Question about Arcsoft ShowBiz DVD 2 (3265)
I can trasfer video successfully but the the sound quality is really bad.
Ive swapped computers and even exchanged the program incase it was faulty but still having the same issue. ive tested the sound of the vhs and the cam corder and everything is working fine. it either records no sound at all or the quality is so bad its impossible to hear anything but noise. help please!!!!
Bought a computer two days ago bad quality need to upgrade exchange
Ask your supplier if they will accept it back. Mind you unless the item is damaged upon receipt or faulty they are not obliged to accept it.
Mar 10, 2015 | Acer Aspire Computers & Internet
Low quality bass and sound
contection sound like wired around the wrong way, try swapping positive and negitave on sub conections over, hope helps
Feb 17, 2012 | Kenwood Car Audio & Video
My hp pavilion will not power up, when i press the power button. the blue light around the power button simply flashes on and off, but there is no indication that anything is happening with the actual...
The fact that the power button is flashing when you push it shows that the computer is still receiving power, however if the computer does not boot then some hardware in the computer must be damaged or faulty. You will likely have to take it to a repair shop so they can figure out which piece of hardware is defective, although i suspect it is the motherboard.
Mar 14, 2011 | Computers & Internet
To convert avi to a format that takes less space dosnt afct quali
It really depends on what your using your footage for.
I prefer mpg3 myself mostly becuse its eaiser to trasfer to DVD.
Also most versatile playback for my needs.
You can get free MPG downloads online to convert.
Jan 28, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Sound is scratchy
Try to install video and audio codecs.
Best regards
Dec 25, 2008 | Dell Computers & Internet
Bad video quality help me plz
import the video into windows movie maker and select a better quality. it will take more discspace but it should look better.
May 23, 2008 | Ulead VideoStudio 9
Bad Video quality
Hi.
On the windows update failure for dot net 1.1 there is a way to edit the registry and set a value that tells windows update it was installed. I'll try to find that key and send it or post it back to you, I don't have it memorized.
Can't help you directly with the Ulead Studio, sorry. I would suggest you look over the program options for video playback quality in the program. As you stated, it looks fine in WMP but not in ULS, therefore it should be a property value for playback quality in the ULS program window.
Hope this helped you.
Worldvet
Faulty agp socket
You can use a PCI slot video card or the internal video if the motherboard has it. there are also ISA video cards (really old and cheap 1-3 dollars)available incase your board has those slots.
If the socket is faulty you could replace it, first of all make sure the pins on the agp slot are not touching or it might cause issues with the computer.
Apr 12, 2008 | Koss P4 Consumer Headphones
Problem: Green colour cast
Problem resolved by swapping the video cable, simple really!
Feb 13, 2008 | Sony VPL CS5 Multimedia Projector
Arcsoft ShowBiz DVD 2 (3265) Logo
123 people viewed this question
Top Arcsoft Computers & Internet Experts
Marvin
Marvin
George Etukudo
George Etukudo
Pierre Legault
Are you an Arcsoft Computer and Internet Expert? Answer questions, earn points and help others
