Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
Model# 110 20902990 kenmore washing machine over flows
Our washing machine is over flowing sometime about every 3rd wash, when it is filling up at the begining and just before it goes into the ajatator mode it continues filling than starts overflowing. At times it will pass this cycle and when it drains after washing than start spinning than fills again it sometime continues to fill and starts overfilling.
Can you helpme?
Pat
  • 943 Answers
Hi thanks for the question you could have a water valve problem how do you shut the water off by unplugging power cord or shutting off water supply if its unplugging the power cord you have a problem with water control switch or lint is caught in small plastic tube that goes to the water level switch check that could be no parts needed thanks the appliance doc
Posted on Sep 27, 2008
Water still trickles in after the entire wash cycle is completed
Check the flow meter first. The flow meter has a reed switch on the side of it. Sometimes this switch fails and doesn't respond to the magnetic wheel inside the flow switch. It is suppose to provide a pulse action as the wheel turns. The CCU interprets these pulses to determine flow rate. Just because the wheel inside the meter turns, does not necessarily mean the reed switch is functioning.
Apr 02, 2008 | Kenmore 44102 Front Load Washer
The washing machine doesn't fill with water - it
WATER LEVEL SWITCH MIGHT BE BAD. SOME MODEL HAVE A FLOW METER. DISCONNECT THE WATER HOSE AT THE WATER VALVE AND SEE IF ANY DEBRIS IN THERE
Jan 24, 2010 | Kenmore Washing Machines
Kenmore 110 Washer fill hoses flowing the wrong way...
Both hoses must be connected to a valve or capped off.
Jun 08, 2009 | Kenmore Washing Machines
Kenmore Elite washing machine will not fill as fast as usual.
You will need to get behind the washer, turn the water off, disconnect the hose from the washer, look for a screen inside the water valve, hopefully there is one that you can clean if necessary. I always put the hose over in the washer and turn the water on to check the flow.
If the screens on both hot and cold are clear, water flow is good on both hot and cold, connect the water back to the washer. If the flow is still slow then the problem is inside the valve. The valve will have to be replaced.
Dec 17, 2008 | Washing Machines
Over flowing washer
If the water valve not getting 120 volts and its start filling that means its bad water valve if its getting 120 volts bad timer
Nov 03, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 110 washer
if screens on both ends of cold fill hose are clean replaced valve have seen restricted flow even with good flow to valve but be sure screen in valve is pulled and cleaned be sure to reinstall it
Aug 01, 2008 | Kenmore 22422 Top Load Washer
Water flows into machine when off
Carmel, I've seen this a number of times on the HE3, you are going to have to replace the water inlet valve. Since it's filling after the end of the wash the pressure switch is not going to detect the fill. The valve is not closing properly. If you post the model number I can give you the part number. It's an easy fix, remove the top and the valve is right there. If you need any assistance in changing it you can email me at stp43ron@yahoo.com Catriver..post back.
Nov 09, 2006 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
412 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
