Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Will not turn over w key NOW no spark
Has'nt started with key all year, so I've been jumping it, no big deal, just a pain. Now last week I get no spark, tried a differant lamanate, nothing
    Scholar:
  • 76 Answers
I hate to sound obvious, but if you are starting it by jumping it, than the problem may not lie in the circut or ignition, but it may be a battery problem. Have you checked the battery to make sure that is a full charge?
Posted on Sep 27, 2008
Nothing when turn key. Bought new battery and fully charged, installed, still nothing.
The "ticking" you hear is probably the solenoid trying to "connect"
The solenoid is the round thing that is the first thing the large red cable from the battery runs to. There are more wires connected to the solenoid..the TWO big ones carry the power from the battery and then jump it to the BIG cable that goes directly to the starter. You can CAREFULLY "jump" the two big connectors ON the solenoid with a screwdriver ( CAREFUL - SPARKS WILL FLY!). If the motor turns over you have a bad solenoid. Key does not have to be on, you just want the motor to turn over. NO open fuel sources!! SPARKS WILL FLY WHEN YOU JUMP.
Try this and repost, let me know.
Mar 10, 2016 | Polaris 2006 Sportsman 500 HO EFI
I was driving my 1994 isuzu rodeo and lost complete power.Got a few jumps and truck wont start.sounds like it wants to start when i turn key over.I also put gas in and still nothing
run the fault codes
check for cam/crank position sensors failure, immobilizer failure , pump operation
could be a failed ECM
have the battery load tested as it may be the original fault and jump starting may have caused a power surge and damaged the ECM
Feb 27, 2016 | Isuzu Cars & Trucks
97 e150 van 5.4; engine only starts by jumping the solenoid but not with the key.
If you have automatic trans, test neutral safety switch. As last resort, wire up a push button from battery + to starter solenoid.
Jun 27, 2015 | Cars & Trucks
My 2001 oldsmobile aurora will not start what can i do
You may not be dealing with the anti theft, just the basic no start condition the light flashes then goes out,if this was alarm it will keep flashing,you may be dealing with no start from no fuel ,to no spark. Here what you can eliminate,turn the vehicle on you should hear the fuel pump go on.If you dont,then your dealing with a fuel problem. For spark remove one sparkplug at the coil leave a 1/4 air gap and crank the engine if you dont have spark your dealing with a spark problem.
Mar 10, 2012 | Oldsmobile Aurora Cars & Trucks
I've been at this all day and still have'nt gotten my laptop to reset to a factory default setting. Can you please guide me through this process, step by step. Thankyou.
You can always restore the computer to a point when it was working fine.
For a laptop when you say factory defaults we've two things
1)Factory defaults on the Bios - as soon as u turn on the laptop we press F8 key or DEL(depends on the brand of the laptop) to get to the BIOS and you've an option to revert to the factory defaults.
It is advisable not touch the BIOS if you are not sure about this firmware
2)The operating system (lik windows xp,vista & 7) there is nothing called factory defaults for this all we've is a installation of the Operating system itself. However we can revert or restore back to last know good configuration mode.
How to start your computer by using the Last Known Good Configuration feature To start your computer by using the Last Known Good Configuration feature, follow these steps:
  1. Start your computer.
  2. When you see the "Please select the operating system to start" message, press the F8 key.
  3. When the Windows Advanced Options menu appears, use the ARROW keys to select Last Known Good Configuration (your most recent settings that worked), and then press ENTER.
  4. If you are running other operating systems on your computer, use the ARROW keys to select Microsoft Windows XP, and then press ENTER
Aug 18, 2011 | Computers & Internet
Sprayed down lawnmower with water, now it won't start. I decided to "wash" the lawnmower last week and now it won't start. And the really weird part is the solenoid clicks every minute...
Engine will not run with no spark or a weak spark. Continuity test will only reveal that the winding is not open, not if you are producing a weak spark that will not jump the spark plug gap.
Mar 31, 2017 | Garden
My Samsung 23 inch LCD tv works fine for 25 minutes then the screem starts jumping..
There is a Anynet Setting under the input tab. It has to be on the right setting or the picture Jumps after 20-25 minute. Once I adjusted it to the right setting it stopped jumping and it now works Perfect. Would nt have figured it out if I wouldnt have been messing around with it as a last chance deal.
Dec 27, 2009 | Samsung LN-R237W 23 in. LCD Television
No spark on lawn tractor
have you bypassed the ignition switch?? if you by pass that switch and you get spark you know its the switch
Sep 28, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mitusuhuibi big screen
start shopping around for new TV
good deal jan 1
Dec 14, 2007 | Mitsubishi WS-55807 TV
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
143 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
