Mitsubishi 55 inch rear projection tv has convergence problem
  • rudypinette Sep 27, 2008
    I replaced the ic chips and its still not working and I rechecked sodering and tryed it again
    President:
  • 2,712 Answers
It could be an issue with faulty capacitors around the IC's as well. You can make out which are faulty, because their caps willbe swollen on top. Here's a sample pic of a bust capacitor (not same model):
Check the specifications of the faulty capacitors, and get the replacementsfrom your local electronics shop. If you are comfortable with this, you can usea pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors.Once that is done, solder in the new capacitors carefully. If are unsure how todo this, try to get a friend who knows how to do this kinda stuff do it foryou, or get a qualified technician. Warning: If you do nothave a background in electronics repair, or are inexperienced, get a qualifiedtechnician to do it for you.
REMEMBER there are very dangerous voltages inside a TVthat can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECTTHE POWER BEFORE YOU DO ANYTHING.
Hope that helps!
Posted on Sep 28, 2008
    Master:
  • 479 Answers
The problem is most likely the STKxxxx convergence output ic's. There are two, one for red and one for blue. Change them both, the blue one will also be going soon. They are not expensive.
OR
Sounds like the classic cracked solder joints. If the color is spreading out over the screen you do not want to touch the convergence controls just yet. Pull the convergence board and using a strong magnifier, look very close at all the solder joints, especially on the Modules. I have fixed many of these problems just by re-soldering cracked solder joints. If the convergence was "in and good" before it started having this problem then this should bring it back to normal. However,if you play with the convergence controls prior to re-soldering then get ready to do some serious alignment time just to get it back to the way it had been before. Change the red convergence STK and you will not need to adjust the convergence.
OR
Convergence output devices [ 3 ] change them, inspect both + - supplies to convergence ciruiit. Check for open fuse devices
OR
Check R540, a 1 ohm resistor off the flyback. Check the supplies to the vertical ckt. Derived from the FBT, etc. Also check connections to/from yokes
OR
Check the pin output transistor and associated capacitors. Usually the area around the transistor is discolored from excessive heating of the transistor. Also check the other active components in the pin ckts.
Suspect components on the convergence adjust/output panel, check for poor solder connections, bad electrolytic caps, etc.
  • 10,594 Answers
Please confirm voltage supply on replaced STK ICs approx +21volts and -21volts.
If these voltages are not present, STK ICs will not function.
I have a 55 inch rear projection mitsubishi tv. it recently has started showing what looks to be white spots when viewed at a distance on a dark screen. when you look at it closely it actually is red green...
It is called Convergence. You have three CRTs. Red, blue, Green. When they are not aligned, you will see the individual colors. See if you can do some alignment in the users menu. Look for Converge or Convergence in the menu. Either under video or setup.
Mar 09, 2011 | Mitsubishi WS-55511 55" Rear Projection...
THE PICTURE GET BLURRY FOR A FEW SECOND THEN GOES BACK TO REGULAR..IT IS A 55 INCH MITSUBISHI TV REAR PROJECTION...IS TIS EXPENSIVE TO FIX?
Yes,the shop will cost u $300 for parts and labors. Convergence problems,the 2 convergence ICS it well die,just not dead yet.Problems will be blurry,color misalign,3 D look,when the 2 convergence is dead.
Feb 06, 2010 | Televison & Video
I have a 55 inch TV and the screen is getting foggy. When we tap the top it goes away sometimes
Ur convergence is cold solders or dying,U know how to solders?Tries websites.Tv repair World.com,Tvrepairkit.com for the convergence kit.
Dec 15, 2009 | Mitsubishi WD-62525 62" Rear Projection...
55 inch mitsubishi rear projection tv red lamp out of adjustment
Have convergence IC's replaced. I believe this unit uses STK-392-570 convergence IC's Only one has gone bad but replace them both, because if one has failed then the other is not far behind, for Blue and Green. One handles Red, One handles BLUE and Grn. There are only two of them in the set, They are the two largest IC's in the entire set.
Oct 01, 2009 | RCA HD52W59 HDTV Projection Television
I have a Mitsubishi 55 inch rear projection tv, ws55819 on which the convergance is gone bad. I'm getting a concave picture with multiple colors and black lines with a blurred picture. this happens mutiple...
Your reference to concave picture suggests a high voltage problem and not convergence. If the raster can't scan from left to right , top to bottom, your having High voltage trouble. if your colors are not dropping on top of each other that is convergence. I would suggest it may be time to consider a purchase of the new HD set for the cost of this repair. good luck
Jul 03, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Warped 3-D LOOK COMES AND GOES
resolder the convergence ICs . Common problem with mitsubishi rear projections
Jun 16, 2009 | Mitsubishi WS-55859 55" Rear Projection...
I have a Mitsubishi 55 inch rear projection tv, ws55819 on which the convergance is gone bad. I'm getting a concave picture with multiple colors. Repair shop estimates are $340-420.00 Can I replace the...
Yes you will need to replace both of the STK392-570 Convergence ICs and the two 5 amp pico fuses. You can get the parts at the following link and they provide instructions with pictures that show how to do the repair. Heres the link'
http://servicemanuals.vstore.ca/
Jun 14, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Out of focus
You have a convergence problem, probably the convergence electronics are going out or the TV has been violently moved and needs a mechanical alighnment. Small adjustments can be made from the menu.
May 17, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
