sensor module (brown wire). Check these wires against both Line and Neutral. That should tell of it's the module or the motor block.
Nov 04, 2013 | Maytag Dryers
Troubleshooting m460g timer
you should have power across the two wires to the timer while it is running . Power needs to be on the timer for it to work. One wire should be low ohms to the ground or metal surface and the other wire should be the power wire to the timer motor. if no power on the other wire to timer follow it back and you may find an open in a door switch or temp switch. good luck
Nov 04, 2013 | Maytag Dishwashers
I have a maytag dryer, model # MDG4000BWW. It has...
check the high limit/cycling switch thermostat located on the heat housing ,you will need to remove the front panel to access this,then, bypass the high-limit with a jumper wire and see if the flame stays on longer,if this doesn't help, then check the radiant senser on the tube also they get dirty,you can clean the senser eye or bypass this also and see if its weak,if not then replace the 2 gas coil valves on the gas valve body as these will get weak and shut off the gas supply
May 20, 2010 | Dryers
I have a Maytag PYG3200AWW and it won't start.
Sounds like a problem with a limit control switch. Some are manual reset and some are automatic . Not sure about yours. They are located of course, in-line within the wiring harness limiting the amount of heat build-up within the machine. If yours had been running with a stopped up, or patially stopped up vent, (and your limit swithch IS AUTO reset,) then the switch could have been cycling the heat numerous times, over that period, preventing overtemperature conditions. This would weaken the switch because it is a safety device and not actually a cycling device. Also, in the vent exhaust, @ the back of the machine there may be a limit switch. And of course, it could always be the start button..........
Jul 27, 2009 | Maytag MGD6300T Gas Dryer
Dryer turns no heat and can smell gas
airflow through the tube keeps the sensors from tripping. low flow, quick cycle. when its all together, does it blow out back strong? is the blower stripped? gas keeps coming out scares me..what do you mean?
May 25, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Slow to dry cloths
Remove the vent from the back of the dryer and see what the temps are. The cycling (or operating) thermostat is on the blower housing and opens more than 100* lower than the 266 you are reading. That, combined with the long dry times indicates an airflow issue. Check your lint screen....fabric sheet and lint can combine to coat and restrict air flow through it. Also check down in the blower housing with the lint screen removed. You'll see lint build up by looking down the slot with a flashlight. If it's restricted, so is the blower wheel and the blower housing. Also make sure the flap, or lovers at the vent hood outside are opening fully. Remove any accumilation of lint from there.
The high limit control is just that........If you cycling thermostat has failed, or does not open because there is no airflow, the limit control opens as a safety. On a normally operating dryer, the high limit control will never open.
The neptune dryer is designed to move more air than a regular dryer due to the higher capacity load it get's from the neptune washer. That is the case with most front load laundry pairs.
May 06, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Performa Electric Dryer Won't Start
check the blower wheel, sounds to me like it is loose on the blower motor, common on these dryers. One sure sign would be a warped filter and a rusted top. The blower aint putting out enough and the dryer is over heating .
/uploadswith image
Mar 08, 2009 | Maytag PYE2300AY Electric Dryer
Dryer doesn't dry
no but are you sure your replacement parts are correct the cycle stat is usally running about 140 - 160 temps did you switch the high one and the cycling wires or parts?
May 12, 2008 | Dryers
Dryers Logo
57 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
