Question about Tappan TGF320 Gas Kitchen Range
Stove window cleaning
I have a Tappan Model: TGF351ES stove and somthing dripped on the inside of the outer glass window. How do i remove the out window to clean the insode of the glass?
  • walla111 Nov 02, 2008
    Tappan TGF336 has the same issue with food dripping between the glass....HOW do you clean it?
    President:
  • Tappan Master
  • 2,651 Answers
Refer to your use and care manual as to howe to remove your door assy, generall its open door fully and "lock " the hinges\( pull tabs on bothhingestha alloy you to "lock" thehing and upn lockking you lift the door rigth off then its a matter of removing the frame holding the glass, do it slowly and carefully the galls will coe of, clean it and revers the procedure to reinstall the door
Posted on Nov 03, 2008
What do I do with the oven door that now has drip marks inside the seal?
You will not be able to clean the marks. They are cooked-on food. You will have to replace the door glass.
Mar 10, 2014 | Kenmore Stove / Oven / Range Bake Element...
Tappan self cleaning oven
You plobably have the incorrect drip pans that do not have the proper holes for the grates to fit in, I would chech with an appliance repairman, he should have a source for the correct drip pans.
Aug 14, 2013 | Ovens
Oven ignitor
is the ignitor getting white hot in the center.it may not be drawing enough current to open the gas flow regulator.the only othe thing foe you to replace is the main control board.or better known as the clock timer
Jun 09, 2010 | Tappan TGF351ES Range
Tappan oven door seal replacement
You will have to google the parts may be very hard to find but you never know what comes up .
Mar 16, 2017 | Tappan TEF242 Electric Kitchen Range
It's a pain to re-install the oven door..Please help...Thanks!
depending on what type of stove you have,the oven door should just slide on over the two hinge arms.I have found that by carefully pulling those hinge arms down it is much easier to slde the new door on.
Jan 28, 2010 | Tappan TGF351ES Range
Outer glass needs cleaning
yes. open door slightly to first stop point, pull up on door. the door will come off. there are screws on the bottom of the door and on the side facing the inside of the oven remove these screws to take door apart
Nov 18, 2007 | GE Profile JTP18 Electric Single Oven
Kitchenaid Oven
I believe the entire door must be removed first. then remove every screw that you can find and draw a picture where they came from. then split the door open like opening a clam. then you may find additional screws to remove the glass
Jun 02, 2007 | KitchenAid Architect Series KEMC308KSS...
Tappan TGF320 Gas Kitchen Range Logo
177 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
