Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman 16 hp 42 in. riding mower won't run when clutch is released
I recently replaced two of the blades on the mower. It will crank but when I release the clutch it dies.
If the engine feels like it is being choked, then something might be catching or bound up...for example the blades may have been installed improperly and will not rotate. Make sure that you can rotate the blades by hand...if not they may have been tightened and are binding against the mower housing.
If there is no engine choking...then it may be electrical for example a bad fault switch...take it to your mower shop.
good luck
Posted on Oct 06, 2008
2 Suggested Answers
SOURCE: I have a 15.5 HP Sears Craftsman 42
I'm betting that you need a new safety kill switch - probably the one underneath the seat (the spring-loaded plunger switch that won't let you use the machine without your *** in the seat). Could also be the one behind the "dash" that is associated with the blade engagement mechanism.
I know that the under-seat-switch cannot be bypassed or it will disable the machine in the exact way that you described. Why do I say this? Because I just tried to bypass my own "***-in-the-seat-safety-switch" on my very own 15.5 HP, 42" Sears tractor, and it responded by punishing me - the absense of the switch caused the motor to cut out when I tried to put the machine in gear AND/OR engage the blade. It seems to have some measured capacitance - the absense of same seeming to interrupt the ignition timing enough to shut the motor down when you attempt to get anywhere past neutral or engage the blade. These "safety" switches may be needed by a very few who prefer to be drunk while they mow lawns on steep slopes that their tractor mowers were not designed for, but I find these items to be troublesome and enfuriating. My trees shed a lot of sticks in high winds, and I can't stand shutting the machine down and restarting it EVERY SINGLE TIME I have to dismount to clear sticks or other obstructions out of my mowing path. This is an obnoxious, "nanny-design" feature that desparately needs to be discontinued. It also makes both jump-starting the tractor and electrical troubleshooting much more difficult than they should be. The tractor should let you dismount without shutting down, as long as you have disengaged the blade and shifted into neutral. It should also let you jump start with jumper cables - impossible to do with your rear end in the seat. By the way, call Manufacturer's Supply, Inc. at 1-800-826-8563. They may have a replacement - their item number 31-9664 might do it, but talk to them first. I'm calling them tomorrow. Good luck.
Posted on May 17, 2010
Testimonial: "VERY THOROUGH - THANKS"
What would cause a heavy vibration on my craftman riding mower, not caused from the deck, but by the v-drive belt for the tractor. i replaced it and without even putting the mower deck back on the vi
You did not finish the statement about without the blades but if your saying what I thing you are...Ah Oh Sounds like you may have a bent crank..Did you hit something with the blades...take the belt off and start the motor..and Check for wobble of the V drive there should be NONE if it does it could be bent itself or the crank...good luck
Jun 16, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My sears craftsman riding mower will crank just fine, but as soon as I try to either put it in gear and release the clutch to go forward or backward, it shuts off. It also shuts off when I attempt to...
Many folks have found that a defective relay in this mower to be the cause of the "stall when i take my foot off the clutch" issue. The relay is connected to the safety switches which turn the mower off when no one is in the seat, etc.
Aug 24, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
16 hp craftsman mower will not run when I release the brake?
does the engine run until you release the brake? if so look at the seat switch it is supposed to kill the engine if you get off with the mower in gear.
Jul 06, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Blades won't spin on Craftsman II riding mower
get some one to sit on it and holding the brake try engaging the clutch...now with out getting to close laying down you can see if the linkage is working right....might just be a missed belt wheel.
Jun 24, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Jun 01, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Craftsman riding lawn mower...engine dies when blade is engaged
Push the clutch all the way down and try to start, does it crank over?
Let me know.
Regards,
May 10, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Clutch issues: release clutch and mower doesnt move.
"....I just took off the right rear tire to replace."
Make sure the key hasnt fallen out of the right rear tire. It has to have the key to work. Its a peice of metal about 3 inches long and flat on all sides. It should slip into the grove on the tires shaft. Hope that helps.
Apr 14, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have 16 hp Craftsman riding mower with a Kohler engine.
It may think you are in reverse and is killing the motor to keep you from backing up with the blade running. Look for switch that is telling it when you are in reverse, maybe it is stuck with grass or other debris. another possibility is that the blades are jammed and they are stalliing the motor. Mines stalls easily when cold.
Mar 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
304 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
