Question about Microsoft Windows Vista Ultimate Edition
Burner not installed message
My PC is not 3 months old and I have already taken it back for a message saying I have no burner installed and eratic performance everywhere else !!! When I took this new 2 gig Vista home I couldn't get it set up right because things would not load properly, and I was told they had to "repair" it...free that time since itr wasn't a day old I guess....they charged me 45 diagnostic???...I already got the message on screen but they did nort include the burner driver in the CD software and when I ask find a way to put it off. Now this is trhe third time and all I need is ther software the way I see it...OR realy a brand new computer that does not need fixed "repaired" the first day out of the box. Can I inmstall a burner online?
  • 37 Answers
James, I have found in the past that many computer manufacturers only install a trial version of some software. One major manufacturer, who shall remain nameless custum built a P.C online that included a CD burner, but I found out later that even though they installed the burner, they provided no burning software. It sounds as though you have no CD burning software installed. First, from the start button, go to control panel, then to add remove software. A list will compile showing all software installed on your machine. If you do not have a CD, or DVD burning program installed and your computer came with no CD's( most today do not) that may contain that program, you will probably have to buy your own at this point. Just to clarify, do you only have a CD burner, or is it a CD burner/ DVD ROM, or do you have a DVD burner. If you have a DVD burner, then you are capable of burning both CD's and DVD's. If you need to purchase burning software I would suggest you do an internet search for Nero, This is the software that I use. It works well in addition to being easy to use.On the Nero site I have in the past purchased their OEM version, the OEM versions are usually available at very good prices. I prefer to purchase software online and have a disc mailed to me as opposed to downloading it online just so that I have a hard copy if I ever need it. If you are limited to burning CD's, just get the CD software. If the device you have installed in your computer is a DVD burner, then purchase the DVD software and you can burn on both formats.
Posted on Sep 29, 2008
"Relearning" process for re-installation of blend door actuator motor (if necessary) on 1997 Ford F150.
There is no process, just make sure the battery negative cable is disconnected before install the part.
Apr 19, 2017 | Ford Cars & Trucks
Installation
uninstall the printer completely and then try installing it back
Aug 23, 2008 | Canon PIXMA MP470 All-in-One Printer
I have a lexmark x1240 and just installed a new cartridge. I keep getting an error message that says " print cartridge missing" install print cartridge even though both cartridges are in the printer.
If you insert the old cartridge, does it recognize it? If it does, then it's a problem with the new cartridge. Try to check if you already have taken out the protective tapes out of the cartridge.
If it still doesn't recognize the old cartridge, then it's a problem with the printer.
Nov 29, 2012 | Lexmark X1240 All-In-One InkJet Printer
It was burning fine but now it says connect to a borner
If the dvd drive still plays cd/dvd but does not burn anymore then the burner is already defective or it could be that it's just the software or driver of the burner which has a problem on it. Do a system restore which restores your computer back to the date when it was still working fine. It won't delete any saved files in your computer except the programs that you have installed there. Any you can install those programs again.
Remember the date when your burner was still working fine because you need it during the system restoration.
Here are the steps on how to do the system restore:
1. Go to start/window button>All programs>accessories>system tools>system restore
2. Then, select a restore point or date when burner still worked fine. Click next and confirm it.
3. Just let the computer to restart. The computer will tell you if it is successful or not. If it's not successful, do the same procedure but you have to select a different restore point.
4. If the restoration is successful, check whether the burner is working already.
If the burner does not work after the restoration, then, it's time for you to replace the dvd burner in your computer.
I hope this helps.
Thank you for choosing fixya.
carloadrian
Feb 03, 2011 | Computers & Internet
Unrecognised disc drive
Hmm! take it back to the dealers under warrranty seems like a good idea ?
Jan 03, 2010 | Compaq Presario CQ60-220US PC Laptop
I have a memory card that hold 700 or so pictures,
It could be, that what you are seeing, is the INTERNAL memory is being taken up with your pictures. Connect your camera to your computer with a USB cable and you will probably find them.
Oct 04, 2009 | HP Photosmart M417 Digital Camera
Dishwasher water at bottom of well.
That little plate has to be gently removed with a screw driver and a hammer.
Apr 01, 2009 | Dishwashers
Camera no longer working
Your memory card must have had the switch moved from locked to unlocked. To fix this, removed the SD card from your camera. Look on the side and you will find a little switch. One end of the switch says locked the other end says locked. Move the switch from locked to unlocked. Replace it in your camera and turn it back on. Try it and let me know if I can help more.
Feb 17, 2009 | Kodak EasyShare C330 Digital Camera
When i attempt to go to the phone screen it goes blank and remains blank ie black. i have two month old 3g i phone. thanks
What you are describing is pretty common. Unfortunately, the only solution is to reset your phone. :(
Sucks, I know, but here are the directions in case you resort to it:
  1. Turn off iPhone - Hold down the Sleep/Wake button for a few seconds until the red slider appears, then slide the red slider. Ignore this step if your iPhone is already off.
  2. Press and hold down the Home button for about 10 seconds until a yellow triangle with a text which says Please Connect to iTunes appears. iphone-recovery-mode.jpg
  3. Plug the iPhone into Mac or Windows PC. Release the button if you haven’t.
  4. Run and open iTunes if it’s not already opened yet.
  5. iTunes will prompt a message that says iTunes has detected an iPhone in recovery mode. Click OK.
  6. You will be taken to the iPhone pane. Then, click on Restore.
  7. Wait for the full restoration process to complete, and the iPhone will be back to the original settings state as when it left the manufacturing factory, typically a working phone again if you face any problem, unless it’s hardware related.
Dec 02, 2008 | Apple iPhone Smartphone
Microsoft Windows Vista Ultimate Edition Logo
94 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
