Am not getting power to fuel shutoff nor am i getting power to fuel pump but will start if you pour gas down the air filter ,any ideas of wht it could be
Fuel shutoff? Are you talking abouty the inertia switch? Are you aware that you will only have power to the inertia switch and to the fuel pump for about 2 seconds when the ignition switch is turned from OFF to RUN? If you are checking for voltage here after that time, you are not SUPPOSED to find any.
If you are not getting any voltage there during the 2-second "fuel prime" cycle, then you need to check your fuel pump relay circuits. (Primary AND secondary)
