Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE Profile Gas Range, serial at235522p, model JGBP79WEW1WW
What is the procedure to calibrate the oven? I checked my oven temperature against a kitchen thermostate with probe, there is a 30 degrees difference... my oven is lower.
    Problem Solver:
  • 15 Answers
If this is a newer range, the instructions to recalibrate should be in the manual that came with the stove
Posted on Oct 07, 2008
Me GE Gas oven is not working, but broiler and range do ?
I am working with model JGBP26WEH1WW GE Gas range: You do not need to remove the back or even turn over, just remove the storage pan at the base of the unit and disconect the two plugs (unique plugs). You will need to splice your old conectors to your new igniter. Yes you have the correct igniter for that model.
Apr 06, 2010 | GE Profile JGBP79 Gas Kitchen Range
My Frigidaire FGFL67DBF gas oven does not reach the temperature set. I tried to calibrating the control, but it did not work. Any suggestions?
I believe that you have a convection oven.... by design, convection ovens built by GE come up to temperature....at 25 degrees below the set level .... when the Convection function is enabled.
Oct 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
F3 code on ge xl 44 gas range
F3 Open oven temperature sensor circuit Measure oven temperature sensor circuit at oven temperature sensor (should be approx 1100 ohms at room temp); check for cut or pinched wire or loss of contact
Jun 25, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Claibrating the temperature of a GE gas oven
5 degree increments from factory setting
1 is +5
2+10
and so on
Apr 12, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 gas range, oven dial doesn't have "lite"?
Set the oven for the desired temperature. It will cycle on and off at that temperature.
It will lite automatically.
Feb 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven temp control not working
you need to calibrate the oven.
go to this web site
http://genet.geappliances.com/geasearch/Dispatcher?REQUEST=GETSEARCHRESULT
the second in the list is your solution
Dec 02, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
I just conveted my ge gas range model #JGBP85CEJ2CC. how do i calibrate the oven
I assume you mean converted.  Changing the gas supply from natural to LP or vice versa should not change the temperature calibration settings. Most manuals have a compensation method for their units within them, should you suspect your temperature dial is out of range.  Get a small oven thermometer, put it in the oven, run at a known setting...say 350 and read what the gauge says after 15 minutes.
Your manual can be found on the GE site under http://www.geappliances.com/service_and_support/literature/
Nov 26, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
First of all, do not use the oven thermometers from a grocery store. they can be off by 20 degrees or more. These directions may help you for electronically controlled ovens. The older manually controlled ovens have a small screw head in the center of the oven temperature knob that can be adjusted in usually 10 degree increments.
To Adjust the Thermostat
Touch the Bake and Broil Hi/Lo pads
at the same time for 3 seconds until the
display shows SF.
Touch the Bake pad. A two digit number
shows in the display.
Touch Bake once to decrease (-)
the oven temperature, or twice to
increase (+).
The oven temperature can be adjusted
up as much as 35°F. or down as much
as 35°F. Touch the number pads the
same way you read them. For example,
to change the oven temperature 15°F,
touch 1 and 5.
When you have made the adjustment,
touch the Start pad to go back to the
time of day display. Use your oven as
you would normally.
NOTE: The thermostat adjustment for Baking
will also affect Convection Baking or Convection Roasting.
Nov 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra XL 44 gas oven
If you can smell the gas when you turn on the oven, it may be on a separate igniter that has gone bad. I would check this first. If you are not getting gas to the oven, there is possibly an issue with the supply line.
Sep 25, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
795 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
