Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Tv wont power up ?
Tv button will come on for 4 sec. and go off after 3 sec. Allready tryed the main plug in & out of the wall shocket. Still not working. Tv worked fine last night and now nothing .Been trying to turn it on since 12 noon. What can I do now ?
  • roctam2002 Sep 30, 2008
    i have a mitsubishi 55" tv with the same problem. push the power button andf the green led comes on for 3 seconds and turns off. i dont know how to test the power source
TV turned off and will not turn back on.
Posted on Oct 02, 2008
MY TV WONT COME ON
1. Make sure AC power is on at the wall socket. Check your circuit breakers to see if one is tripped that allows power go to the wall socket.
2. Check your TV power cord and plug in to take sure the cord is not broken or damaged and that it is properly plugged into the TV.
3. If you are using a remote, replace the battery and see if the TV starts to respond to the on off button.
3. I assume you get nothing on the TV, pressing the menu button does not show the menu. If you do get something, try reprogramming the remote.
Jan 23, 2018 | Televison & Video
When I turn on my Sony TV, ti stays on about 30 seconds then shuts off, What do you think is wrong?
Do a Power Reset.
1. Turn off TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If issue persists after doing the steps, reset the TV to factory default settings.
1. Turn on the TV.
2. Using the supplied remote, press and hold the UP arrow button.
3. While holding the UP arrow button press the POWER button on the TV itself.
4. When the TV goes off, release the POWER and UP arrow button.
5. The TV will turn on by itself and the initial setup screen will be displayed. Just follow the on-screen prompts to finish the setup.
Sony KDL 46V5100 random shut off 15 20 sec
Feb 25, 2016 | Sony Televison & Video
Hp officejet 6310 makes loud grinding noise on right side
1) connect the printer directly to wall
2) try different wall outlets
3) unplug the power chord and then press and hold down the power button for 30 sec. release the button.. then plug in the power chord
4) then try to move the carriage manually from left to right.
5) check if any papers or any thing is stuck inside the printer or not..
6) then unplug the power chord.. press and hold the pound(#) and no 6 key together and then without releasing the button plug in the power chord..once the power button in plugged in release the button..
the printer would go back to factory defaults..
check what happens
7) issue not resolved the service the product..
Mar 26, 2011 | Office Equipment & Supplies
The tv wont turn on all the time-the tv will make a noise like it coming on then the power button blinks and it doesnt turn on-Then it might come on after 20 minutes or 10 hours.
Hi Friend,
Please folliow the below steps one by one
Step 1: Turn on the TV
Step 2: Hold the ON/OFF Button for 10 to 20 Secs
Step 3:Without taking the hand from the ON/OFF button unplug the power cable connected to the wall outlet from the TV
Step 4:Without taking the hand from the ON/OFF button put the power cable back to the outlet
Step 5:Now take the hand from the ON/OFF Button and try to turn it ON again and check
If still you are having the same problem then please check the resolution configured in the Screen,try to reduce the Colour and the brightness of the TV
Even after that you are facing the same issue please check with the Display Card in the TV,
If you have any Clarification please feel free to contact us
Regards,
Ayyasam
Apr 03, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
My sony 63 inch big screen picture goes on and off
Hi Friend,
Try by changing the power cable to any other wall outlet in your home
Regards,
Ayyasam
Apr 03, 2010 | Televison & Video
Paper jam occurred, now printer wont print.
  1. Press the On button to turn off the HP All-in-One.
  2. Unplug the power cord from the back of the HP All-in-One.
  3. Unplug the power adapter from the wall outlet and wait 30 secs.
  4. Plug the power adapter back into the wall outlet.
  5. Plug the power cord to the back of the HP All-in-One.
  6. Press the On button to turn on the HP All-in-One.
Feb 03, 2009 | HP Office Equipment & Supplies
SC-pt750 - screen says CT-Mode wont change
Try cold start.
Power off main set manually by press power button on main set.
Unplug power cord from main set.
Wait for about 5 sec.
[Without plug in power cord] Press and hold "Power" button without release it.
Plug in power cord (must have power) to main set by using another hand [while another hand still press on main set power button]
Keep holding until u see ------ on main set FL display.
Then release you hand which just now pressed on main set.
Power on main set again by manual press power button on main set.
Result should be OK (unlocked)
Dec 06, 2008 | Panasonic Home Theater System System
Blue light
Okay, I found a fix! Called JVC, spoke to somebody there, here it is:
1)unplug the TV completely, no wall no power strips, completely
2)wait 10 sec
3)plug TV back in and Turn it on, the light will still be doing the same thing
4)wait 30 sec
5)ON THE TV, not the remote, locate the menu, volume (-) and power button.
6)while simultaneously holding down the menu and volume (-) button, pressed the power button ONCE and continue to hold the other 2 for 10 sec.
7)on the remote control, go to menu>settings>system info
*** now this I know as a FACT will work on systems that display: JVC - ver.5.32FO001, but I don't know of any other versions***
8)press the mute button on the remote twice
9)unplugg TV again and wait 10 sec.
10) plug TV in and turn on
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first.
Nov 27, 2008 | JVC LT-42X579 42 in. LCD TV
Helpme please
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Aug 25, 2008 | Philips 150S4FB 15" LCD Monitor
My computer shuts down after 3 secs
Try to separate the power cord of your monitor from your system or maybe if your using UPS(uninterrupted power supply) directly plug the UPS to the wall outlet. either you can use pretty voltage regulator to the regulate the AC power.
if not solve the problem try to examine the your system power supply.
Dec 11, 2007 | Computers & Internet
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
134 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
