Question about Intel Desktop Board D815EEA2 (BOX815EEAA2) Motherboard
Where can I get an IDE driver?
I found IATA98.CAB on Intel download site but that is not a .sys driver. I am trying yo use boot.ini to load the driver but I CANNOT find one...
Thanks
  • stillkickin Sep 28, 2008
    Thanks for the quick response!
    1) There's the problem! I need the '.sys' driver in order to boot into Windows! I am getting the '7B' stop code that says I need an IDE controller driver.
    2) I am using a modified boot.ini (which looks for the .sys driver) boot floppy.
    3 So back to the original question: Does anyone know where I can get the interlata.sys or intelide.sys drivers? I downloaded the driver from the Intel website but it is a '.cat' file that 'contains' the needed driver. Unfortunately I cannot 'open' Intel's .cat file.
    ...Just another day in paradise!
  • 158 Answers
Install chipset driver,
repair the windows
Posted on Sep 27, 2008
Advent will not BOOT
The BOOT.INI file may be corrupt. Boot to a command prompt and rename original file c:\ren boot.ini boot.tmp. Now type edit. and insert the following script.
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect
Save as boot.ini. Alt key gives you the menu options
You can also create the file elsewhere and copy to c:\ Remember to rename original.
Note! This is a single partition standard from factory configuration.
Oct 25, 2012 | Computers & Internet
Windows 98 system only boots in to safe mode
try this, load windows in safe mode
click start, click run, type "msconfig" in the open box, and click ok
click selective startup
disable (clear the check boxes for) system.ini and win.ini
click ok, reboot
if it loads, cool, if not
do the same as before, but enable system.ini and win.ini, disable config.sys and autoexec.bat
click ok, reboot
do the same thing, but enable config.sys and autoexec.bat, disable winstart.bat and startup items
let me know what happens
Nov 25, 2007 | Computers & Internet
I need a missing driver or software download. i get a message saying "Can't find asussetup.ini. on C:\windows\chipset\asussetup.ini
Well, Chris Hingee has given a nice solution. But if you want to address the issue more efficiently, I'll recommend you to directly try Driver Detective and let the software have a free scan to automatically detect & update the missing drivers. This way you don't have to risk install wrong drivers which might cause severe system issues.
Hope this helps, best regards!
Jun 11, 2012 | ASUSTeK COMPUTER Asus P8p67 Pro Rev 3.1...
Hello to everyone, I have been reading forums for
This is a typical sign of a defective hard drive.Your hard drive might or might not be repairable, depending on the degree of damage.
I would recommend that you use a live CD (such as this one: http://www.ultimatebootcd.com/download.html) to boot up your computer & run a hard disk diagnostic tool like HDD Regenerator. It might take several hours (sometimes days) to fix the damage. If this did not help, then you will have to replace the hard drive.
Jul 22, 2011 | Acer Aspire 4730-4516 Notebook
Ntfs is missing
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows Vista startup disks or the Windows Vista CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows Vista installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows Vista CD, and drive is the drive where you installed Windows Vista .
  7. Remove the Windows Vista CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer.
  9. rate me 4 thumbs up please
Jan 10, 2011 | Microsoft Windows Vista Home Premium with...
Stack overflow at line 598
Stacks are reserved memory that programs use to process hardware events. A stack overflow occurs when there is not enough space in memory to run the hardware interrupt routines. To resolve these behaviors, you can modify the "STACKS=" line in the Config.sys file, eliminate terminate-and-stay-resident program (TSRs), and eliminate hardware conflicts.
When Windows delivers an error message that is related to an internal stack overflow, there is not enough space in memory either set aside or available to handle the calls that are made to the computer hardware. There are several things to consider when you troubleshoot this behavior:
  1. The Config.sys startup file may not be properly configured for the Windows installation. Use the following values: STACKS=64,512 ;(this is the maximum allowed)
    FILES=60
    BUFFERS=40 If you are using the dual-boot capabilities in Windows, the Config.sys and Autoexec.bat files may not contain the correct configuration to run Windows. When you are dual-booting between Windows 3.x and Windows, these files may not have been renamed back to Config.dos and Autoexec.dos.
    Examine the Config.sys file to determine if files such as Himem.sys or Emm386.exe are loaded from a folder other than the Windows folder. If so, boot Windows by using the Safe Mode Command Prompt Only option. Rename the Config.sys file to Config.dos and the Autoexec.bat file to Autoexec.dos, and then restart your computer.
  2. Some TSRs may be interfering with Windows. Disable any non-boot device drivers in the Config.sys and Autoexec.bat files. If you install from Windows 3.x and you receive a stack overflow error message, check the Win.ini and System.ini files for non-Windows-based programs or drivers that are loading.
  3. There may be an incompatible hardware configuration. Check the port and IRQ settings of the network adapter, sound card, and modem. Make sure that there are no COM2/COM4 or COM1/COM3 conflicts and that no devices are sharing IRQs. Disable or remove conflicting devices.
  4. The computer may need a BIOS upgrade. Check the BIOS version and contact the manufacturer of your computer for information about a BIOS upgrade.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 28, 2010 | Microsoft Computers & Internet
SM Bus Controller and Video Controller (VGA Compatible) drivers
You can download all Windows XP Home Edition drivers for the Intel D101GGC motherboard from Intel's web site at the following link:
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2229&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go!
May 15, 2009 | Intel D101GGC Motherboard
Problem starting my computer
sound like the internal bettery need to be replace.
do yo have dula boot machine? if not, then change the internal bettery.
Mar 17, 2009 | Microsoft Windows 98 for PC
Windows XP boots endless if SATA is set to AHCI
this is'nt so easy here an example solution:
Enabling SATA mode to AHCI after XP Install (applicable to most laptops, or systems) If you want to enable SATA mode as AHCI after installing Windows XP, then read on. It's a bit of a long read because of step-by-step instructions, but worth it.
I did this on on Acer Aspire 5315-2153, it seems like the basic strategy should work on other laptops or systems.
For whatever reason, you may have installed Windows XP on your new laptops with SATA Native Mode disabled in the BIOS. Once XP is installed, enabling it in the BIOS will result in a BSOD upon loading Windows because XP doesn't have the correct drivers.
I read that enabling SATA native mode will give you a slight performance inrease and slightly increased battery life, so it seems worthwhile to me smile.gif
Here's how I did it on a Acer Aspire 5315-2153 running Windows XP (32 Bit version):
- Download the Intel Matrix Storage Manager software from Intel (I think it's iata_enu.exe)or AHCI_Intel_v7.5.0.1017_XP.zip from Acer web site.
- Extract files from AHCI_Intel_v7.5.0.1017_XP.zip to e.g. C:\AHCI_Intel_v7_5_0_1017_XP files need: (you may delete the rest)
iaahci.cat
iaahci.inf
iastor.cat
iastor.inf
iastor.sys
TXTSSETUP.OEM
- Now go to Device Manager, under IDE ATA/ATAPI controllers you should
see: Intel 82801HEM/HBM SATA AHCI Storage Controller
- Right-Click on that and select Update Driver
- Say no to connecting to Windows Update to search, hit Next
- Select Install fro a list or specific location (Advanced), hit Next
- Select "Don't search. I will choose the driver to install", hit Next
- Select Have Disk
- Browse to C:\AHCI_Intel_v7_5_0_1017_XP and highlight the iastor.inf file, hit Open
- Select OK
- Now you should have a list of controllers, for the Acer 5315-2153 choose Intel 82801HEM/HBM SATA AHCI Storage Controller, hit Next
- You'll get warned that installing the device driver is not recommended, click Yes to continue installing
- Click Finish
- Click Yes to restart your computer
When your computer boots up, you need to hit F2 to enter the BIOS. Change SATA mode to AHCI, save changes and exit.
After you log into Windows, your computer will find the "new" hardware. Wait until you get the popup message to restart your computer, say Yes to restart one last time.
You may download also from Intel the RAID/AHCI Software - Intel® Matrix Storage Manager (iata70_enu.exe 5640KB) and install it in your system, it may fix in case you got the wrong Intel 82801 AHCI controller.
I give credit to Jamie Rybarczyk at HP Business Support Center forum for doing most of typing.
http://forum.notebookreview.com/showthread.php?t=186471
Jan 06, 2009 | Computers & Internet
Controller Driver Issue on Armada M700
I am running a Armada M700 with a Hitachi HTS541060G9AT00 60GB Hard Drive - Ultra ATA-100, 5400 RPM, 8MB. The driver that is loaded in mine is on both primary and secondary is atapi.sys. This driver is also installed on the Intel 82371AB/EB PCI Bus Master IDE Controller, along with intelide.sys. The main difference is I am running Window XP Pro SP2. But I believe that they should use the same driver.
Hope this helps.
dferguson64
Sep 09, 2008 | Compaq Armada M700 Notebook
Intel Desktop Board D815EEA2 (BOX815EEAA2) Motherboard Logo
71 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
