NorthBridge FoxConn 6100M2ma
Hi people I was wonder, I bought an aftermarket Northbridge Cooler can I put it on my Northbridge and take off the other stock one without messing up my motherboard?
  • 661 Answers
Don't see why not as long as you are careful not to rip the chip off of the motherboard
Posted on Sep 28, 2008
What is the work of northbridge
The northbridge is part of a family of Intel microchips, used to manage data communications between a CPU and a motherboard within Intel chipsets based on Intel's Hub Architecture. It is designed to be paired with a second support chip known as a southbridge.
The northbridge has historically been one of the two chips in the core logic chipset on a PC motherboard, the other being the southbridge. Increasingly these functions have migrated to the CPU chip itself, beginning with memory and graphics controllers. For Intel Sandy Bridge and AMD Accelerated Processing Unit processors introduced in 2011, all of the functions of the northbridge reside on the CPU.[1] When a separate northbridge is employed in older Intel systems, it is named memory controller hub (MCH) or integrated memory controller hub (IMCH) if equipped with an integrated VGA.
God bless you
May 24, 2013 | Compaq Computers & Internet
Does Foxconn 6100M2MA-RS2H Motherboard BIOS support AMD Phenom 64 X4 procesor ?
I'm afraid not. Foxconn 6100M2MA-RS2H has an AM2 Socket that only supports the following processors: AMD Sempron, Athlon 64,Athlon 64x2,Athlon 64FX. Phenom processors support AM2+ and AM3 socket motherboards. Hope this helps. Any vote will be appreciated. Thank you :)
May 30, 2011 | Foxconn 6100M2MA-RS2H Motherboard
Hooking power supply back to desktop gateway computer 310 series after changing motherboard need diagram where can i get one
Let me look around for you.
The plastic front of the computer is the Front Panel. The area of pins on the motherboard that the wires from the Front Panel attach to, is the Front Panel header.
Sometimes there are two Front Panel headers.
This information may be tough to find.
What is needed is the manufacturer name and model number, off of the motherboard.
There were several different motherboard manufacturers used, and several different variations.
I'm going to post two links that may help you with identifying the motherboard manufacturer, and model number.
Look in the middle of the motherboard, around the edges, and in-between any expansion slots on the motherboard, for identifying nomenclature.
http://www.ascendtech.us/itemdesc.asp?ic=MB4GWTHRASHER&eq=&Tp=
http://www.pcpartsohio.com/gateway.aspx?c=2&s=91
Going further, there is a motherboard chipset on the motherboard.
The motherboard chipset consists of the Northbridge chip, and the Southbridge chip.
The Northbridge chip will be covered with an aluminum finned Heatsink. It's identifying model number/letters will be covered.
The Southbridge chip usually does not have a Heatsink. It's model number/letters will be easily identifiable.
The Northbridge chip and Southbridge chip are installed in a mated pair.
A specific Southbridge chip will be used with a specific Northbridge chip.
This means that identifying what Southbridge chip is used will lead us to what Northbridge chip is used, without removing the Heatsink off of the Northbridge chip.
This shows you a motherboard diagram, detailing how the motherboard chipset is connected to the rest of the motherboard,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
This general example of an average motherboard shows you the Northbridge chip, and Southbridge chip,
http://en.wikipedia.org/wiki/File:MicroATX_Motherboard_with_AMD_Athlon_Processor_2_Digon3.jpg
Looking in the middle of the motherboard you will note a bl;ack square Heatsink that looks like a meat tenderizer.
This is the Heatsink over the Northbridge chip.
To the left of the Northbridge chip, and to the left of the ram memory slots, is the Southbridge chip.
It has VIA on it in white letters.
State any identifying letter/numbers that you see on the motherboard.
Please state in a Comment.
Regards,
joecoolvette
May 29, 2011 | Computers & Internet
Computer turns on. Key board and mouse doesn't work. Screen says PC entering power safe mode..red, green, blue..We took battery out, put new batter in. Nothing! Can't get it to do a thing, only turn on...
The northbridge from your motherboard is not making good contact on you MB. You need to replace *********** board or to reheat the northbridge with a heatgun, so the solder under the northbridge will flow and solders again to the board.
Nov 23, 2010 | HP Compaq Presario PC Desktop
ONN N15235 motherboard, which is a 775 socket. I am currently running a Pentium E2160 on its but its pretty slow so I bought an E5400 to replace it. When I changed the CPU over and started up my computer...
The LGA 775 processor socket doesn't matter, calderwooddu.
It's up to the motherboard chipset, and the BIOS program, and version, of what that Foxconn N15235 will support. I would go back to the Pentium Dual Core E2160, use CPU-Z from CPUID.com, (Free), and see what the motherboard chipset is, first.
(Motherboard chipset: The Northbridge, and Southbridge chips. Chip is slang for I.C. Integrated Circuit)
The Northbridge chip is what determines what Processors are supported.
1) http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
2) http://en.wikipedia.org/wiki/Northbridge_%28computing%29
Since the E2160 is built upon the 65nm technology, and the E5400 is built upon the 45nm technology, the Northbridge chip of the Foxconn N15235 may not support the E5400.
With the technology change are also Instruction Set changes. Plus other parameter changes. The BIOS program, and version on the Foxconn N15235 may not support these, either. Sorry to be a bummer.
Not a solution per se, Yet.
Need to know what computer this Foxconn mobo is out of. (MOtherBOard)
OR, if you get the computer operational again, let's use CPU-Z to see what the motherboard chipset is.
Need help in downloading, and/or installing CPU-Z, post in a Comment.
Oct 09, 2010 | Computers & Internet
6100m2ma-krs2. I'd like to check and see if there are updates for my motherboard. Which model should I use. I'm trying to install an SSD.
http://www.foxconnchannel.com.cn/support/downloads.aspx?ProductModel=6100M2MA-KRS2&TypeID=zh-cn0000003
Should this link ever fail it appears that the 6100m2ma rsh2 may be the same. The link for the krs2 is only on the Foxconn China website.
Though this posting is very old I am posting so that others may find this info which was very difficult to find.
Jul 07, 2010 | Foxconn 6100M2MA-RS2H Motherboard
I have just purchased a AMD Athlon? 64 X2 4400+, 2.2 GHz and installed in a imedia Board: NEC COMPUTERS INTERNATIONAL MS-7168 1.0 Bus Clock: 200 megahertz BIOS: American Megatrends Inc. V3.07 do i need to...
It looks as though my resources were incorrect, as far as the two motherboards having the same processor socket.
(MSI RS480M uses a Socket 754)
What does concern me, is if the motherboard chipset used is the same. This was the stated information.
Chip, and Chipset are slang terms for IC. Integrated Circuit.
http://en.wikipedia.org/wiki/Integrated_circuit
Viewing this motherboard diagram may help explain how the motherboard chipset comes into play,
[You can also type, one at a time, Northbridge (computing), Southbridge (computing), Comparison of AMD chipsets, in the Wikipedia search bar, to gain more knowledge]
The Northbridge chip determines what Processors can be used.
It also controls high speed graphics technology.
AGP and PCI Express being high speed graphics, not PCI.
Determines what Ram Memory is used, and what Southbridge chip is compatible with it.
Let's go back to basics, and see what Northbridge chip is on your motherboard.
Two ways.
One, it looks as though you may be using a tiny program such as CPU-Z, or Belarc Advisor.
If not, I would advise downloading the free, tiny program CPU-Z from CPUID.com
Can you install the old processor, (AMD Athlon 2.25GHz), and get your computer to work, or are you using it now?
After you have CPU-Z running, left-click on the Mainboard tab, and tell me what it states for Chipset. Also tell me what it states for Southbridge.
Second way.
Physically look at the Northbridge, and Southbridge chip. IF, they are not covered with a heatsink.
The Northbridge chip is usually a large chip, and is located close to the processor socket.
Most configurations are like this; Processor socket at the top of the motherboard, ram memory slots to the right, Northbridge chip below the processor socket.
Motherboard designers put the Southbridge chip all over the place. There is no usual spot.
It is my belief at the moment, that your Northbridge chip will not support dual core processors, such as an AMD Athlon 64 X2 4400+
Only Single core processors.
Once I know what Northbridge chip you have, we can determine what your CPU support is.
Jan 23, 2010 | Systemax Dual-Core AMD Athlon 64 X2 4400+...
Computers & Internet Logo
378 people viewed this question
David Payne
David Payne
