The HP Wireless Assistant application, which should be installed on your notebook, has an option to turn the WiFi radio on and off.
If the application is not installed, or you need additional information, visit HP's page about Wireless Assistant here: Installing and Using HP Wireless Assistant Windows 7 Vista XP
Good luck :)
Stan
See if proper driver is installed or not . If the wireless driver is installed and your device is good. Search for wireless symbol o the function keys . To enable wireless just press Fn + the function key ! or Shift + function key , if Fn key not available .
Check the BIOS settings to see if the wireless card installed and enabled. If it is enabled then install the wireless driver. Download the wireless and device drivers from the Acer WEB site. Makesure you select the model of your laptop the drivers you that require thatmatches the Windows version that is installed on your laptop. Use this link toget to the Acer support: - http://www.acersupport.com/drivers_download.aspx
There's two WiFi Driver available, try to use the Realtek first and if it doesn't work try the Atheros. If WiFi driver installed correctly you should no longer see the "!" symbol and you will be able to enable wireless on your laptop using FN key combination.
The wireless maybe disable or not install. If the wifi is disable just enable it. Go to control panel locate the wifi icon click it then choose enable
If you cannot see the wifi icon the possible problem is no driver install. Re-install the driver of the wifi network to work out again
some laptops have a special button for that ...take a look if you see some buttons in front of the edge ..and see the wifi symbol ..after press it look if any leds are on for wireless Another thing you should check if the driver for the wireless card is installed and it is enabled...For that get into bios first and default all settings to the factory optimal defaults...after that save changes with f10 and restart ...now is the time to look into the device manager to see if any of the newly enabled devices are in yellow with an ask sign on them ...In this case those are the ones that need drivers to be installed if you do not have a drivers cd for the operation system that you have in use..go to the support site of the manufacturer ,choose downloads..and look for your exact model and operating system ...Most manufacturers have all the drivers needed in free downloads on the site .. http://downloads.medionsupport.com/files.php?cat=2 if you find your exact model on this site ..you will have all the drivers too..
First off make sure that the driver of the wireless adapater is already installed then you need to enable the wireless card of your laptop by pressing FN + F5 then try to connect to the router if it ask you for a Network key it means that the wireless connection is secured and to obtain the network key you can access the wireless setting on the router page..
It has a touch panel at the top above the keyboard touch it to turn on also go into the control panel and select wireless devices select wireless you see a wire connection and a wireless connection right click on it select properties and you will see an option to enable or disable enable it an it should come on
Harry,
If you mean to access WiFI, then all you have to do is buy a WiFi dongle. Install it and then insert the dongle into the USB port. and you are on.
But, if you want to run a WIFi hot spot on your PC, then you need to install a wireless router so that other devices having a WiFI capability can connect to it. You need to set up a WireLess LAN for which there exists a wizard in Windows.
