Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Whirlpool Dispenser Problems
Water is only dispensed sporadically. Sometimes it works & sometimes it doesn't. The ice maker seems to be working and the ice dispenser is fine. It does not make ice all the time, though I hear it trying to. I think that water is just not making it to the ice cube trays. I thought it might be a frozen line but that would not explain why both work every now & then. I thought it might be the solenoid but by the way it is behaving, would that mean both solenoids went bad simultaneously? I also heard it might be the "head" but I am not sure what that even is. Any help is appreciated.
  • 1 more comment
  • Anonymous Oct 09, 2008
    Whirlpool side by side refrigerator Model ED22TQXEW01
  • cjzuvella Oct 09, 2008
    Whirlpool side by side refrigerator Model ED22TQXEWO1
    Water dispenser has stopped working.
  • mcdowellshar May 09, 2009
    Whirlpool ED2VHGXMQ
  • 148 Answers
It is possible that the water line has frozen, but I would venture to guess that it is most likely the water inlet valve. Both can be accessed by removing the back panel on the back of the fridge down at the bottom.
Posted on Oct 21, 2008
Problems with ice maker and water dispenser
Sometimes the water line entering the freezer will freeze up, if it is you can melt it with a hair dryer. If that is not it you will need to test the solenoid valve under the refrigerator for power, if so you can remove the water line on the outlet of the valve or the inlet of the water filter, when you push the water lever water should squirt out of the hose, if not the valve is problem bad.
Mar 17, 2014 | Whirlpool Refrigerators
FRIGIDAIRE FRS26ZSG - WATER DISPENSER
Is there an overflow module that connects the icemaker to the water dispenser? If you are still getting ice, it is probably just extra water.
Jun 03, 2008 | Frigidaire FRS26ZSG
Ice maker not dispensing
This is possibly only a defective micro-switch on the Dispenser Module. Can you post the model number so I can examine the correct parts?
I am here should you need me, Thanks John Tripp Appliance 911
Contact Me Here
Mar 16, 2014 | Refrigerators
Ice Dispenser on Kitchen Aid Model KSCS25FTBL has stopped working
It can be faulty ice maker assembly and needs to be replaced.
Sometimes it visually sees ok,but actually its worn out or cracked causing the problem.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
My Whirlpool Gold Side by Side (counter depth) [model# GC3PHEXNS00] refrigerator stopped making ice. Water dispenser is still working, doesn't seem to be an obstruction in the line. What do I do?
Can be clogged water passing line or faulty water valve.But if you have already checked the water passing line and it seems clear, then its most probably the water valve.---------
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
This will help. Thanks. Helpmech.
Sep 18, 2011 | Refrigerators
The ice maker is not working right
replace the water valve and clean the coils undrer neath . ( make shure the fan under is working . mm
Jul 03, 2010 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Whirlpool GR2FHTXVQ00 fridge. Water dispenser
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
You can thaw out the fill tube and replace the inlet valves.
Oct 13, 2009 | Freezers
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerator not making alot of ice cubes
a bad valve will make them stick togather and sometimes hollow but the ge is well known for the back board being bad
Mar 18, 2009 | Refrigerators
Ice Dispenser Doesn't work...
sounds like the water coming into the icemaker is spilling over or leaking into the ice despenser bucket.... check for ice build up or plugging of water chut into ice maker
Aug 08, 2007 | Whirlpool GS6NBEXR Side by Side...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
333 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
