Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Australian model 6ED25DQXFW00... motor runs too often
Our Whirlpool Gold appears to be working okay but the motor is running far too often. The seals appear okay.
Please let me know if there anything else that could cause the machine to run so often as our electricity bill keeps soring. Any advice would be appreciated.
dansie97@yahoo.com
  • dansie97 Sep 27, 2008
    Many thanks for the advice I will see if this helps. Much appreciated!
  • dansie97 Sep 28, 2008
    I cleaned the coils but it hasn't made any difference. I am now wondering if perhaps over time the coils or something/somewhere else may perish and develop a leak.
  • 943 Answers
Hi thanks for the question i would pull fridge from wall and clean the coils at the back try this clean coils very important thanks the appliance doc
Posted on Sep 27, 2008
  • john gagnon
    john gagnon Sep 27, 2008
    hi thanks hope it works for you could you rate my answer thanks the appliance doc
My "Whirlpool Gold" Refrigerator's interior water dispenser was dripping pretty badly. I just replaced the inlet valve and the drip is MUCH slower but it's still there (1 drip every ~10 minutes). Wha
Perhaps some air bubbles were trapped in the water line during the repair. Try running water thru the line for a good amount of time and that may help to relieve the line of any air bubbles.
Jan 26, 2015 | Whirlpool Gold Series GB2SHTXTS (219 cu...
Whirlpool gold
did you try cutting the power at the household breaker box and rebooting it. try the manufacturer customer service number, they have technicians you can ask sometimes if you're nice.
Aug 27, 2012 | Whirlpool Gold GU2275XTV Builtin...
Chris@crimmen.co.ukHi my Whirlpool gold fridge freezer is working well but has started tripping the electrics in the house each time it is switched on and the motor strarts - can you help please? Chris
its either the ptc overload on the compressor body or the start winding on the compressor itself,you will need to have a person with a clamp-probe check the starting/running currents and see how large a current this unit draws at start-up and run,then if too high a draw,its probably a bad compressor motor winding
Apr 08, 2011 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
I have a Whirlpool Gold GD22DFXFW02 side by side fridge/freexer with ice maker and water dispenser. Besides the fact that the water dispenses very slowly, the ice maker has stopped making ice. It appears...
Sorry to read about your problem, I hope this helps you out.
yes no water to the unit
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Whirlpool Refrigerators
The compressor fan not properly working.
You need to replace the fan. It doesn't use an external starter. Part 24 on this diagram is your motor. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=502485&diagram_id=124933#d124933
May 13, 2010 | Whirlpool Gold® GC5SHEXNQ
Coil is freezing up
two options...one drain hole blocked in freezer,clean with copper wire/bleach to clear gunge.
two outside temp too cold i.e. unit in garage/outhouse( too cold for compressor )
also check seal to doors.air leaks...
Feb 06, 2010 | Whirlpool GB9SHDXPS Stainless Steel Bottom...
Whirlpool Gold Dishwasher leaking from behind door
could be water getting behind the lug that holds the dishwasher in place , I used some silicon sealant over the top and the dripping stopped
Oct 18, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool Gold model GU1200 will not start wash cycle
FYI, for anyone else with the same symptoms. I took mine apart and found that the seal on the motor shaft failed and over time corroded the motor shaft bearing causing it to failed. I ordered full motor assembly from the parts store.
Oct 09, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
132 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
