Question about Hayward 250kbtu Ng Pool Heater - Inground
Drain gas heater for winter
How do you drain a hayward H250 gas boiler
    Problem Solver:
  • 11 Answers
On the side of the heater, you will see the water connections. Directly underneath them, on that black component that they attach to, there is a drain plug of some description. It may be a draincock, or just a plug. In either case, simply open or remove it to safely drain your heater. In a pinch, you could also disconnect the water connections at those unions (the big grey connectors), but they can be fussy to reassemble, and you run the risk of losing the o-rings.
Posted on Jan 02, 2009
Hayward H250 pool heater will not light
see if pressure switch full voltage both sides or hi limits
Apr 26, 2013 | Hayward Pool Products Hayward H250 250k...
Hayward H250 has LO listed on the electronic panel after it had been blowing black soot out of it
check gas pressure heater overheated probably needs hi limits or fusible link plus clean heat exchange to solve
Oct 12, 2012 | Hayward H-series Electronic Gas Pool...
Hayward h250 ed2 failure error code IF
ignition failure check gas source if ok check ignitor
Aug 03, 2012 | Hayward H-series Electronic Gas Pool...
Remove high stack from Hayward H250 series pool heater
clean stack also check gas pressure sooting caused from low gas pressure plus overheating
May 25, 2012 | Hayward H250 High Wind Stack
Pf hayward error code on gas heater H250 IDPL1
check pressure switch if voltage both sides ok if not bad switch or clogged copper tube also check filters
Nov 16, 2011 | Hayward H-series Electronic Gas Pool...
I need to winterize my Hayward 300. Where the manual shows a drain valve there is a thick square bolt. I'm afraid to compromise it if it is not in fact a bolt.
That is the drain plug...underside of the inlet/outlet header. You should also break open the connection of the water tube to the pressure switch inside the heater to prevent the switch or tube from freeze damage.
John
Sep 20, 2011 | Hayward H-series Electronic Gas Pool...
I need to drain the boiler for winter shut down
There should be a drain valve/plug under the inlet/outlet header. Opening that should allow it to drain thoroughly. Depending on where you live, this should be done in conjunction with the rest of your pool winterization. All suction and return lines should be blown out and plugged as well as all equipment including pump and filter.
Oct 20, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
How do you winterize?
pull the three (or so) drain plugs in your heater ... use a shop vac (without the filter in it) to blow and then **** out any remaining water.
hopefully, your pressure and suction pipes lead away and down from the boiler. Make sure you **** out those pipes as well.
You know how to drain your filter(s) and pumps ... right?
I hope this helps you
a
Oct 05, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Hayward h250, wont heat
Sounds like it could be the flame sensor.
Apr 04, 2009 | Hayward H Series Electronic Ignition...
Hayward 250kbtu Ng Pool Heater - Inground Logo
292 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
