Question about Maytag Washing Machines
I need to replace the timer on my maytag atlantis mav7600awq, but can't figure out how to access the control panel.
  • 943 Answers
Hi thanks for the question you will see 3 or 4 screws at the top of console remove these screws first disconnect power supply now you will be able to see the timer if you need more assistance i will be here thanks the appliance doc
Posted on Sep 27, 2008
Maytag Atlantis MDE7400AYW timer has been replaced but the dryer won't stop drying on it's own. What is the reason? I have the same problem... the timer on mine doesn't seem to work. Any ideas?
The wire connections to the timer may have not been made correctly when it was replaced bypassing the OFF contact in the control circuit.  There should be a wiring diagram inside the front or back panel that you can check.
Jun 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
My Maytag Atlantis MDG6400AWW will not heat up. The drum spins but the clothes don't dry!
my dryer timer is not turning off and it does not get hot,I check glow coil.its working but it does not fire up.I smell gas some time
Apr 16, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag Atlantis MAV7600AWQ Washer. Delayed fill
ALL WASHERS COME WITH SCREENS AT THE
WATER CONNECTIONS.DISCONNECT THE HOSES AFTER TURNING OFF THE WATER.THEN,CHECK THE SCREENS FOR MINERAL BUILDUP.CLEAN THE SCREENS IF
NEEDED AND GO FROM THERE.
Mar 07, 2009 | Maytag MAV7600 Top Load Washer
Maytag top loading washer won't agate. Instead it fills with water and spins, then drains, fills for the rinse and spins. Thanks Bill
Open your control panel.
Disconnect then reconnect your timer wiring harness.
If this does not correct the problem,replace the timer.
Feb 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis....how do I get the timer off the console ??
easy lau...ok since you have the console of ,,just go to the timer knob you see that round piece in center thats just a cap take screwdriver and pop it off gentle...noe remove that clip,,theres a spring under thre dont let it bounce away ,,easy,,now remove the dail just pull it of with your hand,,,ok see the 2 scerws holding the timer,,,orayyy,,if you need help im onthejob
Dec 31, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Still trying to access control panel on maytag washer atlantis
hi. i think you have a drain problem .not the timer . i would check the drain lines. i am sure that's where you will find a blockage. try that.
Sep 27, 2008 | Washing Machines
Timer on maytag washer
this is a good one! dependable care unit made in my home town.
http://www.servicematters.com/maytag_library/docs/16010373%20(16001145).pdf
insert flat blade under center plastic clip in the center if timer knob , you will find a little clip and sping here , then remove two 5/16 screws , then remove two phillips screws on control panel , you should see 4 ,2 on each side remove the inside 2 then tilt panel forward unplug timer. so easy
May 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Removing Timer Knob on Maytag MDE7400AYW dryer
Can anyone help me? I have a Maytag Atlantis that my parents just gave me and my wife. Unfortunately, they accidently removed the model number sticker in the door area. I need to buy a new timer but no one can find which timer to get without the model number. Via the internet, I think I narrowed it down to either the MDE7400AYQ or the MDE7400AYW....but they both look identical to me. Can anyone tell me what the difference between the two is so I can go get the part?
Mar 03, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis gas dryer
timeout...I'm guessing you mean that the timer on off doesn't turn anything off. If this is a mechanical timer unit, the contacts are welded. If electronic, your relay is probably welded. Replace the item. If you do go inside, unplug the unit, and then find the relay or contact set and see if they are actually welded. Most units have a diagram on the back. Follow it through with a multitester.
Dec 17, 2007 | Maytag Atlantis MDE6400AY Electric Dryer
Washing Machines Logo
77 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
