How to open the top of a GE washer (wpxh214aoww)
Hi our washer started to act funny a few minutes ago and now we find out that it started to leak
How do you open the top part of the washer (or better yet how to fix it
  • Anonymous Apr 01, 2009
    Hi I dont know how to open this machine, its GE 7 cycles, top load
  • 943 Answers
Hi thanks for the question theres 2 clips on almost each corner use a flat screw driver at each corner and pry towards you the top should let go remove front it could be leaking from pump thanks the appliance doc
Posted on Sep 27, 2008
Unlock top load washer
Hi, switch power off completely, remove plug from socket, wait few minutes then reinstall plug and start anew. (It would be great if the machine had a reset button). Hope the power unplugging does the trick. All the best.
Apr 17, 2014 | Frigidaire FAHE1011MW HE Top Load Washer...
Major humpng in spin cycle GE front load madel WPXH214AOWW
Hi from retired Englishman in SW France @ 20:46 Thur evening.
All washing machines, whether front or top loaders, must have all of their feet firmly on the floor to operate without rocking n' rolling and being unstable!
With the machine NOT running push one front corner firmly diagonally (tawards the centre) and if it moves it is THAT foot which requires adjusting downwards until it is really firmly- almost pushing- on the floor. If not that corner do the same with the other. Once the machine is REALLY stable ensure that the locking nuts lock the feet in position so that they will not unscrew and make the machine unstable yet again. Might take a little time but it is imperative, not only for good operation but it also saves damage to the drum supporting mechanism.
John C
Feb 03, 2011 | GE WSXH208A Front Load Washer
GE JKP45 double wall oven shuts off
This sounds like a loose connection (solder joint) on the main control board. I had one that had a similar problem. checked the price of a control board $350. I took the control panel off, took the board apart and found a loose connection on one of the relays. resoldered the bad connection. oven works fine now.
Nov 07, 2008 | GE JKP45 Electric Double Oven
How do I open my GE Top Load Washer to check for leak
Pull the washer foward, tilt back against the wall and look under it.... look where the water pump connects to the motor shaft... check for rust etc.... if so replace pump....
Dec 15, 2007 | GE WCXR1070A
Water leaking when when washer is running a large or super load
the leak could be coming from anywhere in the washer it just leaks out from the lowest point of the washer i would suggest placing a putty knife under the top on the right and left side and pushing the tabs in to pop off the front panel to see where the leak is coming from
Oct 30, 2007 | Kenmore 24872 Top Load Washer
Washing Machines Logo
2,142 people viewed this question
Top Washing Machines Experts
