Question about Pioneer Car Audio & Video
The rotary volume knob on my DEH 9400MP head unit has stopped working. this also happened to my friend's. the steering wheel remote still works. is this common? can it be fixed please?
Although I can't check this fix works for 1 month, a really simple explanation and fix was offered.
The rotary knob/control has 2 contacts, which when the knob is rotated c/w or anti-c/w it generates a pulse. The diagnosis is that as the remote still works, the PCB & volume circuit is fine. What is likely is that the 2 contacts/switches have become dirty or clogged.
SUGGESTED FIX: Take head unit faceplate apart to access PCB & rear of rotary control (4 screws). Spray WD40 into rear of volume control and rotate liberally to clean contacts. Dry of with lint free cloth, tissue or air dry.
I am confident this will work and the volume control will function again.
Posted on Sep 28, 2008
Pioneer vsx1021k volume drops by itself at 3db increments until there is no volume. M volume is displayed when this happens as if someone was manually turning the volume knob.
Dirty rotary encoder (volume control ). If you are confident with opening the unit yourself, a spray of contact cleaner into the encoder might help. Ideally u should replace it.
OR
The volume minus button on your remote is dirty/shorted. Try removing remote control batteries and see if the issue disappears.
Aug 14, 2014 | Pioneer Audio Players & Recorders
Yamaha RX-V1000 volume control erratic, remote doesn't work. All was well then the volume control knob became erratic (volume would change erratically as knob was turned in either direction, remain...
sounds like you need to take it in to have it looked at. no simple fix unless you are an appliance technician. hard to walk a beginner through. i suggest calling an stereo repair guy.
Fix Ya
FixYa Support
Please accept solution and rate 4 thumbs up! Thanks for your feedback!
Aug 21, 2011 | Yamaha RX-V1000 Receiver
DEH-P940MP (Pioneer Premier ) - Button's won't respond. The volume knob works just fine but none of the buttons are working. I hit the reset button and now it is stuck in demo mode because the buttons...
have the same problem just my back screen buttons working. dont know what to do =] will try using remote for now but cant change cd. should i try reset ?? or i should not =]
Sep 15, 2010 | Pioneer Premier DEH-P960MP CD Player
Have difficulty with volume control on Delphi SkyFi. Turning volume knob produces a digital number of 1 to 3. Seems to work better after being warmed up. Can eventually get up to 12 or above. Anything I...
Do you have one of the original orange display SkyFi units, or a SkyFi2, or an XT? It sounds like you are using it in a boombox? The rotary dials do wear out on the SkyFi and SkyFi2 and there isn't much you can do - the knob may come off and you can spray in some contact cleaner, but that doesn't always work either. Using a remote control might be your only hope at this point unless you buy a new old stock unit off of eBay or the like. Good luck.
Nov 10, 2009 | Delphi Roady XT XM Radio Receiver
The volume not does not work on the infinity radio. I can control volume from the steering wheel but not the knob. Is this normal? Can it be fixed?
dear friend-the volume on the steering works from the back of the radio and the knob from the front,they work seperate but both can be used,so the knob on your radio is not working.
Jul 07, 2009 | 2009 Hyundai Sonata
Faceplate not working - will remote solve problem?
PLEASE FIRST CHECK THE FACEPLATE TO HEAD UNIT CONNECTIONS (WHERE THE FACEPLATE CONTACTS THE HEAD UNIT ).
THEN IF U ARE SATISFIED ,REPLACE THE ENTIRE RECEIVER.
May 10, 2008 | Pioneer DEH-P4700MP CD/MP3/WMA/WAV...
Car Audio & Video Logo
158 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
