Question about Maytag Neptune MAH5500B Front Load Washer
1997 maytag front load washer has smell of burning rubber in the chamber.
After we did a wash, strong smell of rubber inside the wash chamber once it was opened...do we get a repair estimate or should we consider replacement at this point...who to call? a maytag repair place or any appliance repair shop?
  • Nina Ivey Oct 15, 2008
    My Maytag Neptune was bought in Nov. '99. When the machine was spinning I noticed a burning smell. When it cut off and I opened the door, smoke came out. I have washed this sleeping bag many times and this was the first occurence. It has not done it since. One repair shop was quoting $600 to replace the belt.
  • guych Dec 20, 2008
    smokes on spin cycle, smell like rubber burning
  • 750 Answers
You said, after we did a wash, strong smell of rubber inside the wash chamber once it was opened...do we get a repair estimate or should we consider replacement at this point...who to call? a maytag repair place or any appliance repair shop?
How old is the model?
It may be only the belt is worn and or slipping.
If you need to repair ,our site has some good repair companies that are our sponsors.
Off to the right of the screen in our site is a window that you can type your zip code into and they
will find you service near you home.
Here is a report I just read that may help you evaluate fixing or buying new!
Repair or replace?
When to pull the plug on your old washer
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your washer,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your washer is under warranty or less than four years old
paying for a repair makes sense.
Note that washer is under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your washer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new washer.
Data also shows that it doesn't pay to fix a less-expensive washers.
Thanks to better recycling programs, less than 10 percent
of a washer you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Posted on Oct 04, 2008
Maytag Neptune MAH5500BWW burn smell (doesn't appear to be hose)
if you have a maytag neptune washer that ran up until now you got your money's worth,that's the machine that put maytag out of business,if it's smoking and ripping the boot it sounds like the tub bearing is gone and you'll have to replace the washer,if it's load in the spin like marbles are rolling around in it that's the problem,but i wouldn't put a cent into that machine.
Oct 06, 2017 | Maytag Washing Machines
Burning smell from washer
YOUR DRIVE BELT MAYBE WORN AND NEED REPLACEMENT.
Oct 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer sounds like a jackhammer when rinsing - this is a new thing with all loads. Yesterday it shut down mid cycle while still full of water and we smelled a burning rubber smell. Any ideas?
There is only one belt on the machine (the burning rubber smell, probably). Sounds like something is wrong with the clutch /drive mechanism. Unless your an accomplished DIY'er, it sounds like a job for the Maytag Man.
Sorry.........................
Sep 15, 2009 | Maytag PAV2300 Top Load Washer
Maytag top load washing machine leaking water from bottom
The machine is leaking water from the bottom, I think the leak is in the area near where the motor is mounted. Before we noticed the water comes from underneath the washer, we smelled like burning rubber.
Al Bana
Jun 26, 2009 | Maytag PAV2300 Top Load Washer
Maytag Legacy top load washer is SMOKING!
this is a bogus website that is trying to push smelly washer product....no real fixes and there are other products out there for less just use bleach first
May 05, 2008 | Maytag Legacy Series Top Load Washer
Maytag washer
lean the washer back .......
Oct 07, 2007 | Maytag MAV7600 Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
372 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
