Question about Pioneer SD-643HD5 64" Rear Projection Television
Black levels off
My blacks have become increasingly grey and washed out in color. what can i do to get my black levels back?
    Problem Solver:
  • 7 Answers
My quick and easy solution was to clean the dust off the lenses of each CRT.
1) Unplug TV
2) Remove the back panel.
3) Wipe each of the three (plastic!) lenses lightly, with a lint-free microfiber lens cloth. Do not use anything that might scratch the plastic lenses.
Other than that, you'll need to hire someone to adjust your gray scale tracking.
Posted on Sep 30, 2008
I seem unable to get the black ink to work?? the grey and all the other colors are working but not the black?
there are only 4 colors in a printer one of which is black
grey is very light spray of black
to get the spectrum of colors one of the mix is black
check the printer head for black and is there enough black ink in the cartridge
Dec 24, 2015 | Epson Stylus Pro 9600 InkJet Printer
How do you fix the colour printing grey instead of black
Do you need to change out your black color cartridge? Check your ink levels to make sure that you have plenty of each color. Also, check the settings for your printer (perhaps under "properties") and make sure that you haven't clicked on "grey scale". I hope that this helps.
Jul 15, 2014 | Xerox Phaser 7400/N Printer
Clarion 9700RT (1990) car stereo. Color wiring codes for these wires: White, White w/black strip, grey, 2 green, 2 lavender the stereo is hooked up but just need to hook up wires!
Memory / Constant 12V(+) Yellow Switch / Accessory Red Ground Black Illumination Orange/White Antenna Remote Blue Amp Remote Blue/White Left Front (+) White Left Front (-) White/Black Right Front (+) Grey Right Front (-) Grey/Black Left Rear (+) Green Left Rear (-) Green/Black Right Rear (+) Violet Right Rear (-) Violet/Black
These are the common colors for the radio.
Thanks
-david
Nov 10, 2010 | Car Audio & Video
Colour codes for 83 corona, wiring stereo the colours are grey/black grey/red Brown Purple/green Grey Blue/yellow blue white/black any help would be great thanks!
Hello! I'm having a hard time reading your colors...So, I'll give you the 1983 Corona wiring...
POWER
Constant +12= Blue/Yellow Switched +12= Gray
Ground= Brown Antenna= Black/Red
Illumination= Green
SPEAKERS
FR+ Light Green
FR- Blue
FL+ Pink
FL- Purple
RR+ Red
RR- White
RL+ Black
RL- Yellow
Guru...........Saailer
May 30, 2010 | Pioneer AVH-P5700DVD Car DVD Player
My HP 3550 won't print black when it is out of a color.
restore the properties.... set as "print in grey scale" or "print color as b/w images"...
also if the print become less or more dark you can change the settings to print whit more intensity or less...
there is no necesary change all your documents as "watter ink" only change the print options to fade to black
May 15, 2010 | HP Color Laserjet 3550 Printer
Wire colors on source unit are incorrect need to know the order of color for a clarion drb4375. or a sample picture of colors from factory top and bottom.
Hello! TOP...RIGHT TO LEFT...Grey/Black...Grey...
Purple/Black...Purple/Blue (antenna)...Red (acc)
BOTTOM RIGHT TO LEFT...White/Black...White...
Green/Black...Green...Black (ground)...Yellow (constant 12)...Four blank...[Grey...White...Purple...Green]... speakers...
Guru.............Saailer
Apr 07, 2010 | Car Audio & Video
I HAVE A KENWOOD KRC-2007 CAR STEREO AND DON'T KNOW WHICH COLORED WIRE GOES TO THE LEFT AND RIGHT FRONT SPEAKERS, I THOUGHT IT WAS WHITE/WHITE BLACK AND GREY/GREY BLACK.
Hello! Front Right; + = Grey... - = Grey/White
Front Left= + = White... - = White/Black
You are correct...Perhaps you need the vehicle's colors?
If so send a comment with year, make and model...
Guru.....saailer
Feb 17, 2010 | Vehicle Parts & Accessories
How to cut clear hair in photoshop
Sounds like you want to make a hair mask. If your subject is on a simple back ground, go into your color channels and duplicate the one that is the darkest for the hair. Apply levels to darken even more and then fill in other non hair areas of the head and body with black. Get in close and remove any artifacting around the edges of the hair so it is clearly black and white, no grey or at least try not to have any grey.
Inverse the tones so the hair becomes white and the background black. Make a selection and use it to lift your subject off the background. If you have any fuzzy areas, you can lock the layer and clone hair into them and/or remove them with the eraser or use layer mask.
Jun 15, 2009 | Adobe Photoshop CS2 for PC
Trying to install an in dash stereo can't figure out the speakers
depends on what wires you need the back of the raidio will have white grey green purple white is front left grey is fr green is back left and purple is back right if your lookin for truck colors get a manual or check to make sure there are no hots or grounds with a meter and twist one of the speakers ground up and with the hot touch each wire til u get sound idenitfiy the speaker wire to corect chanel
Feb 18, 2009 | 1995 Nissan Quest
Pioneer SD-643HD5 64" Rear Projection Television Logo
43 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
