Question about ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth...
Audio in not work
Audio out works fine , but audio in not work , mixer for inputs (aux,mic,cd) ,are blocked (windows mixer) , in realtek mixer I don't have buttons . I installed drivers from motherboard cd , I tryed new drivers from asus site , I change the motherboard with another , same type , I think it's a hardware problem , but no effects . ASUS P5GC-MX/1333,ram 2G,Pentium Dual-Core E2180
  • jeredtate Oct 07, 2008
    I have the exact same problem. I have connected everything correctly but still my audio in does not work. I used to not have sound come out from the front of the case but then I changed the front audio bias to be realtek 97 because my case was not hd wired. But the audio in has never worked it says something is plugged in but still nothing. I have checked the wireing the connections reinstalled the drivers several times but still nothing.
  • Anonymous Nov 23, 2008
    I have an asus motherboard and the inputs for sound never worked, I reinstalled all the manufacture drivers with a clean install of XP Pro, did all the updates even flashed the Bios update successfully, but all that did not fix the sound inputs...anyone have a suggestion?
When I update my realtek audio driver my headphone/mic audio jack stops working
you may have to set your audio input/output device back to the jack
May 10, 2012 | Dell Inspiron N5030 Notebook
The mute button cuts the main audio but the effects audio is still heard. What to do?
That's basically normal actually...however it depends on which aux send you're using. If you use aux 1 for the effects, you can use the pre/post switch on the master aux 1 send to switch it to pst fader....now your mute switch should kill the effects as well. Aux 2 is good to use for monitors where you don't need to return them to the mixer.
Mar 25, 2012 | Mackie 1202vlz3 12 Channel Mixer
Realtek sound card front input mic/headphone not working
1. You will have to check *********** board layout for the connector that activates the front input for the sound card then check the mixer to activate the port.
Jun 17, 2010 | Computers & Internet
Suddenly MIC port is not working...
go to volume control option and select mic advace option and choose microphone boost option and try.
Jan 20, 2010 | Gigabyte GA-K8VM800M Motherboard
Sound from one speaker with mic plugged in.
Hi I am Vortash it sounds to me that this is linked to the realtek program off shutting off the speakers when the earphones are attatched , it is confusing the Mic plug on one channel as a speaker plug .. check in the advanced section of your mixer settings that you have not got the box ticked that says treat all inputs the same .. and the other that says mute rear when front plugged in ? as does mine .. ( same system that was my problem yours may be diffrent ) if this fails uninstall your realtek drivers and uncheck the realtek devices in device manager unistall them and rebboot the computer installing new drivers .. hope this helps regards Vortash
Jul 21, 2009 | Philips HP-170 Headphones
Get sound through a Behringer 1204FX mixer & FCA202 interface
Block diagram available here:
http://www.behringerdownload.de/XENYX_GRP2/1204FX_VIEW_Rev_A.pdf
Where are the trim controls set?
Those mics use both phantom and battery power; are the mic switches set to phantom?
Try using the CD/Tape outputs to the FCA202
Nov 20, 2008 | Behringer F-CONTROL AUDIO FCA202 External...
Tape loop
You may need to purchase a cheap external mixer with both mic and line inputs, and use that to mix the mic with the DVD audio. In most receivers, you can only select one input at a time. The output of the mixer can then be plugged into any spare receiver input, such as AUX, CD, DVD, etc. When not using Karaoke, you can simply turn the mic input down to prevent it from interfering with the DVD signal, but will still need to have the mixer on to hear DVD's.
Jun 26, 2008 | Onkyo TX-DS797 Receiver
Realtek HD Audio Troubleshhooting?
I had the same problem with both my Biostar 550 and Gigabyte P35 motherboards, both of which use Realtek ALC888 HD audio. Its got lots of fancy eq and effects but a crippled record mixer with greyed out sliders. I emailed realtek and they responded that its a Mixer Record type audio mixer only and follows microsofts HD audio specification...so blame microsoft or Realtek...or both. There is NO workaround for this.
The solution is to use a sound card with AC97 audio or if youre lucky enough to find a newer one with HD audio and a less crippled mixer. Problem being the industry seems to have embraced Realtek who seems fixated on offering partially disabled mixers. I purchased a Diamond Xtreme 7.1 sound card from officmax for 30 bux. They also have a 5.1 version for 20 bux. The main rec output is set to a fixed level but the individual rec. sliders ARE enabled. Recorded audio ends up being about 10db low but you can always boost it n post production using a recording program like audacity (which the sound card comes with - there are newer versions of audacity available so dont use the included version). - The only way to get FULL functionality
- ALL sliders is to find an older AC97 audio card. There are good ones and bad ones so it may take a few. Try the Diamond Xtreme card first and if you dont like it you can always take it back. This link is for the $30 verson. http://www.officemax.com/omax/catalog/sku.jsp?skuId=21080508&searchString=diamond%20xtreme&category_Id=null
Dont hesitate to send Realtek a "concerned" (not nasty) email about this. Hopefully If they get enough...they MAY take it seriously...but I wouldnt cross my fingers.
Good luck,
Dave
May 21, 2008 | Microsoft Windows XP Professional With...
Audio Input Problems
buy a creative sound pcmcia card with stereo inputs...it runs aboout 50 bux at compusa...another solution would be usb audio input, they are also available at compusa,tigefr direct...i hope this helps...
Jul 29, 2007 | HP Compaq nc6220 Notebook
ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth... Logo
145 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
