Question about Kenmore 22422 Top Load Washer
How to change a belt on model no. 110.22882101
Please help. The spinner stopped spinning and I smelt a burnt rubber smell. We took it all apart, found the belt at the bottom. And crazy, we cut it off as it was mishapen and worn. How do we access it, where does it go, and what is the number to replace. The belt number or placement is not in our repair parts list.
  • Jowilloughby Oct 01, 2008
    yes. the model is right. What happened was I washed a heavy, flannel quilt that I made. It was a rag quilt that had a lot of fraying. So either the lint or the weight... I went down to the machine and the quilt was soaking wet and I smelt this burnt rubber smell. I tested the machine...it fills, agitates, drains but will not spin. My husband and I took apart the machine, towards the bottom was this warped rubber oval like belt that we cut off. (thinking we could take it in and get a replacement) But who knows what that was. We live 3 hours away from the city in a small, remote area. Any tips?
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Are you sure you have the make and model number correct? The reason I ask is because the model number you provided is for a Kenmore DIRECT-DRIVE transmission. There is no drive belt for this model washer. That would also explain why there is no belt listed on a repair parts list.
  • 943 Answers
Hi thanks for your question. the part you need is called motor drive coupling, it attaches to the motor and the transmission. the cabinet has to come off in order to get to the part.if you need assistance in replacing this part. lets chat and i will guide you. thanks
Posted on Oct 16, 2008
Smell rubber
i have found that when people start smelling things in the dryer it's from chemicals from like paint or varnish,all the dryer does is move air when it gets hot you start smelling it.you can pull it apart and check the belt and rollers but your dryer has the lint filter on top and there isn't anything in there that could really make it smell,on some of these dryers the belt pulley doesn't have a wheel on it,the pulley is just a piece of metal with no moving parts and the belt rubs on the pulley but i've never smelt anything from that,like i say usually it's from having your floors done over the smell from the polyurethane coating or from paint can make the dryer smell.go here to take dryer apart
http://www.youtube.com/watch?v=xGIG8Wo5-N4
hope this helps
Jan 19, 2014 | Dryers
Notice a "rubber"smell this winter. The lint vent is clean after each use, outside vent is clear of any debris. can the wind blow smell back into house or is it a belt? Installed new by dealer 1/9/13.
I have found that when people start smelling things in the dryer it's from chemicals from like paint or varnish,all the dryer does is move air when it gets hot you start smelling it.you can pull it apart and check the belt and rollers but your dryer has the lint filter on top and there isn't anything in there that could really make it smell,on some of these dryers the belt pulley doesn't have a wheel on it,the pulley is just a piece of metal with no moving parts and the belt rubs on the pulley but i've never smelt anything from that,like i say usually it's from having your floors done over the smell from the polyurethane coating or from paint can make the dryer smell.go here to take dryer apart
hope this helps
Jan 19, 2014 | Whirlpool Dryers
Load was to heavy and I smelt burnt rubber now no spin
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
To replace the belt carefully pry up on front washer top to release plastic keeper pins, remove 2 Phillips screws from beneath lower front washer panel, slightly lift upward on panel to release. Now remove old broken belt, push new belt beneath large tub pulley and put belt on small motor pulley. After this push back belt tension /idler arm, start belt on large tub pulley, turn tub pulley by hand to run belt on, release tension on idler arm. Replace front panel and lower top.
Please check this diagram for the part number F28(drive belt)--
Please post back for any further assistance.
Thanks
Daniel
Jul 24, 2010 | Frigidaire FWS833A Top Load Washer
Washing machine stopped working and smells like burt rubber
Sorry about that I did not notice the word "Belt" in the paragraph. The belt may be slipping. Even though it looks fine it may not be. You can normally tell if you're able to access the belt right after running it, turn off the washer and unplug it. Feel the belt or the idler pulley it's attached to. Quickly though because it may be very hot! If it is then chances are that you need a new belt. Overloading a washer from time to time can wear out the portion of the belt that contacts the pulley causing it to slip.
Oct 29, 2009 | Amana NAV5800A Top Load Washer
Eureka boss power plus
I had this same problem. The brush roll wouldn't spin, smoke came out, and it smelled like burning rubber. I changed the belt thinking that would fix the problem but it didn't, so I took the belt back off and checked the motor shaft in the back and found a whole bunch of hair wrapped around the shaft. Once I cut out the hair with some scissors and replaced the belt, everything worked like normal. I hope this helps.
Sep 01, 2009 | Eureka Boss SuperLite Bagless Upright...
Burnt Rubber smell and spin cycle didn't work
the main motor needs to be serviced , sounds like the couplings broke , hope this helps , AJ
May 18, 2009 | Maytag Dependable Care LAT9416
Washing machine was making noise when agitating & spinning
This sure sounds like a bad transmission. Turn the transmission by hand to feel and listen to it. It should be smooth and quiet.
May 04, 2009 | Maytag PAV2300 Top Load Washer
Belt problem
the brush is jammed most likely or not in correctly
Aug 08, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Maytag Legacy top load washer is SMOKING!
this is a bogus website that is trying to push smelly washer product....no real fixes and there are other products out there for less just use bleach first
May 05, 2008 | Maytag Legacy Series Top Load Washer
Kenmore 22422 Top Load Washer Logo
137 people viewed this question
Sal De
fordexpert
Robert Rankin
