Question about Brother DCP 115C All-In-One InkJet Printer
Scanning Old Pictures
How do I scan old photo's to print to A4 size ??
Hi ,
I did not solve the problem , and my printer/scanner is the DCP 117C . Anyway the there was no error in the machine , it is I who does not now how it is done ! .
Thank you for you reply .
Maur 1
Posted on Sep 28, 2008
Scanning negatives to positive
For scanning NEGATIVE typically use special accessories and are not available for all scanner models
Apr 04, 2014 | HP PhotoSmart Office Equipment & Supplies
Can I scan legal size paper with the Canon MP 240
Hi
You can scan the largest size of paper that will fit on the glass area of the scanner (the platten).
If your legal paper fits in this area or, at least the text printed on it fits well within the borders of platten, then you can scan it.
Your scan will show you a preview of the image scanned so you can see if all the text has been scanned from the original document before you save the scanned image on the computer or copy print it.
Legal Paper Size is: 8.5" x 14" (216mm x 356mm)
A4 Paper Size is: 210mm x 297mm
Letter Paper Size is: (8.5" x 11") 216mm X 279mm
This printer's Scanning Width is: A4/Letter
This printer's Scanning Length is: A4/Letter
I hope this helps.
Aug 28, 2011 | Canon PIXMA MP240 All-In-One InkJet...
How do you scan?
Open the Applications folder on the hard disk on which MP Navigator is installed, then open the Canon Utilities folder and double-click the navicon.gif MP Navigator 3.0 icon. MP Navigator opens.
2. Point to Scan/Import and click 'Photos/Documents (Platen)'.
3. Place the document face-down on the platen glass, and select 'Document Type'.
How to place the document and Document Type depends on the document to be scanned.
Allow 3/8 inches (1 cm) or more space between the edges of the platen glass and the document.
Align a corner of the document with the corner at the arrow of the platen.
  • When you select Color Photo or Black and White Photo, the position or size of the image may not be scanned correctly if you do not leave 3/8 inches (1 cm) or more space between the edges of the platen glass and the document.
  • When you select Color Photo or Black and White Photo, the position or size of the image may not be scanned correctly depending on the document. In such a case, select Document Size such as A4 or Letter according to the document to be scanned.
  • When you select Magazine(Color), the Descreen function will be enabled and scanning takes longer than usual. To reset the Descreen function, disable Descreen in the Scan Settings dialog box.
4. Click 'Specify'... and set the preferences as required.
The Scan Settings Dialog Box opens. Specify the Document Size and Scanning Resolution.
  • When Document Size is Auto Detect or Auto Detect(Multiple Documents), the position or size of the image may not be scanned correctly depending on the document. In such a case, select Document Size, such as A4 or Letter according to the document to be scanned.
5. Click 'Scan'.
Scanning will begin.
When the document has been scanned, the scanned image is displayed in the Thumbnail List area.
Oct 26, 2010 | Canon MP610 Photo All-In-One Printer
Scanner not scanning right. scans in sections. i need to scan a standard size sheet of paper and it scans it in peices. how do i get it to scan this document correctly
You need to set the scanner to scan a standard size paper (letter or A4) in the Scan Settings dialog. To get there, from the MP Navigator select "Scan Photo/Document", then on the lower left side of the preview area click on the "Specify. ." button. Your Document Size is probably set at "Auto Detect (Multiple Documents)". Change this to the size document you are scanning and click "OK". Now you can preview and scan and not have segmented images.
Mar 03, 2010 | Canon PIXMA MP830 All-In-One InkJet...
I want to increase the size of the small drawings i do from my epson 1250 scanner to my canon 1800ip to a4 printout size is this possible.
You have to scan the pictures with a higher resolution to be able to print them in a larger format with acceptable quality.
If your default scanning setting is, say, 150dpi resolution, and you want the picture to be enlarged twofold, then you have to increase the resolution to 300dpi. If you have 300dpi now, increase it to 600dpi.
Some scanner utilities do a fully automatic scan - then you have to find the automatic scan settings and change the default resolution. Or better yet, find an option for a non-automatic scan, where you are presented with various options after the preview scan has been done. There you can usually set the desired size, resolution, improve contrast, sharpness etc.
Generally, the higher the scanning resolution, the more detail you have on the picture, and the higher magnification you can obtain when printing without quality loss.
But there's a catch - a picture in higher resolution produces a bigger file on disk - the file size grows faster then the resolution - a two times bigger picture will be four times bigger on disk. So you have to make sensible choice.
Nov 06, 2009 | Canon Office Equipment & Supplies
My old all-in-one won't scan with my new Vista computer. I am scanning old photographs. I found a fix by scanning through the Paint function. However, I cannot resize the JPEG image I get. It is about...
It sounds like a driver issue. So go to the HP website and look up your printer model under support. I have an HP aio printer/scanner and when I upgraded my Mac operating system, I had problems scanning photos. I went to the HP website, looked up the model number and reviewed support/driver topics, and found the appropriate solution. You'll probably have to uninstall your current printer software and then reinstall with a download from the website. Hope this helps.
Aug 06, 2009 | Computers & Internet
Scanning pictures
scan and save to pictures then reprint it from there. or store in a file for photoes
Mar 26, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Scanning
Scanning Photos With the Control Panel Scan menu, you can scan photos to a file, application, or memory card.
Scan to File 1 Place a photo or photos face down on the scanner glass.
2 Press Scan to display the Scan menu.
3 Press �� or �� to select Photo.
4 Press �� until Scan To is selected.
5 Press �� or �� to select File.
6 Press Start.
The document is scanned and saved based on the Kodak AiO Home Center scan picture settings.
You can change the folder where you want these saved. Just go to tools in your printer window.
Hope this helps- Happy scanning!
Jan 29, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
All in one
this can be a tricky issue, just like getting pictures to print out the size you want. basically, you either need a program like Adobe photoshop where you can change the size of the image, or you need to scan them in at a higher resolution. you can set this in your scanning software before you scan the photo. to give you a rough example: your laptop screen might have a resolution around 1280x720, if scan in a photo at 640x480, it will only cover around half your screen. This is the simple way to do it. If you have photoshop, you can open any sized picture and change the picture size (sometimes you will loose quality). hope this helps :)
Jan 21, 2008 | Office Equipment & Supplies
Brother DCP 115C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
