Question about Intel DX38BT Desktop Board (BLKDX38BT) Motherboard
DX38BT Hi. I purchase a motherboard dx38bt and a processor intel at 3 ghz. during the installation of windows, the motherboard start to come on and off 5 in 5 seconds indicating a the red light B, that means overheat of the processor. What happen with the motherboard? can y help me? thanks
  • demetriosilv Oct 02, 2008
    Yes. Everything. i install the thermal compound and also the case have more 3 fans around the processor.
  • danielkenobi Mar 11, 2009
    Hi I install everithing and everithing work fine, for arround 2 monts but sudenly the computer tun off and bothe leds a and b are lit when I connect de computer to the power suply and it doesnt turn on,
    Any ideas?
    Genius:
  • 1,066 Answers
Did you install the heatsink with thermal compound before installing windows?
Posted on Oct 01, 2008
Power hook up wire for DX38BT Motherboard
I don't really understand the question as it is stated. However, Systemax is constructed by Tiger Direct and they should be able toi answer your question pretty quick.
Sep 23, 2012 | Systemax Venture S519J (988868) PC Desktop
DX38BT motherboard wirer hook up.
http://www.intel.com/support/motherboards/desktop/dx38bt/sb/CS-028327.htm
Click on the blue - English Product Guide [ PDF ]
After you click on the above file name it may take up to 30 seconds, before the first page comes up.
Connecting to the Internal Headers
Page 50 for the PDF file page number. Figure 27. Internal Headers
The front of your computer is the Front panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
Item I in Figure 27.
Detailed connections on Page 54.
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 23, 2012 | Systemax Venture PC Desktop
Desktop shuts down with no video
This would seem to indicate that the RAM or motherboard does not work correctly with the settings that you set. There should be a jumper on the motherboard for BIOS reset. Also most newer systems will automatically detect a problem and reset to defaults after 3-5 failed boot attempts. The most likely reason for only seeing 4GB would either be that you have 32-bit version of Windows 7 or that one stick of RAM is bad. To see and use more than 4GB of RAM you need to have a 64 bit operating system.
Feb 17, 2012 | Intel DX38BT Desktop Board (BLKDX38BT)...
I just need to figure out what the socket type this motherboard has for the processor so that I can find what processors I can upgrade my computer with. It's a g45t/g43t AM 3 V: 1.1 motherboard made by...
The socket type of ACER G45T/G43T - AM3 V1.1 motherboard is LGA 775. Here are the compatible processors you can use for this motherboard :
Intel Pentium 4 (2.60 - 3.80 GHz)
Intel Celeron D (2.53 - 3.60 GHz )
Intel Pentium 4 Extreme Edition
(3.20 - 3.73 GHz)
Intel Pentium D (2.66 - 3.60 GHz)
Pentium Extreme Edition
(3.20 - 3.73 GHz)
Pentium Dual-Core (1.40 - 3.33 GHz)
Intel Core 2 Duo (1.60 - 3.33 GHz)
Intel Core 2 Extreme (2.66 - 3.20 GHz)
Intel Core 2 Quad (2.33 - 3.00 GHz)
Intel Xeon (1.86-3.40 GHz)
Intel Celeron (1.60 - 2.40 GHz)
Sep 13, 2011 | Computers & Internet
Installed new Intel E6500 (yes - this model is approved for the motherboard - yes new heat sync is cheap - yes there was no thermal paste but instead was a thermal pad) - it is installed fine (tight) but...
As you have installed a new component into your computer system, Windows is asking you to reload/reactivate Windows.
Do the following;
1.)Enter the BIOS/CMOS, by pressing the delete key/F12 key during start up.
2,)Find and select the option for loading default settings.
3.)Now Exit Saving changes.
Your computer will now boot on settings that it feels are appropriate, this may please Windows and get your computer system up and running again!
All the best!
damnor01
Dec 30, 2010 | Intel Pentium E6500 / .93 GHz processor...
Problem with DG31PR board while loading windows 2003 server.
check HDD and RAM, make sure your HDD new formated
Sep 03, 2009 | Intel DG31PR Motherboard
My computer won't start but power supply and Motherboard is okay
if i understand correctly you swapped the cpu to another computer and it did not work... you need to purchase or find another cpu that is compatable with your motherboard.
Robert
Aug 25, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Motherboard problem
1)first u check by single ram, if not
2)remove the graphic card and connect moniter to onboard VGA, if done
3)refer the manual and select the jumper pins as master for AGP ,now connect to graphic card
4)if no display
5)remove the graphic card and try in on board vga
6)now you cant get display remove the bios battery and clear the cmos by using jumper pin short (refer mother board board manual ).then try with both VGA output
(NOTE:-if AGP or PCIE card present on board VGA not functoning)
all the best keep trying -i hope you get working pc by half an hour,if not call to profesional servicemens
regards
prasanna
Mar 06, 2008 | Intel Motherboard
Video monitor
This means the monitor is not receiving a video signal
check your monitor connection or monitor cable for bent pins
thanks for rating
Jan 10, 2008 | Computers & Internet
Intel DX38BT Desktop Board (BLKDX38BT) Motherboard Logo
196 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
