Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
Not Detected on PC
I have a Western Digital USB Hard drive Model WD1600U017-004 160 External Hard Drive. I used this for so many times, until such time it can't be detected in my PC or laptop. I checked on the device manager but the device is properly working but why is it the dive does not appear.
I need help ASAP. because my important files are there.
Hope to hear from you soon. Thanks.
Dads
  • 1 more comment
  • Anonymous Oct 29, 2008
    I too have the same problem. My driver is identified but I can not see it in the Disk manager
  • Anonymous Dec 15, 2008
    I've recently (after reconfiguring my computer by installing other hard drives and after installing WinXP Dark Edition instead of WinXP) got the same problem with my WD1600U017-004 when trying to use it on my computer, but the disk works perfectly on at least one other computer (strangely enough). But I haven't had time to try to fix it yet...
  • HCHW Dec 16, 2008
    Have the same problem of WD 3200 BEV connected to PC but prompted for formatting instead. Went to Disk Management only able to see Drive (F) without the WD labelled name. Right click to Open but cannot work. ABle to view properties only. Please advice.
    Thank you!
  • Western Digital Master
  • 787 Answers
Since you say that it is detected in Device Manager and is shown as working properly, it would appear that the problem is that it is not getting a drive letter. Have you added anything recently that might take up a drive letter like a flash drive? If so, try removing both and then plugging the WD back in. If this is not the case or does not help, do this:
Assuming you are using XP.
Right click on My Computer and select Manage
The computer Management window will open, click on Disk Management
Do you see the WD in the window on the right?
Does it show a drive letter?
If not, you can assign it one by right clicking on it and selecting Change Drive Letter and Paths ...
If the WD does not show up in Disk Management, possible problems are:
1) USB cable is damaged, try another one.
2) USB circuits in the WD case not working properly, hard drive can be removed and put into another case.
3) WD USB case is good, hard drive is good but there is a loose connection inside. Open case and reseat everything.
4) WD USB case is good but the hard drive inside has gone bad (worst case scenario)
Posted on Sep 27, 2008
HI I HAVE A WESTERN DIGITAL EXTERNAL HARD DRIVE AND CAN'T GET IT TO WORK ON MY PC I HAVE WINDOWS 7 CAN YOU HELP ME
Just check in device manager...whether is detected by the computer.
you can go to my computer...right click on it...then click on manage.
if its detected there then go device manager...then go to disk management under storage...right click on the drive there with no name then click on change drive name letter..hit ok,,check in my computer you will see the harddrive there...else if you don't see anything in device manager...contact the manufacturer.
Aug 18, 2011 | Western Digital 1TB WD ELEMENTS USB...
I HAD Western Digital My Book Essential 1TB External USB 2.0 Hard Drive ON M PC AND I CONECT WESTERN DIGITAL MY PASSPORT AND RUN THE AUTO FROM THIS SOMETHING LIKE WD SMART.... AND NOW MY Western Digital My...
Your WD HDD have been attacted by viruses for your computer or outside computer where you used it last. Make sure that you have an up to date antivirus software, scan your computer or the external hard drive, explore your computer, go to tools - folder options under view files & folders select show hidden files and folders apply and ok it.
May 18, 2011 | Western Digital My Book Essential 1TB...
My 360 GB WD drive isno more detected by PC. last time i used when i it, it was working. no dropping, no damage. light is on as usual but drive is not dteected by pc.
1.you may need to remove the hard drive from the original case and purchase a new case with good electronics.
2. check the USB cord to see if there is any damage.
3. use another USB cable to see if the hard disk is recognized by the Operating System ( my computer or "compute" in Windows 7.
Mar 17, 2011 | Western Digital External USB 2.0 80 GB...
My western digital hard drive is not been detected by any system. i tried many times. pls help me there are important datas in that
first change it's cable.
maybe it's cable got an internal cut.
if it doesn't work, you only can take it to a warranty center.
Jan 11, 2011 | Western Digital External USB 2.0 80 GB...
PC will not recognize the WD 750 drive. It shows in the device manager, it is detected with WD Lifeguard, but will not run any test, all fail. It is not detected by compmgmt.msc. It is over 1-year old and...
Most likely the drive is failing because it is in X-box format instead of a recognized PC format. Your most likely going to have to Partition the drive again and reformat it using a standard format.
Jul 22, 2010 | Western Digital My Book Essential Edition...
I've put a new Western Digital Hard Drive in Today But it wont boot up,
if it is an external drive go to Bios and turn the usb emulation to no boot
if it is an internal drive check if is detected
Nov 05, 2009 | Western Digital My Book Essential Edition...
My external hard drive cannot be detected in some pc's
use proper drivers as recomended,you nust have the cd rom that comes by default with drive you have
Sep 03, 2009 | Western Digital Elements powered by WD 320...
My western digital Passport 320Gb usb drive is not detected
hi ,
looks like u primary hard drive is inside the laptop and so should be displayed as c : drive ,
and the reason , the external hard drive is not displayed seperately is csue ., the external HD  may be added as slave to the internal HD .,
can u tell me ,make a right click on c:/ drive and choose properties : and tell the totalsize dispalyed
Jul 23, 2009 | Western Digital Passport WDXML800UE...
New external Hard drive
Open up My Computer and see if there is a new hard drive listed there. It should be automatically detected by your computer, you just need to know where to find it.
Feb 23, 2009 | Western Digital My Book Essential 1TB...
Laptop usb hard disk
I've had this problem many times with external SATA hard drive plugged into the usb. My 120gig hard drive takes significant power to operate it. On laptops with a long cable to the usb, I get the Tick tick tick sound and the light flash in concert with the ticking. On laptops with short cables to the usb, the hard drive works. On one desk top, the hard drive doesn't work on the front usb but does on the rear because the rear has no cables. The usb comes off the motherboard. Conclusion? Most likely a voltage problem from longer than usual cables from the motherboard to the usb. One solution is plug the hard drive in the rear usb. Another solution is buy a more expensive cable linking the hard drive to the usb. Or buy a shorter cable. More expensive cable may have thicker wires that won't resist the current. But I do not believe for a minute that the hard drive is faulty. I've seen it too many times and it has never been a faulty hard drive.
Sep 15, 2007 | Western Digital 320GB MyBook External USB...
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
3,663 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
