Question about Maytag Washing Machines
Water will not drain out even though washer in spinning
  • 943 Answers
Hi thanks for the question i would look at the drain hose some piece of clothing is caught in drain line check that first thanks the appliance doc
Posted on Sep 27, 2008
Diagnostics ok but only spins slow
Water pump screen is plugged. Will not drain properly even though it goes into high spin.
Mar 14, 2014 | Kenmore HE3T Washer
My Samsung duet washer is not draining properly and after awhile when it does not drain the message F02 shows on the console. It also does not spin even though it is showing it in the spin cycle.
It won't spin until all of the water is drained out of it. It probably needs the drain pump replaced. Take of the back cover and see if you can hear the pump hum. If you can and no water is coming out of the drain hose, remove the pump and check for obstruction. Alot of the time socks get stuck in the pump. If nothing is preventing the pump from turning, replace the pump.
Nov 26, 2009 | Samsung WF337AA Front Load Washer
Front load washer, will not do final rinse
A lot of times it is the strainer clogged at the pump. Hope that helps.
Sep 08, 2009 | Frigidaire Affinity ATF7000E Front Load...
GE toploader Washing Machine pumping problems
Sounds like the water is syphoning away due to the drain outlet hose being too low..Raise the hose higher, and this should solve the poroblem.
Oct 31, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Whirlpool washer won't spin even though motor is running
Sounds like the the motor belt is worn or off. Try a new belt, or check the drain pump filter for clogs.
If you've got a handy friend, it's easy to check these... remove the back of the washer (about 12 srews) and check for black dust inside, or a belt hanging or lying on the bottom.
To check the drain pump filer screen, look for the drain hose, follow it into the back of your washer and down to a plastic bow looking unit. There should be a round cover with a kind of handle on it. remove the cover, (water may run out... have a few towels handy) clean off lint etc. and put back together. Try again...
Feb 06, 2008 | Washing Machines
Washing Machines Logo
24 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
