My hitachi 52 inch tv wont turn on. when you push the power button the lights start to blink for the temp. power and lamp. it squeaks for a second and then the lamp light stays on (red)
  • 18 Answers
SOURCE: Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Posted on Jan 05, 2008
centralhigh
  • 260 Answers
SOURCE: When I turn the tv
This is a frustrating problem and is not uncomon. The problem is you will most likely have to have someone come out to complete internal repairs.
However, before you call someone out, try unplugging the television for an hour and plugging it back in. The tv is run by a mini computer. the computer sometimes goes into "safe mode" when the power fluctuates. This can be reset by unplugging from the wall for an hour. You will know your tv has reset when the tv has to reprogram the channels when you plug it back in.
If that does not work, try our premium service or go to our repair service button on FixYa.
CH
Posted on Jul 29, 2008
ginko
  • 19396 Answers
SOURCE: tv will not stay on
If the lamp light is not on, then the TV is flashing because of overheating or because of a fault.
Try first unplugging the TV and leaving it unplugged overnight, this will drain power completely and may solve some problem.
If the TV keeps having a problem, then there is a fault.
Many units have more than one fan (one for lamp, one on ballast, one on board). In that case ensure that all fans are working.
If the problem is not a fan, then parts can cause the problem are ballast board and DMD board.
In that case the parts must be tested before replacement.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here, a common fault is PSU, but part must be tested before replacement.
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts.
Posted on May 16, 2009
  • 101 Answers
SOURCE: We have a 50 inch Hitachi tv. Last night when we
Probably needs the bulb replaced. Look in your manual for a bulb replacement number, surf the net, there is a lot out there to choose from. But.... make sure you buy a original hitachi replacement bulb. Hope this is helpful.
Posted on Nov 06, 2009
ladywinn
  • 5138 Answers
SOURCE: the temp and lamp light start blinking when i turn
CK the Lamp Fan to see if it is running ,If you are still running the orignal Lamp then replace it . Mats has them for $99.00
1-800-628-1118
Posted on Jul 10, 2010
The temp and lamp light start blinking when i turn on the tv and the screen is black and the lamp light stays on hitachi i think it is a 55 inch model # 55vs69a
1-800-628-1118
Jul 10, 2010 | Hitachi 55VS69 55" Projection HDTV
My 50 inch Hitachi plasma 1080 tv has a blinking blue light and screen is blank when powered on.
my hatachi hd/1080 tv has a solid blue light on and it wont turn on i push the reset button on the bottom right and it still wont turn on
Mar 27, 2010 | Hitachi P50H401 50 in. Plasma HDTV
Hitachi Ultravision 50in will power on but no picture or sound!!!
Replace Ballast Board it is what turns Lamp on! Call Encompass for Part 1-800-638-3328
Sep 26, 2009 | HP Pavilion MD5020N 50" DLP HDTV
I have a 55 inch Hitachi HDTV it is around 3 years old. as of yesterday it was working fine and today it will not turn on. when i press power button i get a buzzing noise and it sounds like it wants to...
If you hear the Lamp fan turn, it is probably the lamp it self that has failed. If you do not hear the lamp fan turn then the fan could be bad or binding.
Hope this helps,
Skyassoc
Jun 28, 2009 | Televison & Video
TV won't turn on after lamp was replaced
Check the switch on the lamp door. Listen for the color wheel to spin. if the door switch is bad the lamp wont come on, samething if the color wheel is bad.
Jun 16, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
TH ETV TURN OFF ITSELF
the cooling fan could be going out
Dec 13, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
TV Won't Come On...
My Hitachi Model 50V500 led's ligths temperature and lamp blink when power is turn on.Have no picture or sound, followed the reconmended procedure disconnected power
for 30 seconds and reconnected.
Mar 18, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Dec 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Tv wont turn on
Had the same problem. turned out to be the power supply to the DM assembly. Had to put a power supply, board and a new lamp in. Tech said the lamp blew out the power supply and board. I think it's just a lemon.
Oct 08, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
Electro Med Services...
