Washing mashine my washing machine won't drain or spin after a cycle can you help?
  • 1,031 Answers
If there is a drain issue, sometimes there is an obvious solution. Check the drain hose for any kinks, as well as checking any lint filters in or on the drain hose. Is there a lint sock on the end that's full? Perhaps the drain line itself is plugged. You will want to make sure that the house drain system is not backed up or plugged. Always make sure that the washer drain hose is above the level of water in the drain tub. Some Whirlpool/Kenmore washers make use of a side-check valve near the tub outlet which may get clogged. A standpipe should be at least 1 1/4 inches in diameter, and never seal a drain hose into a standpipe. This can lead to back-siphoning. You also want to make sure that the standpipe is less than 96 inches in height. Pump problems show various symptoms. Sometimes the pump will lock up and seize. If the motor is running, it will continue to try to turn the pump. In the case of belt-driven pumps, the belt may break or burn through. The pulley may shear off. If there is enough tension on the belt, and the motor continues to try to turn it, you may wind up with a seized motor as well. The pump itself may have seized bearings, be jammed by clothing or another object; or the impeller blades may be broken off. The usual fix is to replace the pump.
If you think your pump may be jammed, drain out your tub and remove the hoses. Look inside the hoses and see if there are any obstructions. Feel around inside the pump inlets for anything that may be jamming the pump itself. You can also use long-nosed pliers to feel around inside the pump for any items that may be causing a jam. If you haven't found a jam, and you still believe there may be a jam in the pump, you can completely remove the pump from the washer and inspect it more closely.
Occasionally, transmission gears may become worn, or some other internal part may go bad. Some older washer models have an electric-mechanical shifter. If it won't shift, it's best to call a professional appliance repair person to address this issue. If your transmission is leaking oil, there are really only two options at this point, either run it until it dies completely, or replace it now.
Posted on Sep 27, 2008
  • Starnley Johnwells
    Starnley Johnwells Sep 27, 2008
    If your washer is slow to fill, or won't fill at all, you'll want to check the water pressure at another tap first. Make sure both the hot and cold taps are fully open. Make sure that no other water is getting used in the house when the washer is filling. Check the hoses for kinks. Make sure that water is getting to the water intake hose. With your tap shut off, loosen or remove the hose from the tap, then open the tap slightly to see if water is getting to the hose intake. If water is getting to the hose, remove the hose from the washer to see if water is making it through the hose to the water intake valve.
    Make sure the lid is down as some washers will not fill if the lid switch is not activated. Also, make sure the drain standpipe is at least 30" tall. If it isn't, the water may get siphoned out of the washer. If this is happening, install an air gap in the drain line.
    There are strainer screens in either of the ends of the hoses that connect to the water valve, or in the valve itself, sometimes in both places. You'll want to remove the hoses and check the screens to see if they are plugged or not. In certain set-ups, the screen is non-removable, and you will need to replace the hose or water valve, depending on which it is. If the screens are dirty, you may be able to clean them with an old toothbrush. If you can't clean them, you will have to replace them. If the screens are clean and water is getting to the valve, it may be that the valve itself is bad. You may need to replace the valve.
    Adjust the temperature setting to warm and set your timer to the fill cycle. Start your washer and lift the lid. You'll want to depress the lid switch with a screwdriver or other tool to prevent the interlock from engaging during this test. Feel or look for water entering the wash tub. If no water is coming in, or if it is too hot or cold, you'll need to test the voltage on each solenoid valve with a volt ohm meter or Digital VOM. The voltage should be between the ranges of 110v to 125v.
    If the voltage is correct and the valve is not opening, you need to replace this valve. If the valve is not getting any power to it, you will need to use your washer specific wiring diagram to look for any broken wires, and if there are no broken wires, move on to test the lid switch, temperature switch, timer, and the water level switch. Replace anything that is defective.
    No cold water: check to make sure the cold water is on, and that control settings are set properly. Check intake screens for a sediment or rust buildup. It's possible that the water-inlet valve is bad.
    No hot water: check to make sure the hot water is on, and that control settings are set properly. Check intake screens for a sediment or rust buildup. It's possible that the water-inlet valve is bad.
    Visually inspect the selector switch, make sure that it is set properly and verify that all of the control panel buttons are pushed in completely.
    Note: Some brands have a mercury-tube lid switch, and raising the top of the cabinet to get to the solenoid for testing will have the same effect as raising the lid. You may need to jump the switch to perform tests with the cabinet top raised.
    [Back to Common Questions about Washers] [Back to Beginning]
    Why are the wash and rinse water temperatures incorrect? Make sure that the water fill hoses are hooked up correctly, not reversed. Verify that the correct temperature setting was selected. Your household water supply temperatures can have a very big effect on the wash water temperature. The temperature of the water can be influenced by the local climate, the room temperature where the hot water heater or washer is located, or by the thermostat settings of the hot water tank itself. You may have to adjust your hot water heater settings accordingly for the weather where you live.
    If someone else is using hot water in the home at the same time, the washer may not receive the hot water it's calling for. The best thing is to make sure the washer is full before using hot water elsewhere in the home.
    The hot selection on the control panel causes only hot water from the hot water heater to enter the washer, while warm is the hot and cold water from the house mixing in the water-inlet valve body. Cold is just the cold water from the house.
    If your washer has a temperature sensor inside, you may hear the water-inlet valve opening and closing several times to ensure the water temperature is within the temperature range that has been selected.
    Why is the cold water setting delivering hot water all of a sudden? If you haven't changed the hoses at all, and you've been using this washer regularly with no problems, the temperature switch has probably gone bad. If the temperature switch itself has gone bad, there is no longer any control governing which side of the water-inlet valve is going to let water in.
    Why is the Washer not agitating and/or spinning? Make sure the lid is closed. There is a switch inside that completes the connection. Your washer may not spin or agitate if this connection is not completed. Make sure that the speed selector switch is not between speeds. Verify that the washer is not in a soak cycle. You can also reset the water level up or down to make sure that the water level control switch isn't stuck. If you hear a humming sound when the washer is full of water, you may have something stuck in the drain pump.
    If one of these is not the problem, check the belt. The main drive motor has two distinct functions. The first function is to spin the basket; the second function is to reciprocate your agitator. Inside your washer's transmission is a crank type gear and connecting rods that are used to agitate the washer, with the spinning coming from the washer motor itself. This usually entails some sort of clutch mechanism. Some things to check if your washer is not agitating and/or spinning are:
    If you notice weak or no agitation, the splines connecting the agitator to the drive shaft may be stripped and need to be replaced.
    After a lot of use, belts can become worn or damaged. Replace any worn or damaged belts immediately. If you have a broken belt, replace it and check the pulley to make sure it's not seized.
    Sometimes the drive pulley can wear out and it won't turn the drive belt. Look for wear marks, pits, or uneven spots. It's best to just replace it with a new pulley.
    Many washers use a reversing motor. Sometimes it will continue to work in one direction even if it won't spin in the other direction. If your washer has a drive motor issue, you probably need to replace the motor with a new one. Call a professional appliance repair person to verify this first.
    The lid switch is a safety device that's there to protect you from sticking your hands into a spinning washer. If this switch goes bad, the washer will not work. You will have to replace it. It is inside the main housing for the washer, and located near the door frame.
    The coupler connects the motor to the transmission. After lengthy use, this plastic and rubber coupler can wear out. If this happens, you need to replace it.
    Transmission and clutch assemblies can cause agitator and spinning problems They are fairly complex, so if you suspect you have transmission or clutch issues it's probably in your best interest to call a professional appliance repair person
    pls dont forget to rate it
WASHER WILL NOT DRAIN THE DIRTY WATER
Posted on Jan 28, 2009
  • 943 Answers
Hi thanks for the question i would check the lid switch a very common problem thanks the appliance doc
4 Suggested Answers
  • 1073 Answers
SOURCE: washing machine not draining and spinning
Posted on May 01, 2008
  • 686 Answers
SOURCE: Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Posted on Apr 04, 2009
barkencoa
  • 3463 Answers
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Posted on Dec 09, 2009
/Hello How do I wash a cloth and let drain the wahter and again prigramm the washingmashin to wash that cloth again
your nuts
a washing machine performs a cycle
wash rinse and spin
and thats that
you need a woman or man to wash again and again
Feb 07, 2015 | Washing Machines
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Washing drum not rotating
More than likely belt gone, otherwise the motor has gone.
Apr 06, 2014 | Russell Hobbs RH1042 Frontload Washing...
Washing machine wont spin
Sounds like the belt either broke or jumped off the pulley. should be a simple fix from the back access.
Feb 25, 2013 | Bosch Washing Machines
Kenmore washer 80 series does not drain
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Here are some steps to help you determine the problem and solution:
1. Pinched hose: Is the drain hose at the back of the washer been flattened or twisted in any area? A pinched hose could prevent the water from draining thoroughly. Gently straighten the hose, and make sure there is sufficient room between the back of the washing machine and the wall to prevent a repeat of the problem.
2. Clogged drain hose or pump: Does the drum spin normally, but the washing machine won't drain the water? Sometimes a piece of clothing, money, fabric or other debris gets into the water between the inner and outer tub. It may then make its way into a drain hose or even into the pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. Call a repair professional for help.
3. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
4. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
5. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
6. Pump failure: Is your washing machine more than 7 years old? Your pump may simply have worn out. Even if it sounds as though it is running, the pump may not be working well enough to draw the water out of the machine. Replacement parts for pumps are generally unavailable. A new pump may be necessary.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Washing Machines
Asko 620 washer won't drain well with heavy load
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Overloading your washing machine can cause items to be swept into the space between the inner and outer tub, leading to clogs in the drain hose or pump. These clogs may be the reason for why your washing machine won't drain. Here are some steps to help you determine the problem and solution:
Oct 08, 2012 | Asko W6021 Front Load Washer
Roper washing machine fills and washes, but when it gets to the spin cycle there is no sound and it won,t spin.
Hi m3gamma1,
Before the Spin Cycle should start, all water must be drained out of the machine. If it does not start, it could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 05, 2011 | Washing Machines
Asko 10625 will not spin
it is probably the belt, take off the back of the machine and look at the black rubber belt that spins the cleaning drum. The belts break after about 5 years, you can get a replacement belt at you local Asko dealer, I recall that is was pretty easy to change, like doing a bike chain, Talk to you Asko dealer about how to change it.
Mar 29, 2009 | Asko Washing Machines
Washing mashine repair
Plug off the wall. Clean out your outlet filter. Access is a door in the front bottom of your machine, be prepared for some water to come out. Refit.
Sep 17, 2007 | Washing Machines
Washing Machines Logo
648 people viewed this question
Top Washing Machines Experts
