Televison & Video Logo
Michael Parshley Posted on Nov 15, 2011
I have SAMSUNG UN55C6400 with a broken screen, Where can I get a replacement screen for this TV?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 05, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
104
Points
I have a Genuine Samsung BN07-00855A LCD Panel still in sealed box from samsung. My neighbor's tv repair company went out of business.
  • Anonymous Feb 16, 2013
    Hello, I understand that this was posted almost a year ago, but did you get rid of the LCD panel, or do you still have it around?
I have Samsung UN55EH6050 TV with sound but no picture
check this out..
Samsung power defect causes some TVs to fail and class action suit follows
Watch this video.. ( I did mine - three times - before I bought a LG).. its not hard.. just a little time... the local TV repair shop can install these for you..
Samsung TV Won Turn On How to Repair Bulging Capacitor for Clicking Noise
watch the + and - sides when installing..
Samsung LCD Plasma TV Capacitor Repair Kit Replacement Parts
Samsung LCD... Power supply, t-con or inverter?
Samsung LCD TV Repair - TV Won't Turn On - How to ...
? 8:22
https://www.youtube.com/watch?v=n54IurMvr6o
Apr 4, 2014 - Uploaded by ShopJimmy.com
So in this video today we are going to be looking at a Samsung LCD and how to diagnose if you have a bad main or a bad power supply.
Samsung LCD TV Fixing Power Supply Problem - YouTube
? 10:52
https://www.youtube.com/watch?v=F6qgCg8lsxc
Dec 23, 2011 - Uploaded by Studio G Vision
Samsung LCD TV Fixing Power Supply Problem. Studio G Vision .... How switch mode power supplies (SMPS) work - Duration: 19:22.
Samsung LCD TV Power Supply Repair, Capacitor Replace ...
? 25:23
https://www.youtube.com/watch?v=lL0id3-YZsQ
Feb 9, 2013 - Uploaded by HandySavesMoney
... LN46A630 LCD TV. This procedure will apply to several otherSamsung TVs. ... Samsung LCD TV Power Supply Repair, Capacitor Replace, LN46A630. HandySavesMoney .... Country: Worldwide; Restricted Mode: Off.
LED TV pulsing
How many have 'blinking' issue with Samsung led tv - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJan 26, 2011 - I am trying to get the number of people affected by this nagging blinkingissue with the latest Samsung led tv's. If possible it would be useful to ... Samsung LCD TV Screen flickering (LN55C630K1F)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung LED with flashing standby light on front
Apr 17, 2014
More results from www.cnet.com
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical ...
Samsung 55unc6400 will not turn on
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
I have anew Samsung 55 inch model code ue55h6500akxxu but it will not store my settings as soon as i turn tv off an on again it goes back to custom settings
This is from an article I found online:
"It's likely that the television is in Shop Mode. The symptom would be that your settings are defaulted back to the out-of-box settings?
Try holding down the Menu button on the TV (Not remote) for 12 seconds.
OR
Try pushing the volume button up once, let go, and then hold down the MENU button for about 12 seconds.
You might see the screen flicker, and that's okay. Once you've done that, you should be able to program your settings and they should stay.
--HDTech"
How do I adjust my screen
Look for picture size or zoom on remote...
TINY WHITE SPOTS ARE APPEARING ON THE SCREEN OF MY SAMSUNG DLP TV, IS THERE ANYWAY TO FIX THIS PROBLEM?
The DLP chip is failing and will have to be replaced, very expensive. You can call samsung at 1-800-samsung to find the closest service center.
2answers
An 55 Samsung UN55C6400RFXZA Model/Code will be auctioned off tomorrow night. How can I reseach this model? Is it a LCD or LED. It's ultra slim
Hi
Thanks for using FixYa. The Samsung UN55C6400RFXZA is an LED TV; please check this link for more information. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
