Question about Miele H4900B Electric Single Oven
Miele h900b oven
The oven won't turn on. After flipping the main breaker of the kitchen off by mistake, when I turned the breaker back on, only the oven would not work. I believe the oven is still receiving electricity because there is a slight glow where the digital clock and oven temperature are displayed. Any ideas?
SOURCE: MIELE H 4641 PYROLYTIC OVEN
I HAVE THE SAME PROBLEM. KEEP HAVING TO TURN IT ON AND OFF TO USE IT.
Posted on Jan 05, 2010
paulc118
  • 15 Answers
SOURCE: Miele steam ovens
A dedicated circuit is recommended. 208-240V 20A L1 L2 & Ground, Neutral not required.
Posted on Feb 27, 2010
Testimonial: "Thank you excellent"
rickead1
  • 1998 Answers
SOURCE: H4681 miele oven touchscreen is
do you have any error code there site says exactly this Switch the appliance off. If the door lock will still not open this may indicate that there is a fault that needs to be investigated by an engineer. if you get an error code message me back the code here are what a couple mean What does error code Fault 23 mean? The temperature required for pyrolytic cleaning was not reached.
This could have been caused by too much soiling in the oven to start with.
Remove all coarse soiling before starting the pyrolytic cleaning programme again.
If the fault message continues to appear this may require further investigation by an engineer
What does error code Fault 33 mean?
This means that the door lock for the pyrolytic cleaning process will not open.
Interrupt the pyrolytic cleaning programme by switching the oven off.
If the door will still not open this would indicate that an engineer is required
What does error code Fault 32 mean?
The door has not locked for the pyrolytic cleaning process.
Switch the oven off and start the pyrolytic cleaning process again.
If the fault code continues to appear an engineer may be required for further investigation
please message me back with any further questions you might have and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
Posted on Dec 03, 2010
  • 10865 Answers
SOURCE: Oven does not get up
Hello tim.... When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Joe
Thanks for choosing Fixya!!
Posted on Mar 06, 2011
pctech1
  • 1940 Answers
SOURCE: The lock symbol is appearing
To deactivate the system lock:
  1. Press the "On" control to activate the display.
  2. Call up the SETTINGS menu.
  3. Call up the SYSTEM LOCK submenu.
  4. Select the touch control next to "Do not accept" and confirm by touching "OK".
  5. Press the "Off" control.
To activate the system lock:
  4. Select the touch control next to "Accept" and confirm by touching "OK".
Using the system lock:
  • Select the touch control next to the Unlock symbol and confirm "on". The oven cannot be operated now. The Lock symbol indicates that the lock has been activated. The timer can still be used while the lock is on. The system lock remains active even after a power cut.
  • To switch the system lock off call up the Lock symbol and confirm "off". The oven can now be used.
- Note: If the system lock is activated for more than 4 days, the oven clock will have to be reset.
Posted on Apr 24, 2011
Some touchpad buttons don't work but some do. Cancel button for bottom oven doesn't work. Have to flip breaker to turn off. CLock works
Jenn-Air WW30430P Oven User Manual - ManualsOnline.com
fitness.manualsonline.com > ... > Jenn-Air Oven
Free kitchen appliance user manuals, instructions, and product support information. Find owners guides and pdf support documentation for blenders, coffee ..
Sep 24, 2015 | Jenn-Air WW30430P Stainless Steel Electric...
How do I get the ovens working if the clock works, but they do not?
You'll have to make sure that the clock has been set for Manual cooking and not inadvertently set it on Auto. However if your breaker tripped because of a fault on your oven the internal switching of the timer may have been damaged as a result of the fault.
Nov 10, 2014 | Viking VEDO205 Electric Double Oven
Self cleaning oven won't start
Hi bstetson328 - Try resetting the range by either unplugging it or flipping the household circuit breaker off. Wait approximately 30 seconds and turn on the unit. Select the self clean option, if it does not turn on then the temperature had tripped the internal sensor of the unit and needs to be reset. This usually has to be done by a professional since the back panel needs to be taken off and the power reset inside. Possibly the unit may have a communication problem with the EOC and I would suggest contacting a professional to move forward accurately.
Nov 10, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Stove went completly dead during self cean no power door remains locked
Check the breaker for your kitchen even if it isn't flipped, flip it off and on again.. I had the same problem it turned out that my dryer and stove were on the same breaker, so I couldn't run them both at the same time.
Aug 03, 2012 | Samsung Induction Range FTQ307
Have Whirlpool electric range super capacity 465 with accubake system oven will not shut off
Karen, We are sorry to hear about your Oven. We are happy to look into your concerns but we will need your your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
Jun 12, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
We have a Kitchen Aid Electric stove about 10 years old and there was no owners manual left from the last owner. This week we turned on the oven and there is no heat from the elements on both the bake and...
The first thing I would check is the breaker for the oven at the breaker box. I have encountered similar problems and a partially thrown breaker ( or one pole of a double-pole breaker) can cause this. Find your "range breaker" in your breaker box and cut it off then flip it back on. There is a good chance that might fix your breaker. If it is an older house with fuses, then the range would be on two fuses and one of them is blown. This happens to dryers also (if the right fuse/breaker goes, the motor runs but it won't heat)
Hope this helps
Jan 28, 2011 | KitchenAid Ovens
I have a Bosch double oven and it continues to heat even when I turn it off. I then flip the breaker to turn it off. When I flip the breaker back on a code pops up (VO515 HOO47 ...
Hello there again
I know you rejected the chat and that is all right
Here is the part and what it looks like it may be a different color
Oct 16, 2010 | Ovens
Kenmore electric oven will not turn on.
burnt out fuses or flipped circuit breakers? burnt out elements? Fuses are usually in the top of the oven above the knobs. Is it just the oven; check the main circuit panel? details?
Dec 28, 2009 | Kenmore Ovens
Miele H4900B Electric Single Oven Logo
90 people viewed this question
Top Miele Ovens Experts
Paul Bade
Dan Webster
Dan Webster
John
Are you a Miele Oven Expert? Answer questions, earn points and help others
