Question about Electronics - Others
No led Techwood S.S Reciever, no lights on panel just standby an mute. both lights are working cant find reset anywhere on unit?
  • 88 Answers
I can not get your info compleltely .
do clearly.
Posted on Nov 13, 2008
My techwood freeview box was working i feel aaleep n woke to a black screen & my freeview box appears to be atuck in standby mode. Can you help please?
Hi Yvonne
"FreeView"
You must be in Australia. Like me.
I would assume that you have pulled the power out & reset the unit. I don't have the freeview box but they can be similar to other set top boxes.
Does the user manual indicate that holding down certain buttons on startup will cause a reset?
Some of these units have an internal backup battery to keep your parameters in memory. Often not user accessible.
But in emergency, the battery (if you find it) can be given a quick short with a jumper wire to reset it.
Otherwise You might need a tech to look at it or swap it out
Good Luck
Apr 02, 2015 | Televison & Video
I have a Denon AVR1603, recently I plugged computer in AUX connections at rear (not loud) and it kept tripping out. Eventually it tripped and now the the on/standby light fashes but nothing else happens....
The LED flash indicates that unit goes into protection. Check the power transistors, the 0.22 ohm or 0.47 resistors in the output of the transistors.
SAM ANDERSON
Sep 29, 2008 | Denon Audio Players & Recorders
Techwood twp 4210 media box
DEAD AV BOX NO POWER LIGHT
UNPLUG FROM THE MAINS
UNSCREW THE TOP CASE
UNPLUG THE 2 SOCKETS REF PICTURE ( TECHWOOD AV BOX RESET AND UNPLUG )
LEAVE THEM UNPLUGED AND “PLEASE BE CAREFUL AT THIS POINT” SWITCH THE MAINS BACK ON AND SWITCH THE POWER ON THE AV BOX, IF YOU GET A RED LIGHT SWITCH THE SET OFF.(PLEASE NOTE THE RED LIGHT MAY NO ALWAYS COME ON, SO DONT BE ALARMED).
PLUG BOTH THE LEADS BACK IN AND SCREW TOP CASE BACK.
CONNECT ALL BACK UP AND YOU SHOULD BE WORKING NOW
JOB DONE HARD RESET.
Let me know if you need any further help
thank you for using fixya and good luck
Apr 15, 2008 | Televison & Video
Techwood TV won't turn on
no you just need a new power supply and mainboard in this unit!
Jan 21, 2013 | Televison & Video
Danfoss rx1 thermostat shows 'of' ?
Remove batteries from room stat,turn off the electrical supply to reciever unit.
Turn back on the electric to reciever unit,the red light should be on,press the top "manual" button,the green light should come on and boiler should fire (assuming the programmer is in an "on" period)
Press the bottom button,and keep it pressed,then press the top button until the green light flashes,stand about 6 feet away,and refit the batteries to the stat while observing the reciever unit,either the red or green light (cant remember which) should flash to show the 2 units are syncronised.
Another basic test if all seems ok,when turning the stat up or down,when the green light on the reciever unit comes on or goes off,its usually accompanied by an audible "click" ive found,that if this is not happening, the reciever unit does not switch either on or off,may be intermittant.
Replacement is the only cure.
garden led light
Jun 04, 2012 | Garden
2yr old Pioneer pdp-506 50" panel with seperate receiver unit
YOUR MAIN CONTROLLER IC (processor) is damaged you cant try ressiting it but I'm sure it wont work you need to get it professionally repaird by a qualified technician
Jan 02, 2008 | Televison & Video
Sony KDL-40S20L1 Flashing Standby Led, No pic, No Sound
try some of the solutions on this link hope one will work for you. http://www.docs.sony.com/release/KDL32S20L1.pdf look under troubleshooting for no picture good luck
Aug 25, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
My pioneer vsx 815 amplifier has a flashing blue standby light. Have tried resetting by pressing enter and advanced surround keys. All it does is flash a few other LEDs and then goes back to the flashing...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-815-K-Receivers-manual/id/385dj989/t/2/
"enter and advanced surround keys"? I don't see that documented as a special function in the manual.
BTW: other than the Flashing light, is there a malfunction?
Page 72 describes how it REALLY resets...
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
Mar 04, 2011 | Pioneer VSX-815-K Receiver
Samsung flatscreen wont turn on but red light is on showing power ..my son used sleep timer last night
with tv in standby press INFO / MENU / MUTE / STANDBY on remote tv will come on with service menu DO NOT CHANGE ANY SETTINGS
look at list you will see reset
ONLY USE DOWN NAVAGATION KEY until RESET is highlighted
then PRESS RIGHT NAVAGATION KEY the tv will reset
PRESS STANDBY TO EXIT
the tv will need retuneing after
hope this helps
Dec 19, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Nad 712 output issues - Mute flashing
The only thing I can tell you for sure is that the mute indicator always flashes (very dimly) when the receiver is off.  I have no idea why, but mine has always done this.
Jan 23, 2007 | NAD 712
Electronics - Others Logo
115 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
