Question about Dryers
Kenmore dryer won't stay on. Starter switch works, but as soon as you take your finger off the switch it shuts off
  • gramschris Sep 27, 2008
    When the problem started, it shut off mid-cycle, when it was running. Could a door switch do that? BTW; It's gas dryer.
  • gramschris Dec 01, 2008
    After a lot of diagnostics, it was the main circuit panel ($150+labor). I should have just purchased a new dryer.
  • 943 Answers
Hi thanks for the question i would look at the door switch also check to see if the belt is broken thanks the appliance doc
Posted on Sep 27, 2008
  • john gagnon
    john gagnon Sep 27, 2008
    or a broken belt
Dryer won't stay on without the button held in
Most likely the motor relay or the even heat board is bad.
Oct 06, 2017 | Kenmore 74992 Gas Dryer
My Kenmore 80 series dryer won't stay on unless I
Aha!
You are going to make me guess!
I am guessing you have to hold the start button down.
So.
Try a new start button first.
If that does not fix it, replace the timer/control unit.
God bless your efforts.
Jan 05, 2018 | Kenmore Washing Machines
I have to tape or keep my finger on the start button for my Kenmore Elite 64982 to run. Could it be in the starter switch?
http://fixitnow.com/wp/2009/03/17/easy-fixes-for-two-common-problems-with-the-whirlpool-even-heat-dryers/
Nov 27, 2010 | Kenmore 64982 Electric Dryer
Dryer shuts off when let go of the on button
If the motor stops when the button is released check the motor relay switch. If the motor runs but the flame goes out check the flame sensor.
May 19, 2009 | Dryers
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Dryer will not run
Hello tomechkojr,
Many dryer motors have a centrifcal switch on the motor that should allow the motor to continue operating after you remove the momentary start switch. Chances are, that motor switch is hanging up and not actuating to keep power on to the motor. Keep me posted and I'll follow along with you to help..
Regards
Rick
Nov 23, 2008 | Kenmore Dryers
Start Button will start dryer but won't stay on!
pull end caps off just grab at top of plastic and pull towards you remove the 2 screws underneath lift console up and roll back next to timer is a small control bd to right of that are 2 relays 1 with red wires for element and 1 with blue wires for motor first try switching the relays they are identical and will work for either 1 ..try if works replace relay ..if still not working suspect control bd
Jul 01, 2008 | Kenmore 63952 Electric Dryer
Kenmore dryer mod. no.110.64972301
replace the motor the start winding is staying in and the run winding is not kicking in
May 16, 2008 | Kenmore Dryers
Dryers Logo
202 people viewed this question
Top Dryers Experts
