Question about Kenmore 62602 Electric Dryer
Stackable washer dryer
We just moved in and connected our washer/dryer. The dryer works but not the washer. It's connected to a 220 electrical plug.
  • 943 Answers
Hi thanks for the question the washer has a separate cord for 110 volts see if its plugged in thanks the appliance doc
Posted on Sep 27, 2008
I have a stackable Frigidaire washer/dryer combo and the problem is that when you push the start button, you hear an electrical buzzing but the dryer won't start. When you take the panel off it st
Hello Mike Brady - From what you have described it seems like the dryer is experiencing a wiring failure or a communication error with the control board. Contact a professional to move forward accurately.
Jan 08, 2013 | Frigidaire FEX831CS Top Load Stacked...
Can I change the 220 plug on the stackable unit from a 4 prong back to a three prong.
Yes you can. Green in the middle and red and black to the matching sides coming in from above the block where your connecting the cord
May 07, 2012 | Kenmore 98702 Stacked Washer/Dryer
I am trying to hook up my stackable washer and dryer. I havee a 220 plug 30a what do I need to do so I don't have to go back to home depot and get whole new plug in and plug?
If the unit has a 30 amp/220volt plug, then you will need a dedicated 30 amp outlet from a 220 volt line from the panel. You can not switch the plug to work with a regular (15-20 amp) outlet. Have an electrician install a 10 gauge 220 line from the panel to the unit. good luck!
Aug 30, 2011 | Whirlpool LTE6234D Top Load Stacked...
I just got a used kenmore model number 110 88752792 stackable washer and dryer. it had a 4 prong cord.I live in a travel trailer, it has a 24 inch wide space for a stackable washer and dryer that the 110...
You will need to get 230v to allow the dryer to work if your service panel has 230 you will need to get a 30 amp two pole breaker and run 3 wire #8 in size. Then get the socket and plug for the dryer. The 110 in the model number simply means made by whirlpool and is a pretty good machine but requires 230 volts to dry with heat.
Jul 28, 2010 | Dryers
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
I WANT TO KNOW IF THE MODEL DVLR223 CAN CONNECT TO 110
THE ONLY DRYER I KNOW THAT CAN CONNECT TO 110 IS A FEW STACKABLE washerr and dryer combo, if its a 220 dryer no you can not connect to 110, it has to be 220,
Feb 19, 2010 | GE DVLR223 Dryers
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Plug in for washer on a Kenmore stackable washer/dryer
the washer works off the 220v cord on the back you have other issues with the washer sorry
Jan 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 62602 Electric Dryer Logo
125 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
