Question about Bosch 24 in. SHU53 Built-in Dishwasher
Bosch Dishwasher Model SHU 5317 UC
I replaced the control module but it still is not working correctly. No water delivery and the machine runs on after cycle end. If I manually add water to the bin, it pumps it right out upon cycle start-up.
SOURCE: bosch dishwaher shu 4322 uc/u12
remove outer door skin and kick plate at base pump will be on view turn off power look carefully at pump you will see a lever you have to cut away a small section of plastic on lever to be able to push it inwards pump then twists off anticlockwise is a bayonet fitting like a light bulb.
hope this helps
Posted on Jan 23, 2008
SOURCE: Bosch builtin 60cm SGV4313 dishwasher
many thanks however intend purchasing new machine
Posted on Sep 15, 2008
  • 98 Answers
SOURCE: Our Bosch SHU 4300 dishwasher does not drain fully
There is a recall on the control board of many of these models, butyour problem is likely not related. A sticking impeller indicates that the pump may be failing, but you are welcome to try my guide to help. It is here. Thanks!
Posted on Jul 19, 2009
SOURCE: Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Posted on May 25, 2010
  • 11 Answers
SOURCE: I have a built-in Bosch
The problem is a solenoid on the bottom of the unit. It is a small black cylinder next to the pump. It operates the valve that changes to the drain cycle. You can probably order one from Bosch
Posted on Aug 18, 2010
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
Bosch dishwasher time delay problems
Bosch Dishwasher Repair
When the display is stuck on 2H it often means the heater is not working. If the water is not heated, the cycle will never complete. It is possible the heating element is bad, but a more likely problem is with the control module PC board. The solution requires some basic repair and soldering skills plus the tools to do the job. Bosch recommends re-soldering the connection to the heating element relay (see page 11 of "SHU/SHI/SHV Dishwasher Troubleshooting Tips") free download here
The problem is that the circuit board copper is not heavy enough to handle the heating element current, causing the copper to heat and melt the solder connection. A better solution is to solder a short length of copper wire between the two pins to provide more copper and reduce the chance of heating as shown in the attached photo.
Jan 11, 2013 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Hot water fills with hot and cold not strictly hot what is the fix
see the causes: and proceed with common sense. God bless you
Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine isn't working the way it used to--or should--try these tests: Is the hot water turned on? If not, turn it on. Is the washer getting cold water but no hot water? If so, check to see if the control panel settings are correct. Is there hot water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine is not working the way it used to--or should--check the following. Is the cold water turned on? If not, turn it on. Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct. Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the
Sep 22, 2012 | Roper Washing Machines
When trying to wash with hot water only machine fill slows and adds cold water then adds hot this continues until load level is reached and you end up with barely warm water is there any way to fix this...
see the causes and use the common sense. God bless you
My washer has just started to leave about an inch of water in the bottom of the tub after the cycle is complete, leaving my clothes soaking wet. How do I get the water out?
Hi.
The problem is either caused by a drain system fault or by a defective pressure switch.
Check that height and setting of drain hose at the back are correct. If the hose is not set correctly (check manual), then water will flow back inside the appliance. The problem is called siphoning.
Make sure there is no drain system blockage. Inefficient drain because of blockage results in soaked water. Check hose connected to pump located at the base of the washer.
Check and eventually replace the pressure switch. The pressure switch detects water level and determines when to stop the spin part of the cycle. The pressure switch is located in control assembly, near to control module. Clean the long rubber hose connected to the switch.
Inside the control assembly look also for an envelope containing the tech sheet. The document will contain the instructions to run diagnostic cycle in this model. Run a diagnostic cycle.
Regards.
Ginko
Aug 29, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Water will not spin out. Code says 5d
The troubleshooting page in the owner's manual says: 5d "Sd" Suds Detected - Did you use regular detergent? Regular or hand-washing detergents are not recommended for this washer. Use only High Efficiency (HE) detergent. Did you add too much detergent? Always measure detergent. Follow detergent manufacturer's directions. If excessive suds are detected, the washer will display this code while running a suds reduction correction routine at the end of the wash cycle.The susds reduction routine removes extra suds and asures proper rinsing of your garments. If te code remains and the wash cycle dial is flashing after the recovery routine has stopped, re-select your desired cycle using cold water. Press start. Do not add detergent.
Dec 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My Bosch made a moaning sound and never got water to wash dishes. I tried to cancel the cycle and it would not cancel. I am guessing I have a bad controller? Can you tell me how much that piece would...
A solution to this problem would be to sell me your dishwasher. The law firm for which I work is looking to acquire an old unrepaired Bosch SHU 33 dishwasher for some ongoing litigation. If you (or anyone else with this model Bosch) could send me some details regarding your dishwasher, you may be able simply to buy a whole new dishwasher. My email is JFraser -at- jshlawmi.com.
Thanks!
Sep 10, 2010 | Bosch 23 in. SHU3302UC Built-in Dishwasher
I have a built-in Bosch dishwasher SHU 4302 UC. It no longer drains the water out at the end of all the cycles. I have tried everything mentioned in the booklet (make sure water is hot, use the jet-dry...
Aug 18, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU53 Built-in Dishwasher Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
