Question about Hoover H130E Front Load Washer
Very noisy spin on my front loader, sounds like a loud hammer bashing and washing smells
  • 32 Answers
Sounds like you have a broken stanchion on the rear of the basket,usually a fatal diagnosis because price of repair excess cost of new one.check your manual and look under warranty.if you have a extended warranty on parts(stainless steel basket and tub)you would only have to pay for labor...good luck
Posted on Sep 29, 2008
Why is my front loader noisy at end of cycle in spin?
Most likely the rear main bearing is bad
Jul 13, 2015 | LG Washing Machines
My front loader Ariston A1636S. Is washing and pumping water out very quiet, but when it comes to spinning has become noisy, and perhaps describe as a grating noise. But no strange smells.
Most common causes of noisy spin are something has found its way between the drum and its casing or the heater has come adrift from its fixing and is rubbing on the drum
Mar 31, 2015 | Ariston Technologies Washing Machines
Smelly water & not going into spin
Try cleaning out the pump access port. It is at the front of the machine.
All sorts of stuff gets into these pumps on front loaders. A partial clog will go what you describe.
If you use a mesh laundry bag it will keep this from happening
Mar 23, 2014 | Bosch Washing Machines
Loud grinding noise when on when it starts to spin?
If it is a front loader, then it sounds like the drum bearings have failed, spin the drum from the front by hand, if it feels rough or is noisy, then bearings have failed.
Jan 26, 2011 | Washing Machines
Loud clanking noise during spin cycle. Will not
If it is a front loader, then remove the rear panel, remove the belt, and soin drum by hand, if it feels rough, or is noisy and rumbling, then the main drum bearings have failed.
This is a major repair.
Feb 01, 2010 | Whirlpool LHW0050PQ Front Load Washer
I have a noisy ariston front loader washing machine and
From the front of the washer, spin the drum by hand, and if it feels rough, or is noisy, or rumbling, then the main drum bearings have failed..
If no noise, then problem is elsewhwere.
Hope this helps.
Jan 27, 2010 | Ariston Technologies AW149NA Washer
Loud banging when spinning
but a small load in . if happen then it sounds as if the bearings have gone at the back of the drum.
May 12, 2009 | Washing Machines
Noisy Spin Cycle
frigidaire frontloader infamous for rear bearings going bad,NOISY is probable an understatement. I wold open door and grab hold of inner tub, try to lift it up a bit, problably a bit of play in there, thats an indication of bearing failure, call authorized servicer possible warr parts
Feb 22, 2008 | Frigidaire FWT449
Danby washing machine noisy only during spin cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jan 13, 2008 | Danby DWM99W Top Load Washer
Kenmore front loader drum grinding
This can be a symptom of drum bearing wear. A quick check for wear is to see if the inner drum moves up and down relative to the fixed outer drum. It should only move a minute amount. If it moves more than a millimeter or two, it is probably worn bearings. Regarding the bad smell - Make a boil wash (with no clothes and detergents) put in the powder's drawer a cup of bicarbonate of soda. It should clean the machine and remove out the bad smell. Good luck!
Sep 14, 2007 | Frigidaire GLTF1670A Front Load Washer
Hoover H130E Front Load Washer Logo
131 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
