Still trying to access control panel on maytag washer atlantis
After removing the 3 screws in the back, what else to do? the outside still seems attached. do i pull it a certain way like toward the front of the machine? also, do i need to pull off the timer knob in front - can't seem to do that either..
  • 1 more comment
  • zexp Sep 28, 2008
    thank you. but i am not sure i understand - have little experience with appliances. what do you mean the knob clips off? i've tried to pull it straight off, but it doesn't come off.
    the problem is that none of the cycles drain and spin down on the last of any cycle. at the end there is water. it will drain and spin if a spin is selected from a different cycle.
    for example: if on perm press, water is left at the end. if select either white or delicate spin, it will drain and spin down. if perm press spin - no change.
    if a white cycle is done, again the last drain and spin doesn't happen. if select either perm press or delicate spin, it will then drain and spin. but will not if white spin is selected.
    everything else is fine. no strange noises, etc. from what i've read online, the timer is the problem.
  • zexp Sep 28, 2008
    thanks, but the drain is not blocked.
    can you please explain how to take the knob off?
  • john gagnon
    john gagnon May 11, 2010
    hi yes you have to remove the very front of the knob clips off then you can remove the rest of knob but why do you want to replace the timer what is the original problem
  • 943 Answers
Hi. i think you have a drain problem .not the timer . i would check the drain lines. i am sure that's where you will find a blockage. try that.
Posted on Sep 28, 2008
How do I take the top off of the Maytag Atlantis dryer?
they are called baffles. and can only be accessed by getting to the outside of the drum. have to remove the body but u may have a bad baffle if the screw hole is busted up?
Sep 14, 2014 | Maytag Atlantis MDE7400AY Electric Dryer
I have a Maytag Atlantis Dryer Model MDE6400AYW - it is making a loud screeching noise which seems to be coming from the rear of the dryer. I have unplugged it and removed all the lint from every possible...
If you remove the screws from the lint trap shute, unscrew the 2 screws on the back side of the control panel, on the outer back, and take a flathead screwdrivew or putty knife to the front corners of the lid, you can pop the tabs and lift the top to remove the front of the dryer, to access the drum and motor.
Apr 10, 2011 | Dryers
How to I get to the drum? The fins in the drom have come unscrewed and fallen off. I need to get to the outside of the drum and screw them back on.
Access to the outside of the drum requires the removal of the front then the top panel. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top panel is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top panel lip.
Open the door then lift the front of the top panel and tilt it toward the rear of the dryer.
Rotate the drum until the screw holes appear at the top of the drum and screw the baffles back into position.
Reinstall the top panel and the front panel by following the removal steps in reverse order.
Note: This guide is for Maytag Sloped-Front Dryers.
Apr 19, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
My Maytag Atlantis washer stopped working after moving?
maybe the hose came off the water level switch,,,just remove the screws in each end of the control panel,,some machines you have to remove the panel end caps to get to the screws,,,,then pull slightly forward and flip the panel back to access the level switch,,,,,,my hose came off 1 time and flooded the kitchen lol,,,,but air pressure coming through the clear plastic hose kicks off the water coming in and allows the timer to move forward to next cycle!
Apr 17, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis top loader washing machine won't spin out water. it spins but the water doesn't go out. it's only about 5 years old. help please!!!
The drain hose is plugged or kinked or the drain pump is not working. Check and clear the drain hose from any debris that might be causing the water not to be pumped out. After checking and clearing the drain hose and the water is still not pumped out of the washer, check the pump to see if the impeller is good or the pump needs to be replaced. Access to the pump requires the top cover and the front panel to be removed. Disconnect power to the washer prior to servicing to avoid the risk of electric shock.
The top cover is attached to the front panel by two clips positioned at about 3 inches from the corners. Use a putty knife and insert the blade into the seam between the top cover and the front panel assembly at the position of the clips.
Push the putty knife blade against the clips, one side at a time while lifting the cover to disengage the clips. Lift the top cover off the front panel then remove the two screws securing the front panel to the upper front corner braces of the cabinet.
Lean the top edge of the front panel away from the cabinet and lift the panel to disengage its bottom from the base clips. Move the front panel away from the cabinet to access the pump.
Disconnect the pump inlet and outlet hoses from the pump then remove the three screws mounting the pump assembly to the base of the washer.
Slide the pump to the rear of the washer to disengage the belt from the pump pulley and pull the pump assembly out of the washer.
Clear the pump inlet and outlet hoses for any debris to ensure water is not blocked from being pumped out of the washer.
Check the impeller. Remove the four screws securing the pump housing to the pump base then lift the housing off the base. Clean the impeller and the pump housing; replace the pump assembly if the impeller is damaged.
To replace the pump, set the pump pulley into the base opening and put the belt on the pulley. Install the mounting screws while holding tension on the belt to keep it on the pulleys.
Connect the pump inlet and outlet hoses and secure it with the clamps.
Position the bottom of the front panel back into the base clips then secure the top to the upper front corner braces of the cabinet with the two securing screws.
Push the top cover down into position to the front panel to complete the procedure.
Note: For Maytag Atlantis MAV8000A, the pump assembly is part number 35-6465.
Mar 22, 2010 | Maytag Atlantis MAV8000
I NEED INTO GET INTO THE TOP OF THE WASHER TO REPLACE THE OPEN LID KILL SWITCH
You should be able to remove / open the top control panel (rear top) screws and tip it out forward to gain access to the lid switch. Be careful of the small air line that goes to the pressure switch. If that comes unhooked your machine will over fill.
Jan 12, 2010 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6451 - The machine buzzed and stopped. Now it wont run. Dont think its the lid switch
does it fill with water?
Does it not do anything after it fills?
If this is the case than it is most definitely the lid switch.
I recently had the exact same problem. Easy fix if you are handy.
Remove back of control panel to access the mounting screws. this will give you hand access to the lid switch. Try manually activating it after letting it fill. Replace switch or repair if able.
Good luck
Sep 30, 2009 | Maytag Atlantis MAV6451 Top Load Washer
How do I remove gravel underneath washer tub?
To access the washer:
  1. Use a putty knife about an inch wide.
  2. Push the putty knife on the sides to release the top panel and lid clips.
  3. Lift the top panel back towards the wall.
  4. Tape the lid so it does not fall back and chip.
  5. Remove the two 5/16 inch screws on the inside of the front panel. The top of the front panel will come towards you.
  6. Lift the front panel off the clips on the bottom and set aside.
  7. Pull the washer out from the wall and lift up the front to access the belt. Support it with a block of wood.
Aug 23, 2009 | Maytag Atlantis MAV6000 Top Load Washer
I need to replace the timer on my maytag atlantis mav7600awq, but can't figure out how to access the control panel.
hi thanks for the question you will see 3 or 4 screws at the top of console remove these screws first disconnect power supply now you will be able to see the timer if you need more assistance i will be here thanks the appliance doc
Sep 27, 2008 | Maytag Washing Machines
Timer on maytag washer
this is a good one! dependable care unit made in my home town.
http://www.servicematters.com/maytag_library/docs/16010373%20(16001145).pdf
insert flat blade under center plastic clip in the center if timer knob , you will find a little clip and sping here , then remove two 5/16 screws , then remove two phillips screws on control panel , you should see 4 ,2 on each side remove the inside 2 then tilt panel forward unplug timer. so easy
May 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Open Questions:
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
