Question about Epson Perfection 1240U Flatbed Scanner
Epson scanner 1240U
I have used my scanner for years on my PC. I have tried to download drivers to use it on my Mac os x. the drivers download but I can't get it to work. I tried the software that came with the scanner originally and it says it is not supported. Any ideas?
  • needle3000 Feb 14, 2009
    This solution worked perfectly. Thanks for your help
Needle3000:  The Epson "Perfection" 1240U Scanner won't work with Mac OS X 10.4.11 possibly due to the program it is being run from. Like you, I had the same problem: it wasn't being recognized. Epson's drivers installed and ran correctly. Scanner even appeared under Bus in USB Device Tree in System Profile. Finally, I discovered that the Scanner runs if opened directly from EPSON Scan.app under Applications. The problem, in my case, was my ancient version of Photoshop (5.5.) from which I was running it.
 Hope that helps!
Posted on Dec 06, 2008
I have downloaded the scanner software for the canon CanoScan N670U more than once, but it is not opening or running on my mac.
This was a problem with Mac's and this scanner (are you using 10.3 OS)?
Try unplugging the scanner then replugging it in, sometimes after the mac sleeps and is woken, the scanner will not be recognised (happened on XP and Vista PC machines as well)
also try using image capture on the mac rather than the canoscan toolbox software.
If you want to give installing the drivers and software another go, download the software and driver remover tool from canon's site before re-installing
Jul 27, 2011 | Canon CanoScan N670U Flatbed Scanner
I have lost my driver software to install umax astra 2200.so how can i install the scanner on my mac os x 10.4.11
try using mac os 8.6-9.1 driver it is mac osx but older it might work
here is the umax link to softwarfe download
http://www.umax.com/download/index.jsp
select model 2200 and then mac os 8.6-9.1
May 20, 2011 | Umax Astra 2200 Flatbed Scanner
RE Canon scanner problem 'No driver found'. downloaded new updated software twice and got the same message. Using Apple Mac Os x (snow L.)
Pls disconnect the scanner, uninstall scanner driver and switch of the computer. After restarting, run Scan disk and then install appropriate driver for MAC OS and connect the scanner. This should work.
S. Mohan
Sep 21, 2010 | Canon CanoScan 4400F Flatbed Scanner
I'm trying to scan a photo from my HP700 onto my MacBook and I have the CD that came with my printer - but still can't do it. The Mac does not recognize the disk.
try downloading scanner driver compatible with mac os here. though unlikely, it is still possible the the cd inculded with your scanner does not have mac os compatible driver.
Mar 16, 2010 | Apple MacBook PC Notebook
Canon 9900f scanner not recognized by Adobe Photoshop
According to Canon it is not supported.
Issue: Does my product support Mac OS X 10.5 (Leopard)?
but here is a link to try.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=235&modelid=8743#DownloadDetailAct
Solution: Mac OS X 10.5 (Leopard) Compatibility information (Non-Compatible Scanners)
Mac OS X 10.5 (Leopard) Compatibility information (Non-Compatible Scanners) Unfortunately, the chosen scanner model is not supported with Mac OS X 10.5 (Leopard). For models that are supported, please see the information below.
Compatible Scanner Models Drivers to support Mac OS X 10.5 will be available for the below models. Visit the Canon download site for the most up to date versions of the product's drivers and software.
4400F
9950F
LiDE 70
8400F
LiDE 25
LiDE 90
8600F
LiDE 35
LiDE 500F
8800F
LiDE 60
LiDE 600F
  • Scanner models released after 2007 will be compatible unless otherwise noted.
  • For scanners missing from the list above, if it was released prior to 2007, then it will not be supported in Mac OS X 10.5 Leopard.
Aug 01, 2009 | Office Equipment & Supplies
Mustek 1200 ub plus driver for latest OS?
go to the mustek 1200 ub plus manufacturers web site and (download/support) and download vista or mac driver for your hardware.
Jul 01, 2009 | Mustek Plug-n-Scan 1200 UB Plus Flatbed...
Using on an Intel MAC machine???
It doesn't appear as though that scanner is supported under Mac OS X... No drivers are available anywhere, and it's not a popular enough brand for any to be included in the OS. Sorry! I had an older Canon scanner that wasn't recognized by anything in OSX, so I feel your pain!
Please rate this answer if you feel it has helped you!
May 11, 2009 | Office Equipment & Supplies
Update driver for UMAX Astra 2200 for Mac OS X
8.6 -9.1 is the lastest available.
Sorry, your scanner is too old for newer versions of MAC OS
http://umax.com/download/index.jsp
Nov 17, 2007 | Umax Astra 2200 Flatbed Scanner
Epson Perfection 1240U Flatbed Scanner Logo
428 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
