Question about Alps MD 2010 Thermal Printer
ALPS MD 2010 does not work
Hi, this is chris from germany.
i have an old ALPS MD 2010 which worked properly all the years. For a few days I´m not able to start it anymore. If I try to switch it on there is no power-light and the printer does not work.
Can anybody tell me where I find a fuse inside the printer? I hope that this is the problem... I tried to open it but had to fail after taking off the back, the sides and the top. Maybe somebody has also an explosion-drawing? I was still not able to divide all the parts to get close to the power-supply/ energy pack.
THX
Chris
5 Suggested Answers
fcollingwood
  • 58 Answers
SOURCE: Do you repair Alps MD 5000 printer
Unfortunately, this website is not a repair shop, but I'll give you what help I can....
Printhead problems are not repairable in the US or Europe any longer. You best bet is to upgrade to an MD-5500, which you can find here: http://www.alps-supplies.com
Posted on Mar 19, 2008
fcollingwood
  • 58 Answers
SOURCE: lines through my md 1300 alps printer
It sounds like the head has been damaged. Unfortunately, there is no fix for this, as Alps stopped production of these printers years ago, and now do not offer repairs for these printers.
If you still want a dye-sub capable Alps printer, the only model available is the MD-5500, which you can find here: http://www.alps-supplies.com
Posted on Mar 21, 2008
fcollingwood
  • 58 Answers
SOURCE: Alps MD 5000P Vista Drivers
There aren't any.
You can try the XP drivers if you're using Vista 32, but there is just no way to use these printers on Vista 64
Posted on Apr 18, 2008
fcollingwood
  • 58 Answers
SOURCE: Alps MD 1000 self tests okay, but printing gives "nonvolatile error" (fast blink)
This is a symptom of the following:
You are running XP, and have installed SP3 and, you are using the microsoft driver bundled with XP.
The solution:
The m$ driver will have created a printer with "(MS)" as a suffix. Leave this intact, as it will cause major trouble on every reboot if you delete it.
Download the appropriate driver from the Files section in the Alps YahooGroup found at http://tech.groups.yahoo.com/group/Alps/
With your printer unplugged, install the downloaded driver
Shut down your computer and hook up the printer
Reboot
XP will detect the printer, and create a new printer in Control Panel without the "(MS)" suffix
Make the new printer your default printer.
The reason why you do not delete the printer with the "(MS)" suffix, is because every time you reboot, XP will ignore the fact that you have the correct Alps driver loaded, and will create a new printer using the m$ drivers, and set it to default. Of course, the m$ Alps driver is fundamentally broken
Posted on May 24, 2008
NO WAY, XP drivers absolutely do not work in Vista. You will get an error message after "successful installation" telling you that you must have a different version of windows, etc. etc.
(I even bought a BOGUS disc from a **** on eBay stating Vista compatability but was a total lie)
Posted on Jun 14, 2008
Alps md driver error
For the ALPS printers, make sure you are using Windows XP SP2 or older. There are no Win 7 drivers and there can be problems with a Win XP SP3. Join the Yahoo ALPS group. In the files section they have a full description of the problem along with a work around. It usually is a conflict with the bi-directional communication and the LPT port. The LPT port needs to be motherboard based - not an add-on card.
I hope this works.
Nov 14, 2012 | Alps MD 5000 Thermal Printer
Can our ALPS MD 1000 printer work with Windows 7? We used it when old computer had Windows XP on it, but that crashed and bought HP with Windows 7 now... we need Alps to make waterslides for custom rod...
There are NO Windows 7 drivers for the ALPS MD printer. I've read that you can run an XP virtual mode on Win7 that allows you to use the printer. If you are comfortable tweaking the OS, it's a workable option. I picked-up an old (and cheap) laptop on Craigslist and printed my decals from there.
Sep 15, 2011 | Alps MD 1000 Thermal Printer
I'm looking for a vista or windows 7 driver for my Alps MD-1000
There isn't any Vista and Windows 7 drivers for this printer. The manufacturer still hasn't produced any. This is really sad because I have the same printer and I have to stick with XP just to be able to use it.
- HotRatchet
Dec 15, 2009 | Alps MD 1000 Thermal Printer
Turns on and off
I had a similar problem with my MD-2010 printer. It turned out to be a loose wire on the power supply.
May 28, 2009 | Alps MD 1300 Thermal Printer
Alps MD1000 printer.
MD-1000s hit end of support almost 10 years ago. Chances of getting spares are nil.
Best bet is to get a junker of eBay for spares, or you can get a new MD-5500 from http://www.alps-supplies.com
Aug 04, 2008 | Alps MD 1000 Thermal Printer
NEED TO HAVE INSTALL SOFTWARE FOR wINDOWS VISTA
Join the Alps mailing list at YahooGroups. The drivers are in the files section.
Apr 08, 2008 | Alps MD 1000 Thermal Printer
Lines through my md 1300 alps printer
Feb 15, 2008 | Alps MD 1300 Thermal Printer
Alps md 1300 only prints in black
First of all, Alps MD inks do not "Dry up". They are dry to start with!
It sounds like you may be running XP, with the Microsoft driver for this printer installed. You need to load the Alps driver, which you can get by joining the alps or alpsdecal group at http://groups.yahoo.com. You can find the driver in the files section of one of the groups.
Oct 05, 2007 | Alps MD 1300 Thermal Printer
The printer starts to print but no print
a friend of mine had the same problem and after 28 h of searching ist was clear, that not the printer is damaged. No. Windows had made its online Updates (Service packs) and from then on printing failed. Try to reset your Windows OS to the date, when the Alps worked properly and i think it will work again. I can give you no fo further Information about windows settings, sorry i`m a Mac user.
I dont have these kind of Problems. Think about it !!!!!
Greetings from Germany
Sep 07, 2007 | Alps MD 2010 Thermal Printer
Alps MD 2010 Thermal Printer Logo
61 people viewed this question
Top Alps Office Equipment & Supplies Experts
Jeremy Murray
Jeremy Murray
Jesse Walters
Jesse Walters
Andrew Taylor
Andrew Taylor
Are you an Alps Office Equipment and Supply Expert? Answer questions, earn points and help others
