Question about Kitchen Ranges
Electrical problem w/ magic chef electric range CER3540AAA
The burners and oven suddenly stopped heating- but when the dial is turned, the led (?) clock flashes on, and the oven setting buttons work, but no heat....so there's electric in, but something not connecting.....is this fixable?
  • pjllp Sep 27, 2008
    Thanks for the quick response- I didn't check fuses yet- it'll be great to fix it that easily- hope it works! (will be back if not) thanks
    Checking back- If there were fuse problems, where would they be located? We have breakers in both the indoor panel to the kitchen, and the main panel outside- none of which are tripped....Also, how do I check for 220 at the stove, with a tester in the socket?
  • 943 Answers
Hi thanks for the question i would check to see if theres 240 volts at the stove if only 110 volts at stove you will not get any heat but lights will work check that replace fuses in main panel for the stove thanks the appliance doc
Posted on Sep 27, 2008
Our Magic Chef oven just began making a whirring noise and the clock stopped functioning properly at the same time.
Hi Peggy Freeman,
I suppose that it is a Maytag Magic Chef.
From your description my conclusion is an electrical fault on the clock.
You have to open the cooker and remove the connection to the clock.
BE CAREFULLY
Always insulate the connector, as it is mains grid.
When it is indeed the clok, the noise will stop, but you an not use the clock anymore.
Kind regards, Dik
Here you find a PDF of the Maytag Magic Chef:
https://www.repairclinic.com/UserManual/b8e1b97795884ea59496a9eaf1a93883/Magic-Chef-Range-Stove-Oven-Repair-Manual-CGL1100ADQ-CGL1100ADW-CLL1101ADW.pdf
Feb 08, 2018 | Kitchen Ranges
Oven Won't Heat To Desired Temp / Burner Quits Working Sometimes
The temperature sensor in the oven needs to be replaced. Here is the part to order. As far as the top element, lift the top up and look for lose or broken wires on the element. Keep me posted.
Nov 20, 2012 | Magic Chef Ovens
I have a magic chef oven model # 61S04PAW. the
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 07, 2010 | Magic Chef 31000 Gas Kitchen Range
Magic Chef oven stops working
the ovan could be a thermostat 3" 2 6'' long probe my first gess or the ignitor top you need more help with could be a lot of things hope this helps a lititel
Feb 13, 2010 | Magic Chef CGR3742 Gas Kitchen Range
How do you light the oven? We turn the dial and
I take it the range is electric ignition because you say the top burners have a clicking(igniter) noise. If the top burners are electric ignition then the oven is also. The oven probably uses a hot surface igniter and that is why you do not hear any clicking. Turn the oven on and open the broiler compartment. You should see a bright glow from the hot surface igniter. If you do not see any glow there may be a grounding issue or the igniter could be bad. If you do see a glow but the burner does not come on in a few minutes then give the gas valve a tap with a wrench and see if the burner comes on. Shut it off and then back on several times. If the burner continues to light after this you may have fixed the problem. If it does not come on gas valve could be sticking or igniter is weak.
Sep 10, 2009 | Magic Chef 31000 Gas Kitchen Range
Slow heating- low gas to burner
The main solution of it is to clean the gas tube.
May 18, 2009 | Magic Chef CGR3730 Gas Kitchen Range
Ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
Dec 30, 2008 | Magic Chef 31000 Gas Kitchen Range
Surface Heat and other lights will not light up. Will not get hot but is trying - gets slightly warm. This includes burners and oven. The cooking light will come on in the oven but nothing more. The...
you have a power promblem start where the cord connects to the range and go back from there to the fuses before you pull it out turn off the breakers loose connections will cause the cord to short out sometimes
May 24, 2008 | Magic Chef Kitchen Ranges
Kitchen Ranges Logo
206 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
