Question about Dishwashers
Dishwasher has no power - Dishwashers
  • pkliu Apr 05, 2009
    Is there is transformer in the dishwasher?  A couple weeks ago, several transformers were burn out through out my house (for phone, game console....)  I wonder the same thing happen to the dishwasher.
    Thanks
    -PK
First check the circuit breaker panel in your home for the breaker for the dishwasher. See if it has been 'tripped'. Re-set it if that is the problem. Try the washer again.
If that isn't the problem. I have another possible solution that I just discovered with my KitchenAid. It takes someone who knows how to work with appliances to fix this.
There is a device that is like a fuse called a thermal cut off. It is in series with the door switch (makes sure the dishwasher door is closed). In my case this thermal cut off was the culprit. It looks a cylinder the thickness of a pen refill, is about a quarter inch long and has what seems to be a cone shape at one end of it. Wire/ leads are coming out of each end. In my KitchenAid, this small device was housed in a plastic block with two larger connectors that could be detached. I was able to disconnect the two connectors and then un-snap the plastic block with the thermal cutoff device in it. I used a ohm meter to test it and it was open (that is, it was like a blown fuse). I don't think it could be much more than $5 to $10 to replace this small unit. I'll be doing that tomorrow. I was able to prove that that was the culprit by shorting out the two connectors that had gone to the thermal cut-off with an alligator clip. The washer lit up immediately. He careful this device is carrying the 110volts. It is not a replacement for amateurs.
Posted on May 15, 2009
    Novelist:
  • 171 Answers
Hi deborah-333,
I'm Harvey the Master Plumber.
Your problem is: no power
First check breaker (fuzes), if breaker is good then check the connection at the d/w. It's under the d/w behind the kick plate on right or center under a cover box. 9 times out of 10 you'll find a loose, broken or burnt connection there. That done, it's time to call in warranty repair. If beyond warranty you might consider utilizing the Repair Directory to find a repairman. If the d/w has a few years on it perhaps it is time to compare the cost of repair verses replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 27, 2008
My dishwasher does not power up?
How to Fix a Dishwasher That Won't Start ' Dishwasher Repair
www.partselect.com/Repair/Dishwasher/Will-Not-Start/
When your dishwasher won't start it can be frustrating. ... The selector switch on adishwasher is used to select different options for the individual cycles, such as ...
Dishwasher Will Not Turn On - How To Fix ...
removeandreplace.com/2014/.../dishwasher-will-not-turn-on-how-to-fix/
Oct 6, 2014 - If your dishwasher won't turn on or start, here are a few things to check ... My Frigidaire dishwasher Model # FGID2474QFOA is only a year old ...
Dishwasher has no power - YouTube
? 4:38
https://www.youtube.com/watch?v=pp5P3Cvy9qA
Mar 26, 2010 - Uploaded by ApplianceHelpOnline
If your dishwasher has no power watch this video. For more free videos,parts,service manuals, free expert ...
What to Do When the Dishwasher Won't Start -
Jan 18, 2016 | Frigidaire Dishwashers
What does pf mean when it comes up on my dishwasher model no. fdb2320rec2
POWER FAILURE.. you lost power to the dishwasher either whole house or just dishwasher,,,not sure why we need the dishwasher to tell us that we lost power, but too many can cook the control board,,,did mine. good luck
Mar 18, 2014 | Frigidaire DGBD2432K Dishwasher
Why isnt my dishwasher powering up
assuming the power circuit breaker is ok and you are getting power to the dishwasher itself, there are other factors that could lead to an outcome of dishwasher not appearing to be powering up.
The most likely cause is power supply inside dishwasher is faulty, the controller is faulty or simply the dishwasher display panel is faulty.
More likely the dishwasher has suffered a "thermal" trip. The thermal fuse located in the control panel on the door has blown. You may need to replace it. It is item 6 on this diagram
Jan 04, 2013 | Whirlpool GU2400XTP Built-in Dishwasher
Why does my dishwasher not have any power?
More likely the dishwasher has suffered a "thermal" trip. The thermal fuse located in the control panel on the door has blown. You may need to replace it. It is item 6 on this diagram . ( i have already responded to your earlier post)
Jan 04, 2013 | Whirlpool Dishwashers
My dishwasher froze and i have no power lights on it. I think we need to reset the dishwasher? how do i do it?
I am not an expert in dishwashers but most appliances do a hard power reset by removing the power supply for at least 15 seconds.. You might be able to turn the circuit breaker off for power(ie 15amp)in your power box for your house as your dishwasher is probably hard wired..*NOTE. If it has its own power point-turn that off only***
Aug 26, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
No power
well if your main power that supplies the dishwasher is good then you need to replace the main control unit of the dishwasher
Jan 31, 2010 | Dishwashers
How do I reset an old Bosch dishwasher SHI4302UC ?
Assuming that you can control power to the dishwasher from your kitchen panel switches, hold down the power on switch on the front panel of the dishwasher and recycle power (switch off and on) at the kitchen panel switch.
This will reset the dishwasher.
Sep 26, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
DISHWASHER WONT POWER UP
HI, there are four problem spots that i recommend checking. these are the most common hot spots for a non responsive dishwasher. Check each area thoroughly to address this issue.
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Jul 13, 2009 | Dishwashers
My dishwasher will not start: Most common d/w power is 120 volts, check for 120 volts with a volt meter at the main power harness where it enters into the dishwasher, you will have to remove the lower access panels to get to the power box. Dishwashers also have at least one and most newer dishwashers have two door switches that must be checked. You will find then behind the console at the door latch area. Each manufacture has different designs but this is a picture of what some of the newer dishwasher switches look like.
Feb 19, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
438 people viewed this question
Top Dishwashers Experts
