Question about Welding Tools
Thermal dynamics cutmaster 50 2004 yr.
Will not arc, operates as it always did , air set at 70 lbs, air kicks in upon depressing trigger and normally arc begins in about 5 seconds,but now it doesn"t. ckecked ground with meter, contact all the way.incoming voltage checked on both legs coming in,220 v single phase.took torch apart, ohmed out wiring checked good no breaks in torch lead.220 going to primary coil,pulled trigger checked output voltage to torch 16 volts.when torch should kick in two red leds come on on logic board. ? is there a thermal protection overload on these machines and where? can it be reset.fuses checked good
  • Anonymous Nov 09, 2008
    I have a Firepower 25 with the same problem, when trigger is applied air comes out but no arc
  • tdodds Feb 02, 2009
    I have a Hobart 400 (same as Miller 375 unit) that has a similar problem. When the trigger is pushed there is a short power surge and the the power lamp starts flashing and no plasma. Have to reset the power switch to try again. Looked inside the unit - no burned components.
Check contacts in tip and be sure it is all lubed correctly. If you have good air pressure and flow it should arc after pulling the trigger for about 2-3 seconds.
Posted on Nov 10, 2008
Keeps repeating itself
Most nailers have a two position setting on the trigger to allow for single fire or bump fire. If set on bump fire, the gun will work better when you bump fire the gun instead of placing the gun on the work then depress trigger. Bump fire works best when safety spring has good tension. Easy test. Make sure that the safety spring is in place (with air hose removed, contact foot should spring back quickly when pushed against work). With air connected, hold trigger and quickly bounce the gun against the work. If the gun does not fire when you bump, the trigger is most likely set to single fire. With trigger set to single fire, you must place the gun against the work, then depress trigger. If the gun shoots two nails while set to single fire, most likely worn trigger or worn out trigger valve. These parts are not expensive and are easy to replace. Good luck
Apr 12, 2013 | Dewalt D51321 3/4" 1 3/4" Heavy Duty Coil...
E3 error on LIfesmart heater
Even after replacing thermostat and motherboard offered from company, my heater would trigger e3 error code and shut off. After several (maybe 100!) different attempts to plug in and operate, here is what worked for me!
Depress the power button on the heater while plugging in to wall circuit. Continuously depress power button. It will run through a test cycle and attempt to start. Keep depressing the power button as the heater tries to start, then shuts down with e3 error. While the power button is still depressed, unplug the unit from the wall. When I plug back in the wall the E3 error is gone. Good luck
Nov 03, 2012 | Lifesmart DYNAMIC 1000 to 1100 Square Foot...
Thermal Dynamics cutmaster 81. when turned on it cycles blowing air but no arc. two green lights are flashing. pulling the trigger doesn't do anything, air keeps cycling
Hi; Check the following troubleshoot and see if you can ID the problem:
Problem: Gas flows continuously when power is turned on, AC indicator flashes 1. Torch switch is activated (closed) before user turns power on. a. Release torch switch. 2. Faulty torch switch a. Check torch switch for continuity. Replace if necessary.
Problem: Gas flows continuously; Torch will not pilot when torch switch is activated; AC indicator ON 1. System is in SET mode a. Change to RUN / Rapid Auto Restart / SET switch to RUN (up).
Mostly of the problems found is that customer has the switch line on to SET instead of RUN.
Hope this help. Have a good afternoon.
Sep 16, 2011 | Welding Tools
Thermal Dynamics Drag Gun Pac 10, Push Trigger, Labored Sound, Cuts Off and wont cut or flash arc. Cleaned Air Filter allways, All New Consummables, Allways kept clean, Has a rattle when trigger pressed...
Hi:
Your plasma has a start arc pilot inside the machine, this one must be faulty, check your owner's manual and request the part to your nearest welding store. It is easy to replace.
Jun 21, 2011 | Welding Tools
My Thermal Dynamic Drag Gun Plasma Cutter runs but cant blow its arc. Bit of spark, Bit of air, then just refuses to blow its arc. Was working well and with new tips and electrodes but then just refused....
Hi:
There is no mention of the Thermal Dynamic's gun model, but i will suppose that it is a SL60 or a SL100 which are replacement guns for any model of plasma using the proper adaptor.
Your problem could be the start cartridge which go bad now and then when the gun is used as a replacement of a hammer to make the cut piece to fall.
The way to check if your start cartridge is in good condition is by checking the low part of the cartridge, push it up (or down depending on the way you handle it) it should freely slide inside and return out.
Good luck.
Jun 16, 2011 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
The exclamation point, the red dot, keeps popping up and it is also red on 85-5.9 and only air is blowing out
Try and replace the swirl ring. We had the same problem and it fixed it. They cost around 35 bucks
Dec 10, 2010 | RTO THERMAL DYNAMICS CUTMASTER 52 PLASMA...
Plazma cutter/no arc
check pilot/output board
Sep 05, 2009 | Welding Tools
Welding Tools Logo
1,850 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
