Question about GE GMR04AAM Compact Refrigerator
Brand new wont get cold cotrols sa of no on switch i unpluged it still no luck I have the same problem. It won't get cold. Unpugged and wait a day still no good. Metered temp setting and no go
  • josephgalluc Oct 02, 2008
    I have a new 4 cubic feet refridgerator. It was given to my by a friend who decided he wanted a full size instead. He had it over a year and never took it out of the box so the warranty is over. It seems like the compressor is running,I took reading on the temp control. On off it is open, any other setting reads continuity. Is there a way to check the charge on refrigerant
    Brigadier General:
  • 6,966 Answers
I am assuming that by your post "...wont get cold..." you are referring to the entire unit, both the freezer and the fridge. Since the fridge is cooled by way of drawing air from the freezer/evaporator, it is the freezer that must be attended to. Most designs have a single compressor, might or might not have two but definitely a thermostatic control (which incidentally you have posted to checked out OK). By process of elimination, that leaves us only two (2) possibilities:
  • the compressor; and/or
  • the refrigerant.
The compressor is basically a motor and a pump. You could check by feeling if the casing of the compressor hums/vibrate, then this would be a safe assumption that the motor is running. On the other hand, the refrigerant could have dried out/leaked and therefore would require a refilling process.
Depending where you are, the availability of service center either authorized or independent, the repair cost would have to be considered given the size of the unit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 02, 2008
    Scholar:
  • 121 Answers
With any refrigerator there are only a few things to make it cold. First make sure the compresor and fans are running. If there are any fans. With this being a brand new unit it is under warranty for the sealed system. So if it is low on refrigerant you can exchange it or go thourgh the warranty process of having a repairman come out and fix it. There should be a thermostat in the refrigerator part that you can ajust. Other than that there's not much else to a refrigerator Exspecially a new one.
Posted on Sep 27, 2008
  • Edward Boukater Oct 02, 2008
    To check the refrigerant on a demestic refrigerator you have to have a perising valve to access the system. You can theses at any appliance store it's an a-1 vavle. With a set of refrigeant gauges you should read 2-8 lbs. low pressure on the suction line or the biger line that gets cold. The valve comes with 1/4, and 5/6 fittings in it with directions in it. The thin g is do you have access to refrigerant gauges. Call me at 504-722-3946
  • 943 Answers
Hi thanks for the question can you hear the compressor running put your hand on the compressor to see if its hot if its hot and no cooling you have an internal leak if so not worth repairing thanks the appliance doc
  • john gagnon
    john gagnon Sep 27, 2008
    so check tat and get back to me hopefully its not the compressor thanks
New battery In mercedes no power
I'm not a car mechanic, but, it sounds like you might want to check the fuse to the ignition switch, and, if that fails, it might be a problem with the Start Safety Switch on the transmission. Good luck.
May 02, 2017 | Mercedes-Benz S-Class Cars & Trucks
Polti vaporetta comfort steam cleaner...no steam
if you put two much water in it it wont steam
Dec 26, 2012 | Vacuums
1993 Toyota Camry won't restart after driving unless waiting hours. The starter doesn't try and it's brand new. It always starts cold and if you don't drive it, you can turn it off and restart it over
i'me asumeing the batt is ok....turn on lights, do they dim when you try to start engine? if not .bad selonoid on new starter..was it rebuilt? it happens. Billy Starr
Dec 27, 2011 | Cars & Trucks
Sometimes my car won't start, the security light blinks i wait ten minutes try again, then it starts. How can i fix this without the dealerships help?
Is it cold when this is happening? If so it is your ignition switch. Common problem with ions yet no recall. Just have to get it replaced and its costly too, around 400$. I have had mine replaced twice in 3 years and with a new one i have still had some times it wont start on VERY cold days
Jan 13, 2010 | 2004 Saturn ION
Wont turn on.
I suspect that your battery might be down. Try opening with new batteries.
Sep 07, 2009 | Vivitar ViviCam 8300s Digital Camera
1983 chevy pick up wipers won't turn off
The wipers have a control module in the wiper motor. That is what is wrong. On that model you will have to replace the wiper motor . Good Luck
May 07, 2009 | 1983 Chevrolet Silverado
We have a 1986 montgomery ward microwave that the cotrol panel will only display 8888. It appears to be locked.
You can try resetting the micorwave by unplugging it, waiting awhile then plugging it back in. However, considering it's age. It is probably worn out and repair would cost much more than a new mupdated microwave. They are very reasonable in price now.
Aug 01, 2008 | Microwave Ovens
GE GMR04AAM Compact Refrigerator Logo
136 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
