Question about Acer Aspire 3690-2196 Notebook
Acer 3103 WLMI I lost my CD Drive
My CD drive disappears suddenly. When I check the devices it is not there. And suddenly and after many clicks through Control Panel, I shows again.
Any tip?
  • Michael France
    Michael France Oct 17, 2008
    ACER ASPIRE 2920 CD AS DISAPERD COMPLETLEY
I have no solution yet, but I don't want to pay for it too.
Thank you for following up and hopefully I will find free help.
Best regards,
Ashraf
Posted on Sep 28, 2008
Lost Acer D2D Recovery Partition
hi
thank you for using Fixya
i have lost your recovery then only once solution just you have to run Windows CD and re load your Windows XP then go to Acer Site and Download drivers for your model
you will find drivers from folowing link
http://www.latestdriversupdate.com/driver/41652.html
May 14, 2010 | Acer Aspire 5610-4648 Notebook
CD-RW driver disappeared
check the cable connections to your optical drive..it must have loosen up
Sep 05, 2009 | Acer Aspire 3050 Notebook
Acer harddrive working also in other Acer notebooks?
You can physically install the drive in any laptop with the same type. They will either be SATA or IDE. However unless you have a nearly identical system which is unlikely after a few months of buying it the windows installation is not likely to work.
The better solution would be to stop in at your local computer store and purchase a 2.5" drive caddy and install the HDD into the caddy. That caddy will then work as an external HDD on any computer you purchase allowing you not only to access the files on it but also to backup any new data.
Chris
May 31, 2009 | Acer Aspire 5100 Notebook
Ive lost the cd drive
Kindly follow the following steps..
1. Go to Device manager. Click on the + sign beside IDE drives. Right click on the dvd drive and select uninstall. Restart the computer. It should get installed automatically as it is a generic driver.
2. Go to run > type regedit > go to the following key
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\
Select the folder that says ( 4D36E965.....
on the right hand side delete the file that says "Upper filters" and "Lower filters"
3. Go to device manager > clock on the + sign beside IDE ATA ATAPI Controllers > right click on Secondary IDE channel and secect uninstall. Do the same with Primary IDE channel. Restart the computer.
4. Reseat the dvd drive.
Hops this helps..
Regards,
Anup
Apr 05, 2009 | Acer Aspire 5735 Notebook
Computer does register wen i put a cd in the tray
Hi try rebooting the laptop or if that doesn't work you may have to search of another drivier for the E: drive.
It happened to me ages ago on my acer aspire 5100/5102 wlmi
Apr 02, 2009 | Acer Aspire 5315 Notebook
Vista lost DVD/CD Drive But fine with XP
From your description, it is look like registry issue.
MS has solution to fix that problem by editing registry.
just follow the step from microsoft website in order to update registry:
http://support.microsoft.com/kb/314060
Jan 05, 2009 | Acer Aspire 5050-3242 Notebook
E DRIVE DISAPPEARED FROM LAPTOP (ACER)
this is a known issue check the microsoft website on how to work on this,. look for the part where you need to do something with your registry.
Dec 18, 2008 | Computers & Internet
Acer 5100 lost dvd/cd drive
Is the DVD drive listed in device manager under CD/DVD drives at all? If so, remove it and reboot. Windows might be able to re-detect and reinstall the drivers for it, but odds are the drive is bad. You can try removing the drive from the computer, and use compressed air to blow out the area where it connects to the laptop. Also check the connection on the DVD drive to make sure there isn't any physical damage, bent pins, etc.
Hope this helps - remember to rate!
Sep 30, 2008 | Acer Aspire 5100 Notebook
Loosing cd/dvd completely from device manager
check your dvd in bios. is it recognised in bios ?
also try to push your dvd, dvd connection to motherboard might be loose.
Jul 31, 2008 | Acer Aspire 9300 Notebook
The slot loading DVD drive does not read CD or DVD on my aspire 1694 WLMi. The e drive also does not recognise a disc in the drive. Device manager states that the drive is working properly, no new drivers...
hi,
you may have a faulty laser in your drive, the best solution will be to try and use another known good working drive in your machine, by doing this you will out find if the fault is with the drive or the the software/mother board.
hope this helps
rami
Jun 27, 2008 | Acer Computers & Internet
Acer Aspire 3690-2196 Notebook Logo
114 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
