Question about RCA P56950 56" Rear Projection Television
I need to replace the flyback and I cna't find the part number or purchase referece. Can you help?
I need to replace the flyback on my RCA P56950 and I can't find the correct part number. The original flyback is marked PN15478840, however I can't find anything under that p/n.
Can you help me find the correct replacement?
Chassis PTK195W1P
Thanks!
Robert Nova (robertnova@codetel.net.do)
  • 119 Answers
SOURCE: 56" RCA projection TV (FLYBACK related problem)
the base to emitter of the hot will read short on a diode checker/test on ohms it vairies but typically about 50 ohms.e to c, or b to c should have very high resistance. unsolder the collector of the hot. make sure all solder is gone. now test the ohm between your tuner ground & the pad of the hot collector it should read open.
Posted on Jan 16, 2007
Slinteriors
  • 8617 Answers
SOURCE: flyback 259296
When you remove the rear panel look to the left side of the chassis and you will see the Flyback with the two wires coming out of the top one is a large thick red wire the other is a small wire. You can get a new replacement at the following link under 50.00 which includes free shipping and free support to help you install it by on line instant message with a repair tech.
http://servicemanuals.vstore.ca/
Posted on Jun 18, 2008
ladywinn
  • 5138 Answers
SOURCE: D52W14 power button blinks 3 times
Yes make sure you get correct flyback,call UED 1-800-648-6657 see if they have part; also are you sure that is what is wrong?Check capacitor cp150 2200uf 16 v see if it is ok or if it is bad this cap if bad will keep set from coming on,and if it is bad there is 2 other capacitors that need to be replaced also.
Posted on Dec 14, 2008
  • 346 Answers
SOURCE: RCA CONVERGENCE PROBLEM
check and or replace dl231, fl231
Posted on Jan 27, 2009
  • 4234 Answers
SOURCE: Cant Find Correct flyback
Sorry about the delay.
The RCA part numberis 259296 and is available fro tritronicsinc.com for $50.39
Dan
Posted on Mar 03, 2009
RCA P56950 Powers on then 10 mins later powers off, repeats cycle. Then channel display in TV changes by itself
may be some thing is stuct on the controt pannel power button or others check. try this it may work
Jun 04, 2012 | RCA P56950 56" Rear Projection Television
Find a horizontal output transistor or flyback
Flyback transformer part number for a tv RCA F32648
Mar 06, 2010 | RCA F32648 32" TV
I need to find a service manual for an RCA F32650 so I can replace a blown flyback transformer, preferabley free if possible
I have repaired many of these; if a high pitched buzz when you plug the set in---flyback and horz. output transistor are bad--transistor has a generic number on it--Flyback is location number LL05, part number should be 257805---you will find RCA no longer has this part--most now are replaced with an asti #2078----CHECK the RCA number on Ebay---company I get them from is Suburban Electronics---Flyback and transistor are less then 30 dollars for both.
Aug 06, 2009 | Televison & Video
Will not turn on
Bad FBT flyback transfomer,ck hori output transistor.
Jun 11, 2009 | RCA P56950 56" Rear Projection Television
Broken/Cracked front screen
Pls provide model number of the unit.
This unit is a projection or DLP unit?
Dals123
Oct 09, 2008 | RCA P56950 56" Rear Projection Television
RCA D52W20 flyback question
If your model number is D52W20 you need flyback number 259296 and you can get a new flyback at the following link and they will givce free online tech support to walk you through the removal and replacement procedure.
Jul 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
CTC 195 series
Horizontal output transistor is needing replacement for sure and quite possibly the flyback as well
Jun 29, 2008 | RCA P56950 56" Rear Projection Television
Tv went out, made a pop sound and won't turn back on
Sounds like the flyback went out. Your set is a CTC195 you can get a replacement flyback for it at the following link. They also provide free instalation instructions and free on line tech support.
Apr 30, 2008 | RCA P56950 56" Rear Projection Television
Rca projection tv
eeprom problems, need chipper checker test
Aug 20, 2007 | RCA P56950 56" Rear Projection Television
RCA P56950 56" Rear Projection Television Logo
171 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
