Question about Mitsubishi HS-U560 VHS VCR
Part for VCR mechanism
I had a worn capstan/drive belt on my HS-U560 VCR and replaced it. Thinking all was fixed I reassembled the mechanism and replaced the cover. Big mistake! When I loaded a tape, I was unaware that the arm that the cleaning pad uses to clean the heads every time you load a tape was stuck in the clean postion. It kept the tape loading mechanism from completely loading the tape around the heads although the motor was trying to force the operation. It eventually broke a gear and now the unit is unable to load a tape. I took it to a video repair shop and they told me that the part was no longer available. Does anyone out there have an old unit that still has a functional mechanism. Even if the unit is dead, it would still help. All I need is a 'working' VCR mechanism.
  • Tim Valdez Oct 02, 2008
    I.m in Mobile, Alabama but haven't gotten any positive results when trying to locate anyone who could get parts for my HS-U560, They usually just say they're no longer available.
  • 4,234 Answers
I'm not sure what part you ned, but parts are still available from generic suppliers although not from Mitsubishi. Where are you located?
Dan
Posted on Oct 01, 2008
    Problem Solver:
  • 5 Answers
Did you ever get your part discussed in this old post? If you want to send it to me, I may be able to make a part for it. I've made machine parts by hand successfully before. Although it would probably be easier to repair the part that you have. After seeing it, I may decide I don't want to attempt it. Or you could send photos of the broken part and it's location, and I might be able to give you instructions on how I would do it. I just replaced the belts on my folks HS-U560 so have some familiarity.
Posted on Apr 06, 2013
  • Keith Douglas Jan 11, 2015
    Do you know were I could find some replacement heads for Mitsubishi U-48 VCR thanks.
I've a Mitsubishi HS-U770 that has not been used for several years. When I tried to use it today, the tape loaded but would not play, rewind, or fast forward (I hear what sounds like gears slipping). The...
Mine did that, and when I opened it I found that a small drive belt (visible from the bottom with the cover removed) had deteriorated into goo. This unit had been in storage a while and the rubber just deteriorated, I guess. The trouble is that now I cant tell what size it is, or what length. I think this belt drives the mechanism that loads the tape in and out, and the rest of the mechanism is triggered by the tape cassette moving into position. Since it cant get loaded properly, the rest of the machine doesnt work right, either.
Jan 17, 2011 | Mitsubishi HS-U770 S-VHS VCR
Mitsubishi black diamond E4 fault
your VCR has a problem with the drive belt CAPSTAN, maybe is broken or fallen, you have to take it apart and check that the band is in order
Mar 16, 2010 | Mitsubishi HS-U445 VHS VCR
Can we tape digital feed on a VCR and play it on an HD-ready tv?
You should be able to accomplish this. Run the antenna to your converter box. Run the video and audio outputs of the digital converter box to the inputs on your vcr. Your vcr should then be able to record the program (select line-in as the channel when setting up the recording). Hook your vcr audio and video output to your tv.
It's best to use a converter box that has an event timer - this allows the converter box to turn on at a specified time and channel. Otherwise you will need to manually set the channel you wish to record on the converterbox, and leave it turned on.
Mar 10, 2009 | Mitsubishi HS-U560 VHS VCR
A tape is stuck in my VCR. and i cant get it out, How can I remove it? notheng
Open bottom metal cover. Rotate the belts of the motor. Cassete should unload from Spindle and reel back into the cassette. Then please open the VCR top, and you will see a belt and gearmechanism on the right side of the cassette compartment. Manually rotate the gears and the tape will slowly come out.
Jul 20, 2008 | Mitsubishi HS-U560 VHS VCR
Replacement Belts for Mitsubishi HS-U560
You can try Vancebaldwin.com or MCM electronics corps, or even tritronics INC.
Mar 22, 2008 | Mitsubishi HS-U560 VHS VCR
Sony VCR
I'm not sure how old your unit is but over time, the rubber parts in a VCR become cracked, glazed and begin to slip.
There is a rubber wheel about the diameter of a nickel that is called the pincher wheel and does exactly what its called.
It pinches or compresses the tape against a shiny metal spindle called a capstan. The capstan spindle is connected to a motor. The pincher wheel rests against the turning capstan with the tape in between the wheel and capstan.
The pincher wheel can become glazed and coated with a brown oxide that has worn off of the tape. This causes the tape to slip and it can spool out into the VCR.
There is another wheel called an idler tire. It lays flat and pivots between the sending reel and pickup reel. Its used during play, fast forward & rewind. This wheel too can become glazed and worn causing slipping. If your unit won't play, fast forward or rewind, most likely the idler tire is the culprit.
There are also belts that can also become glazed and worn. These belts are used along with motors in the tape load/eject mechanism and capstan drive. If the belts slip, the tape may not load or eject properly and the capstan might not be turning properly.
When I owned my repair shop, one solution was we to remove the belts and/or tires and apply a re-grip solution on the rubber with a cotton swab, while roughly rubbing the the entire rubber surface back & forth with the swab. The re-grip solution actually eats away the top surface of the rubber leaving the rubber surface course and causing it to grip better.
Another solution was to just replace all of the rubber tires and belts. These parts including the re-grip solution may be ordered through www.mcmelectronics.com
Please let me know if I may be of further assistance to you.
- Jim
Feb 26, 2008 | Televison & Video
VCR started eating tapes.
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle connected to a motor. The pincher wheel can become worn and/or dirty (slick) from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out of the cassette than can be wound up on the takeup reel. You can try using a re-grip solution on the idler tire or replace it.
Let me know if you need more information as to where to purchase these parts.
Yes - There are cassettes available that are made out of clear plastic that allow you see what's happening. You can also trick the player into thinking there is a tape. There are sensors (mechanical & infrared sensors) that you can bypass.
- Jim
Jan 30, 2008 | Mitsubishi HS-U560 VHS VCR
Vcr hs-u500
Typical belt drive failure. Take the cover off and turn the loading motor shaft with your fingers until the tape is ejected. Get a belt kit for this model and replace all the rubber parts in your VCR. Mitsubishi's are nice units and worth fixing. Check the little pulley under the capstan motor for cracks or worse.
Dec 30, 2007 | Televison & Video
Televison & Video Logo
440 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
