Cant get cordless mouse and keyboard to reconnect at the same time only one at a time how do i get them both too respond at same time
I'm not too great with computers and don't know if this will help, but i have a wireless mouse and keyboard set up on my pc. I have a device that plugs into the usb port that picks up and synchronises the bluetooth rather than it being picked up directly by the computer. I've seen the devices in pc world, so i presume they're quite generic and you should be able to get them in most pc shops.
Hope this gives you an option
Posted on Sep 27, 2008
The mouse has stopped working /responding--what could be the issue? Does this take batteries? I cannot find a place that they would go...
Logitech uses either 1 or 2 AAA batteries or 1 or 2 AA batteries.
The way to change them is:
1. locate the oblong button on the bottom (usually near the palm end) of the mouse.
2. Press and hold the button
3. Lift off the cover (top) from the palm end.
4. Replace the batteries as indicated inside the cover.
5. Reinstall the cover. Be sure to catch the little tabs under the buttons.
6. There may be a reconnect button also (small red and recessed) you may have to reset the connection after changing the battery.
Aug 21, 2010 | Logitech Cordless Mouse
Keyboard and mouse not working
Can you give me more information...What brand of mouse and keyboard are they?
Do they use seperated recievers or does one reciever work for both mouse and keyboard?
Aug 27, 2009 | Logitech Wireless Access Duo Optical...
Keyboard isn't responding but mouse is
open the Logitech utility and try to reconnect the keyboard and pair it with the mouse. if it doesnt work uninstall/reinstall the software for your wireless mouse/keyboard.
May 27, 2009 | Logitech Wireless Access Duo Optical...
Connectivity problem with Logitech Cordless Desktop Wave Keyboard and Mouse
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Sep 16, 2008 | Logitech LX7 Cordless Optical Mouse
Cordless mini optical mouse
My Logitech cordless mouse quick working when I checked into a motel. How do I get the mouse working again? The touchpad is driving me whacko!
Sep 14, 2008 | Logitech Cordless Mouse
Mx3200 keyboard stoped typing
Unplug the USB (or PS/2) plug for a couple of seconds and reconnect them. That worked for me when this happened on my older Logitech keyboard.
Jul 05, 2008 | Logitech Cordless Desktop MX3200 Laser...
Hotkey problems
I had the same problem but finally found a solution hidden in the depths of Logitech. It's quoted below. I had to do it a couple of times before it worked, and it seems that you need to reconnect the mouse at the same time. I didn't the first time and then the keyboard refused to work. (Finger trouble?) :-(
Cheers,
Magani
The following is from :-
http://logitech-en-ap.custhelp.com/cgi-bin/logitech_en_ap.cfg/php/enduser/std_adp.php?p_faqid=28&p_created=1083786523&p_sid=hwmEUpij&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTkwLDE5MCZwX3Byb2RzPTg0NCZwX2NhdHM9JnBfcHY9MS44NDQmcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1teCBkdW8gaXRvdWNo&p_li=&p_topview=1
This article applies to the following products:
Cordless Access Duo
Cordless Acess Duo Optical
Cordless access keyboard
Cordless Elite Duo
Cordless MX Duo
Cordless Navigator Duo
You may be able to reset the keyboard and resolve the problem by clearing the keyboard capacitors. To do this, remove the batteries from the keyboard and type continuously on as many keys as possible for one to two minutes. This action should simulate touch-typing; you should not press and hold only some keys down.
After you clear the capacitors, replace the batteries and synchronize the keyboard using the following procedure:
  1. Make sure the batteries are in correctly. A diagram on the device itself or in the Getting Started Guide should tell you the correct polarity for the batteries.
  2. Press the connect button on the receiver.
  3. Press the connect button on the bottom or right hand edge of the keyboard.
    NOTE: If you are using a Cordless Desktop System, you must do this procedure for both the mouse and the keyboard.
The "Connect" button on the mouse is quite small and usually requires a pencil tip or other small object to push it. Remember, ALL Logitech cordless devices will have a synchronization button. If you have the "Cordless Mouse" with Model Number (M/N) M-RN67, the button will be located in a small hole on the lower portion of the back of the mouse. You will need a paper clip to access the button.
Jul 03, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
